W65C265 Multiplexed Pins (PIB and UART3) - Custom Board
Jmstein7
Re: W65C265 Multiplexed Pins (PIB and UART3) - Custom Board
Post by Jmstein7 »
Jmstein7 wrote:
... but then I read 265iromlist (cleaned up by Andrew Jacobs), which gives the code for the internal rom...
Do you have a link for this clean version? I did a quick search but it was inconclusive. Thanks!
Here you go: download/file.php?id=7788
Jmstein7
Post by Jmstein7 »
No problem! Hope all is well with you - it's been a while!
Ha ha - all well thanks - holiday/vacation, friends, family, walking...
Jmstein7
Post by Jmstein7 »
Okay, I've got it running at FCLK 6mhz with Port 3 at 115200 at boot. I'm still using the external clock for Timer 4. For some reason, I can't get FCLK over 6mhz. I just get garbage if I try.
Jonathan
tokafondo
Post by tokafondo »
Jonathan
I don't know how you managed to get Port 3 to run at 115200 at boot.
The ROM monitor listing has calculations for FCLK =< 6.144 Mhz, and bps =<57600.
Page 30 of the w65c265 datasheet v2.1 has the formula to get the values to program the timers for arbitrary FCLK and bps.
Jmstein7
Post by Jmstein7 »
Custom ROM.
handyandy
Post by handyandy »
Does your custom rom contain values for calculating FCLK over 6 mhz and corresponding baud rates?
The internal rom will default to 3.68 mhz on error.
BTW congrats!
Cheers, Andy
Jmstein7
Post by Jmstein7 »
BTW congrats!
Cheers, Andy
Andy,
Great question! My ROM doesn't need to do that because I made FCLK independent of the baud rate. I use TIN on P60 to connect an oscillator for Timer 4. In my case, 1.8432mhz. That is what it uses to set the baud rate. Therefore, you can use whatever FCLK you desire.
Jonathan
Sheep64
In Memoriam
Post by Sheep64 »
I presume that you want to re-assemble the W65C265's monitor program but with UART not clashing. I understand that the monitor looks for a magic string at $8000 and then runs an external program. If you're not using the region from $8000-$DEFF, it might be quicker and easier to run a patched copy of the monitor from external ROM. It might also be desirable to use an external UART.
Jmstein7
Post by Jmstein7 »
The "magic" bytes are "WDC", and the internal rom searches a few different addresses for that. But, I agree that an external UART is desirable.
Jmstein7
Post by Jmstein7 »
Okay, here she is!
I found two errors, but they were simple to fix with two wires and some solder.
Testing her like crazy!
fachat
Post by fachat »
I would have hoped for a 65256 chip version that has lots of internal RAM and boots from SPI flash, so all IO pins would be available instead of having to sacrifice them for the system bus
Jmstein7
Post by Jmstein7 »
I guess that would have made too much sense (?)
tokafondo
Post by tokafondo »
Who knows... maybe some day WDC surprises all of us with a fpga based '265s, so what you say can be achieved.
