SBC Blaufuchs-II
Re: SBC Blaufuchs-II
norby wrote:
Is the ENC28J60 any good?
The +/- 12 volt outputs are mandatory in the ATX2.0 and ATX-EPS standards, so they will be around for a long time. Also, power supplies have to be backward compatible with older hardware to assure interchangeability.
Anyhow, to use /KS (push button input) and /DPWR to control the power supply, proceed as follows:
- Create a voltage divider consisting of a 2.2K resistor in series with a 3.3K resistor.
- Connect the free end of the 2.2K resistor to +5VSB on your power supply's main motherboard connector—that would be pin 9.
- Connect the free end of the 3.3K resistor to ground.
- Attach the junction of these resistors to Vbaux on the DS1511.
- Connect /KS through a 3.3K resistor to Vbaux.
- Connect /DPWR to PS_ON# on your power supply's main connector—either pin 14 (20 pin connector) or pin 16 (24 pin connector).
- Connect one side of a push button to /KS. Connect the other side of the push button to ground.
Page 2 "Recommended DC operating conditions"
Auxiliary Battery Voltage (note 3) VBaux
Says 5.3 V max.
Later in the text they talk about 2.5V - 3.7V for VBAUX but I guess that applies to the 3.3V (W) version.
I just breadboarded the circuit you described, with and without a voltage divider and both seems to work perfectly.
The only gotcha is that pushing /KS again will not automatically power off the system. It seems that it can be handled in
software though.
As for the DS1511's /RST output, it doesn't respond to a push button the way the DS1813 does, so I question its value to you in this design. If you decide to use /RST, under what circumstances would you assert it? If you arrange for the watchdog to assert it, what about using the watchdog for jiffy IRQ generation? You can't do both.
In lieu of tri-stating the RDY output on the CPLD, you can isolate the circuit with a low-power Schottky diode, with the anode connected to the RDY pin on the '816. A pullup resistor is required no matter how you do it. Better to directly connect RDY to the CPLD and tri-state when inactive. That way you can use the CPLD to detect when a WAI is being executed.
/norby
Were those really weak? BDD was talking about some kind that was really thin. These however are the same thickness as the pins that the ribbon cable on IDE hard-disc drives plug into on a PC motherboard, much thicker than IC pins. The only thing you have to be careful of is that when you pull a module out of the socket, you pull it out straight so you don't bend the pins on one end. It would be possible to put the socket on the module and the pins on the motherboard (instead of vice-versa), although I'll have to figure out a way to test it-- maybe just solder a couple of pin headers tail to tail.
When the machine started beheaving erratic, reseating / pushing it back in usually helped
/norby
- BigDumbDinosaur
norby wrote:
After reading the DS1511 datasheet I get the impression that VBAUX can actually handle +5V.
Says 5.3 V max.
Says 5.3 V max.
Several years ago, I talked to Maxim's tech support on this subject and was told that Vbaux was intended to be powered by a CR2032 battery or similar. I tried to pin the guy down on whether Vbaux could be directly powered off the +5VSB output of an ATX power supply, but all he would say was it was intended to be powered by a 3.3 volt battery. So I decided that he was trying to tell me that the 5.3 volt max was probably a "do not exceed" value and that Vbaux really should be powered by 3.3 volts. Hence the voltage divider.
I just breadboarded the circuit you described, with and without a voltage divider and both seems to work perfectly. The only gotcha is that pushing /KS again will not automatically power off the system. It seems that it can be handled in software though.
It's also possible to detect closure of the power push button while the system is powered, and in fact, you can arrange for that closure to generate an IRQ. In such a case, the IRQ could cause the operating system kernel to initiate an orderly system shutdown when the power push button is pressed, like what happens with Linux or Window$.
After reading the datasheet I got the impression that the watchdog and irq where unrelated, I guess I was wrong, I changed my schematic - /RST tied to VCC via a resistor.
See following code for a set of definitions for the DS1511 and the 26C92.
;DALLAS DS1511 REAL-TIME CLOCK DEFINITIONS
nr_rtc =32 ;total registers ($14-$1F reserved)
; register offsets...
wr_sect =$00 ;TOD seconds ($00-$59 BCD)
wr_mint =$01 ;TOD minutes ($00-$59 BCD)
wr_hrst =$02 ;TOD hour ($00-$23 BCD)
wr_dowt =$03 ;day of week ($01-$07 BCD)
wr_datt =$04 ;date ($01-$31 BCD)
wr_mon =$05 ;month & control...
