100MHz TTL 6502: Here we go!
Drass
Re: 100MHz TTL 6502: Here we go!
Post by Drass »
joanlluch wrote:
I think this only works (possibly) because the 6502 uses two cycles anyway to complete instructions. So in fact you have a two step gap between the fetch-decode-execute-writeback sequence of one cycle to the next. Or in other words, the next instruction fetch happens while the current cycle is in the executing stage, not while it is in the decode stage, as it would be the case for a standard pipelined risc processor. Is this right, or I am missing something fundamental here?
Very astute observation Joan. There is a “gap”, but here is perhaps a more general way to think about this:
The pipeline always fetches and executes one microinstruction per cycle. We avoid WRITEBACK data hazards by ensuring that there is an intervening microinstruction between a register read in the DECODE stage and a corresponding register write in the WRITEBACK stage. On a 6502 multi-cycle implementation, a register write operation is always followed by an operand-fetch for the next instruction (or a nop if the next instruction is a single-byte instruction). Hence, data hazards never occur.
In a RISC implementation, it might be useful to think of this intervening microinstruction as a “data delay slot” which can be “filled” to avoid a stall. You can dispense with hardware hazard checks by having the compiler (or some other mechanism) fill these slots ahead of time, either with other instructions in the program, or with nops that resolve the data hazard but do not preform any useful work.
Drass
Post by Drass »
ttlworks wrote:
Now this gives me quite a headache.
You and me both! :)
Drass, since the ALU input latches will be edge triggered 74AUC16374 chips or such...
have you considered building the registers with transparent latches like 74AUC16373 ?
BigEd suggested a reference to this in an earlier post. We can use a latch to balance the workload between two stages. This works well if you have a stage that is shorter than the cycle and one that is longer than the cycle but the aggregate is shorter than twice the cycle. In that case, a transparent latch between the stages can be used “borrow” time by having the data flow between the stages as soon as it is ready, rather than only when the clock edge arrives.
In this case, most stages are very well balanced already so there is no “short” stage to borrow from. One possible exception is the BranchTest operation. I am still working that out, but we may benefit from a transparent latch for the flags and/or IR (BranchTest requires the opcode to decide which flags to test. The opcode comes from memory in the prior cycle and gets to the IR 1.5ns early since there is no setup time required).
Drass
Post by Drass »
On the face of it, computing Z should be no worse than a carry-chain problem, and indeed the inputs to the Z function arrive earliest from the LSB and latest from the MSB, so Z might only need to be a gate-delay behind C. (I say this, knowing that computing Z often does seem to be a time-consuming thing. So I'm interested in why the difference between theory and common practice.)
That makes sense. (Or is it concurrent with C? The carry chain requires an additional gate after the MSB of the result, no?)
I wonder if there is any way to optimize the V flag. It requires the MSB of the result IIRC (which admittedly still emerges from the adder before the final carry. So there is that).
Drass
Post by Drass »
joanlluch wrote:
Thus it also looks to me that just half a cycle for write-back might not be enough time for what's required, and that as Dieter suggests, we might need to allow some incursion onto the second half of the cycle to make this affordable.
Flag evaluation from the C74-6502:
It should fit in a half cycle using CBTLV and NC7SV logic.
joanlluch
Post by joanlluch »
Actually, using a carry look ahead circuitry you can get the C flag at least two gate delays ahead of the result [I mean that we get C before the result, I'm having some use of English trouble with the word 'ahead']. Also you can get the V flag concurrently with the result.
To illustrate it, you can Look at this Logisim Model of my "ALUCore" https://github.com/John-Lluch/CPU74/blo ... LUCore.png. This is no less and no more than the Dieter multiplexed ALU http://www.6502.org/users/dieter/a2/a2_1.htm with two levels of carry-lookahead, as seen for the 74xx181 / 74xx182 combinations http://www.6502.org/users/dieter/a7/a7_3.htm, with the difference that the carry look ahead goes up to Cn+4 instead of only to Cn+3
- The C flag is generated from the second level carry-lookahead circuit, it is shown on the top right of the drawing. Forget about the "SHR Cy" ic for now, and think that the Carry bit emerges from the 'C4' output of the top right cy-look-ahead ic. Thus the final carry is available before the first level look-aheads provide their carry signals to the end Xor gates, and the Xor gates process them, so that's more than 2 gate delays earlier than the result is available.
- The V flag is generated by Xorting the final Carry with the Carry of the previous bit. The later emerges from the first level carry-lookahead circuit at the bottom right of the drawing, it is depicted as 'Cx' in the logisim model. Thus the Cx is available one gate delay earlier than the Result. Then it is compared (not shown in that drawing) with the final carry by means of a Xor gate, which executes concurrently with the end Xor gates of the adder. Therefore we have the V flag at the same time than the result.
- The problematic flag is still (and surprisingly) the Z flag, which must be computed after the Result
ttlworks
Post by ttlworks »
Joan, thanks for the summary.
For address calculations, we would be going to need a temporary carry flag (not visible to the "end user")
which needs to be updated at the end of the ALU cycle.
