Edit: if you're hand soldering, you could put a via inside an SOIC pad to save space. This is not recommended for reflow soldering, because the via will wick away the solder.
TTL 6502 Here I come
Re: TTL 6502 Here I come
Drass wrote:
Curious, what size vias are you using?
It's likely I won't have the luxury of a clean VCC plane this time around in any case - in fact, I'm considering doing away with the VCC place altogether on this board and running 24mil traces for VCC lines.
- BigDumbDinosaur
Incidentally, that board is a four-layer design, with the inner layers being Vcc and ground.
Via in the signal paths (0.006 inch traces) are 0.026 inch diameter with 0.008 inch holes.
Arlet wrote:
I normally use 0.6 mm (23,6 mil) via size with 0.25 mm (9.8 mil) finished holes.
Arlet wrote:
I usually run a VCC plane anyway, so that all left over space can be used
Rather than taking a lot of board space making the Vcc lines so wide, I would just put bypass capacitors with the shortest possible connections from Vcc pins to the ground plane. The current peaks you have to worry about for AC performance will go through the bypass capacitor, not the traces.
I did the soldering above with a 30W 1/8" chisel-tip soldering iron, .032" 60/40 rosin-core solder, and no additional flux.
- BigDumbDinosaur
I have soldered the occasional SD card socket, but that's about it as far as SMD is concerned. To get more practice I've ordered a couple of those 1-dollar DIY kits from ebay, just a silly thing with blinkenlights, but they have several surface mount chips. Can as well make something that does something while practicing.
Be careful with the flux though. I once used some flux pens, and the flux got under TQFP packages, and started to corrode the vias.
- BigDumbDinosaur
I have modules built on non-RHOS boards that have been in use for many years, some in cabinets that are outdoors and thus are occasionally exposed to high humidity. I've never seen any evidence of via or pad corrosion. It could be that is because the reflow is lead/tin.
Yes, I think it was post-RHOS time.
drag technique to solder the rest of the pins.
Thanks for all the suggestions - I really would like these boards to have that pristine look
Incidentally, Card B is coming along, but I have a ways to go yet. I'm encouraged that it just might work in 4 layers after all - using 6 mil traces, 5 mil spacing and 18 mil vias. Being VERY careful about how horizontal traces are used seems to be the key to this board - at least the bottom section (horizontal traces are in dark blue, air-wires in bright yellow). I'm working my way up from the bottom so I'd say I'm about 1/5th of the way
- BigDumbDinosaur
...using 6 mil traces, 5 mil spacing...
- GARTHWILSON
- Forum Moderator
Thanks for the pointers and video on SMD soldering - great to have this reference.
Regarding DRC, I've been checking the board as I go and all seems well so far. It's definitely a tight squeeze, but it feels like I'm getting through it. I'm not having to use the VCC layer nearly as much as expected and Arlet's suggestion of putting via's right on the pads has let me get out of a bind a few times
. Nearly half way there now ...
Cheers!
Cheers!
Another milestone along the journey ... the ALU & CU Card is now routed
It took some effort to squeeze things in (and the suggestions above proved essential!). In the end, I'm very happy with the result - over 100 ICs, as many bypass caps, ROM sockets, connectors and assorted passives, along with VCC and GND planes, and even one Canadian flag
. Here is a pic of the top and bottom traces along with the top silkscreen:
As expected, I had to put traces on the VCC layer, but not nearly as many as I feared:
Surprising really how much room there is, and I'm glad I didn't have to resort to a larger board. I quite like the dimensions currently (not to mention that my copy of Eagle CAD won't let me go any bigger - I did notice, btw, that Altium has a new free version of it's software with no such limit, very interesting).
Ok. Next up is more checking and double-checking, and then finally getting ready to order some parts
- BigDumbDinosaur
...over 100 ICs, as many bypass caps, ROM sockets, connectors and assorted passives, along with VCC and GND planes, and even one Canadian flag