; xxxxxxxx
; |||+++++———> month ($01-$12 BCD)
; ||+————————> 1: enable 32 Khz at SQW when on battery
; |+—————————> 0: enable 32 KHz at SQW when on Vcc
; +——————————> 0: enable oscillator
wr_yrlo =$06 ;year LSB ($00-$99 BCD)
wr_yrhi =$07 ;year MSB ($00-$39 BCD)
wr_seca =$08 ;alarm seconds & IRQ control...
; xxxxxxxx
; |+++++++———> alarm seconds ($00-$59 BCD)
; +——————————> 1: IRQ once per second
wr_mina =$09 ;alarm minutes & IRQ control...
; xxxxxxxx
; |+++++++———> alarm minutes ($00-$59 BCD)
; +——————————> 1: IRQ when TOD secs = alarm secs
wr_hrsa =$0a ;alarm hour & IRQ control...
; x0xxxxxx
; | ++++++———> alarm hour ($00-$23 BCD)
; +——————————> 1: IRQ when TOD secs & mins = alarm secs & mins
wr_dowa =$0b ;alarm date/day & IRQ control...
; xxxxxxxx
; ||++++++———> alarm day ($01-$07 BCD) or date ($01-$31 BCD)
; |+—————————> 0: alarm date set
; | 1: alarm day set
; +——————————> 0: IRQ when TOD & day/date = alarm TOD & day/date
; 1: IRQ when TOD = alarm time
wr_wdms =$0c ;watchdog millisecs*10 ($00-$99 BCD)
wr_wds =$0d ;watchdog seconds ($00-$99 BCD)
wr_cra =$0e ;control register A...
; xxxxxxxx
; |||||||+———> 1: IRQ pending (read only)
; ||||||+————> 1: IRQ = watchdog timer
; |||||+—————> 1: IRQ = kickstart (read only)
; ||||+——————> 1: IRQ = TOD alarm
; |||+———————> 0: PWR pin = active low
; ||| 1: PWR pin = high-Z
; ||+————————> 0: PWR pin = high-Z wo/Vcc present
; || 1: PWR pin = active low wo/Vcc present
; |+—————————> 1: aux external battery low (read only)
; +——————————> 1: external battery low (read only)
wr_crb =$0f ;control register B...
; x0xxxxxx
; | |||||+———> 0: watchdog generates IRQ
; | ||||| 1: watchdog generates reset
; | ||||+————> 1: watchdog IRQ/reset enabled
; | |||+—————> 1: kickstart IRQ enabled
; | ||+——————> 1: TOD alarm IRQ enabled
; | |+———————> 1: TOD alarm wakeup enabled
; | +————————> 1: NVRAM address autoincrement enabled
; +——————————> 0: TOD & date register update disabled
; 1: TOD & date register update enabled
wr_nvra =$10 ;NVRAM address port ($00-$FF)
wr_rsva =$11 ;reserved
wr_rsvb =$12 ;reserved
wr_nvrd =$13 ;NVRAM data port
;NXP26C92 DUAL ACIA DEFINITIONS
nc_c92a =2 ;number of channels
nr_c92a =8 ;registers per channel
nr_26c92 =nr_c92a*nc_c92a ;total registers
dr_mra =%0000 ;ch A mode select...
; xxxx0xxx ——> mode 0 settings
; |||| +++———> baud rate extend: 000: normal
; |||| 001: extended mode 1
; |||| 100: extended mode 2
; ||++———————> TxD FIFO IRQ level: 00: 8
; || 01: 4
; || 10: 6
; || 11: 1
; |+—————————> RxD FIFO IRQ level: 0: 1-5: see also MR1:6
; | 1: 6-8: see also MR1:6
; +——————————> RxD watchdog: 0: disable
; 1: enable
; xxxxxxxx ——> MR1 settings
; ||||||++———> data format: 00: 5 bit
; |||||| 01: 6 bit
; |||||| 10: 7 bit
; |||||| 11: 8 bit*
; |||||+—————> parity type: 0: even*
; ||||| 1: odd
; |||++——————> parity mode: 00: check
; ||| 01: force
; ||| 10: don't check*
; ||| 11: multidrop
; ||+————————> error mode: 0: character*
; || 1: block
; |+—————————> RxD IRQ mode: 0: RxD ready*
; | 1: FIFO full
; +——————————> RxD RTS mode: 0: off
; 1: on*
; * = default setting
; xxxxxxxx ——> mode 2 settings
; ||||++++———> stop bit length
; |||+———————> TxD CTS mode: 0: off
; ||| 1: on
; ||+————————> TxD RTS mode: 0: off
; || 1: on
; ++—————————> channel mode: 00: normal
; 01: auto echo
; 10: local loop
; 11: remote loop
dr_sra =%0001 ;ch A status (R)...