For data calculations, evaluating the flag results could be done in the next cycle,
that's "supposed to work" when trying to stay cycle compatible to a 6502,
but this sure won't simplify having cycle exact branches.
From the propagation delays, I think that evaluating the Z_flag can't be done in the ALU cycle.
N_flag, V_flag, C_flag evaluation is "debatable":
74CBTLV3251 8:1 multiplexer:
data input to output: tpd@2V5=0.15ns max. and tpd@3V3=0.25ns max.
select input to output: tpd@2V5=1ns/2.55ns?/4.1ns and tpd@3V3=1ns/2.3ns?/3.6ns.
Drass
Post by Drass »
Ah, right. Thanks for mentioning it. Dieter reminded me of this http://www.6502.org/users/dieter/v_flag/v_3.htm.
The C74-6502 used 74AC283s so we had no access to the MSB input carry. We do so now, but it may still be best to leave the FET carry chain alone. Especially since, as you pointed out, the Z flag must be calculated after the result anyways.
Drass
Have you investigated fast adder architectures, for example? There's a whole body of knowledge (which of course you might already be familiar with). See perhaps
https://syssec.ethz.ch/content/dam/ethz ... Adders.pdf
(via this hackaday post)
Just came across an interesting one, the Brent-Kung adder circuit, while looking at this TTL simulator in the browser
ttlworks
Post by ttlworks »
Did a simulation in C.
BK_ADD.C
(2.21 KiB) Downloaded 82 times
Looks like implementing the Brent-Kung adder >carry chain topology< with FET SPDT pass_through switches won't be too efficient.
Ripple carry adder: carry chain has 8 SPDT switches. Brent-Kung adder: carry chain has 15 SPDT switches.
Also, with the Brent-Kung adder carry chain we would have a select_to_output delay of two switches for the MSB,
with 2.5V powered 74AUC2G53 switches this would be 2.8ns typ.
Haven't checked my wiring above for errors, because I'm not sure if implementing a Brent-Kung adder for our project would be a good idea.
Edit: Q0=P0, that text didn't make it into the schematic when cutting the screenshot to size.
// I love that smell of undigested scientific articles in the morning...
Drass
Post by Drass »
Interesting concept BigEd and great work Dieter. The FET Switch has such asymmetrical behaviour and it’s a whole new dimension to consider. It seems a carry-select arrangement might work (compute the high-nibble with carry low and high in parallel). But even then, the tradeoff is the select time of the final switch vs. the added delay due to capacitance of the upper nibble in series.
joanlluch
Post by joanlluch »
Or we could say it's an old dimension, because the relay computer engineers or the past designed their ALUs on the consideration of asymmetrical behaviour of mechanical relays :D
ttlworks
Post by ttlworks »
Joan, you happen to have some schematics at hand ?
The relay computer engineers probably didn't have to worry much about capacitances. :)
Binary Adder Architectures for Cell-Based VLSI and their Synthesis, Reto Zimmerman 1997.
That's a nice read about adder topologies.
Tricks like in the picture below probably won't bring us far,
because ALU A inputs directly would be feeding the carry chain (piling up capacitances):
On PDF page 45, the conditional-sum adder structure looks interesting.
High-Speed VLSI Arithmetic Units: Adders and Multipliers, Prof. Vojin G. Oklobdzija 1999
mentions on PDF page 15, that a conditional-sum adder was used at Byte level in the DEC "Alpha" 21064.
But implementing a conditional-sum adder at Bit level would be a lot of 74AUC2G53 switches (and a lot of capacitance).
While propagation delays of 4 Bit 2:1 multiplexers are slow, their switching time delays are not.
To me, conditional-sum adders don't look like the thing for our project. //Somebody please prove me wrong.
joanlluch
Post by joanlluch »
Hi Dieter,
The only public documentation that I am aware of, is from the Konrad Zuse Internet Archive. But last time I checked, the link was broken http://zuse.zib.de The Facom 128 from Japan is a more powerful one, still maintained and working at amazing specs. With its 68 bit bus, it performs floating point multiplication in 0.4 seconds max, and division or square root in 1.0 seconds. But I'm not aware of any public docs. The key for performance was a very wide bus (carry chains have zero delay), and an all parallel ALU. To help reliability, floating point numbers were represented on bi-quinary coded decimal and contacts were never switched with current. There's also a number of 'modern' relay computers made by hobbyists, but they are all based on modern CPU architectures, with virtually zero degree of parallelism and much narrower bus (maybe just 8 or 16 bits), resulting in much slower speeds than the original ones, despite using much faster relays. An interesting project would be to make a relay logic based computer with 74CBT3xxx analog switches.
Drass
Post by Drass »
The Facom 128 is amazing! Here is a nice video with a live demo of the machine. Thanks for pointing us to it Joan.
Drass
Post by Drass »
Found this link about Konrad Zuse’s Z1 Computer: Architecture and Simulation of the Z1 Computer. It includes an interactive 3D simulation of the adder (pic below), and a informative pdf about the Z1 computer.