; xxxxxxxx
; |||||||+———> 1: RxD FIFO not empty
; ||||||+————> 1: RxD FIFO full
; |||||+—————> 1: TxD FIFO not empty
; ||||+——————> 1: TxD FIFO empty
; |||+———————> 1: RxD overrun
; ||+————————> 1: parity error
; |+—————————> 1: framing error
; +——————————> 1: break received
dr_csra =dr_sra ;ch A clock select (W)...
; xxxxxxxx
; ||||++++———> TxD baud rate & BRG source
; ++++———————> RxD baud rate & BRG source
dr_cra =%0010 ;ch A command (W)...
; xxxxxxxx
; ||||||++———> 00: no operation
; |||||| 01: enable receiver
; |||||| 10: disable receiver
; |||||| 11: illegal operation
; ||||++—————> 00: no operation
; |||| 01: enable transmitter
; |||| 10: disable transmitter
; |||| 11: illegal operation
; ++++———————> 0000: no operation
; 0001: select MR1
; 0010: reset & disable receiver
; 0011: reset & disable transmitter
; 0100: reset error status
; 0101: reset break IRQ
; 0110: start TxD break
; 0111: stop TxD break
; 1000: assert RTS
; 1001: deassert RTS
; 1010: enable C/T timeout mode
; 1011: select MR0
; 1100: disable C/T timeout mode
; 1101: undefined
; 1110: standby power mode
; 1111: normal power mode
dr_rhra =%0011 ;ch A RxD FIFO (R)
dr_thra =dr_rhra ;ch A TxD FIFO (W)
dr_ipcr =%0100 ;input port change (R)
dr_acr =dr_ipcr ;auxiliary control register (W)...
; xxxxxxxx
; |||||||+———> 1: enable IP0 IRQ
; ||||||+————> 1: enable IP1 IRQ
; |||||+—————> 1: enable IP2 IRQ
; ||||+——————> 1: enable IP3 IRQ
; |+++———————> C/T setup:
; | 654 Mode Source
; | 000 counter IP2
; | 001 counter TxD Ch 1 1X clock
; | 010 counter TxD Ch 2 1X clock
; | 011 counter Xtal/16
; | 100 timer IP2
; | 101 timer IP2/16
; | 110 timer Xtal
; | 111 timer Xtal/16
; +——————————> 0: select BRG set #1 (38.4k max)
; 1: select BRG set #2 (19.2k max)
dr_imr =%0101 ;interrupt enable mask (W)...
; xxxxxxxx
; |||||||+———> 1: enable ch A THR ready
; ||||||+————> 1: enable ch A RHR ready/FIFO full
; |||||+—————> 1: enable ch A change in break
; ||||+——————> 1: enable C/T ready
; |||+———————> 1: enable ch B THR ready
; ||+————————> 1: enable ch B RHR ready/FIFO full
; |+—————————> 1: enable ch B change in break
; +——————————> 1: enable IP0-IP3 state change
dr_isr =dr_imr ;interrupt status (R)...
; xxxxxxxx
; |||||||+———> 1: ch A THR ready
; ||||||+————> 1: ch A RHR ready/FIFO full
; |||||+—————> 1: ch A change in break
; ||||+——————> 1: C/T ready
; |||+———————> 1: ch B THR ready
; ||+————————> 1: ch B RHR ready/FIFO full
; |+—————————> 1: ch B change in break
; +——————————> 1: IP0-IP3 state change
dr_crur =%0110 ;C/T MSB preset (W)
dr_crlr =%0111 ;C/T LSB preset (W)
dr_ctu =dr_crur ;C/T MSB value (R)
dr_ctl =dr_crlr ;C/T LSB value (R)
dr_mrb =%1000 ;ch B mode select...
; xxxx0000 ——> MR0 settings
; || 01: 4
; || 10: 6
; || 11: 1
; |||||| 01: 6 bit
; |||||| 10: 7 bit
; |||||| 11: 8 bit*
; ||||| 1: odd
; ||| 01: force
; ||| 11: multidrop
; || 1: block
; | 1: FIFO full
; 1: on*
; xxxxxxxx ——> MR2 settings
; ||| 1: on
; || 1: on
; 01: auto echo
; 10: local loop
; 11: remote loop
dr_srb =%1001 ;ch B status (R)...
; xxxxxxxx
dr_csrb =dr_srb ;ch B clock select (W)...
; xxxxxxxx
dr_crb =%1010 ;ch B command (W)...
; xxxxxxxx
; 0001: select MR1
; 1000: assert RTS
; 1011: select MR0
; 1101: undefined
; 1110: undefined
; 1111: undefined
dr_rhrb =%1011 ;ch B RxD holding (R)
dr_thrb =dr_rhrb ;ch B TxD holding (W)
dr_usrdf =%1100 ;user-defined (R/W)
dr_opcr =%1101 ;output port configuration (W)
dr_ipsr =dr_opcr ;input port status (R)
dr_sctc =%1110 ;start C/T command (R)
dr_sopbc =dr_sctc ;set output port bits command (W)
dr_rctc =%1111 ;stop C/T command (R)
dr_ropbc =dr_rctc ;reset output port bits command (W)
.end
Last edited by BigDumbDinosaur on Fri Apr 08, 2022 12:58 pm, edited 2 times in total.
8BIT wrote:
I looked at you 65SPI and it looks like a nice device. Do you have any plans to convert the code to something else like VHDL? Not that I don't want to support you efforts by buying from you - but I would like to keep the chip count down - possibly buy incorporating it into a bigger chip.
/norby
Says 5.3 V max.
Says 5.3 V max.
I have incorporated all you suggestions into my schematic. I think I have reached a point where I don't what to change anything... at least for this version of the SBC.
Comments are welcome.
/norby
- BigDumbDinosaur
norby wrote:
Again thank you for all the clearifications, you seem to have spend quite some energy on this chip
- I see two Ø2 connections attached to the CPLD. The one at the GCLK1 input (pin 83) makes sense, as your flops and state machines would be clocked from that input. What's the purpose of the Ø2 connection at the IO3 input (pin 20)?
- You have ABORT and BE on the 65C816 sharing a common pullup resistor. I'm not aware of any adverse effects that such an arrangement might cause, but it does prevent those inputs from being used for their intended purposes. If you can spare the room, I suggest separating the two (take a look at resistor networks in SIPP form to conserve PCB space) and connecting ABORT to an unused CPLD input so you can experiment with it.
- What is the function of IC20P?
- I really don't recommend the use of the MAX3232 in your application. That device was developed to implement serial transceiver functions where economy of power consumption is paramount. Maxim sacrificed drive strength and noise immunity to minimize power consumption. You will be powering your unit from a PC type power supply, so the value of the MAX3232 in your application is zilch.
The MAX238 is a better choice, as its charge pump circuit produces a more robust output, which makes it do a better job of driving the serial link. Plus you get support for both serial channels in a single package, will consume less board real estate (fewer capacitors) and as a bonus, a single MAX238 costs less that two MAX3232s. Order Maxim part number MAX238CWG+ for the SOIC24 version or MAX238CNG+ for the PDIP24 package. Pinout is the same for both devices. - In some cases, TIA-232 devices may required that their DSR inputs be asserted as a condition of establishing communication. You can take care of this by providing a DTR output from your serial hardware. Make the connection at the MAXxxx V+ pin. See attached.
- Resistors that drive LEDs from Vcc should probably be 470 ohms. The value you selected drives most LEDs harder than necessary.
Hi Nobrby,
nice design. I see that you use a CF Card as mass storage. As I'm currently fighting with interfacing the W65C816 to the CF Card, I wanted to let you know my findings. First if you are using True IDE mode (PIN9 to ground) then you can not hot-swap the compact flash, because a newly inserted card will not be set to True IDE mode (when it powers up it will see Pin9 floating before it is fully inserted). You need to power-cycle the card. So either you add high-side switch (or as I use a AO3401) or a switch to power cycle the the CF Card. To not reset the CPU when you power-cycle the CF Card you must make sure that you separate the /RES of the CF Card from the reset line, e.g. by using a dedicated output of the reset circuitry.
Also it seems compact flash cards are very sensitive to address hold time form /IORD and /IOWR going high and in True IDE Mode the address consists not only of A0, A1, A2. /CS0 and /CS1 (Pin7 and Pin 32) are considered as as well as part of the address. When using a fast CPLD (or GAL in my case) /CS0 is de-asserted to soon (at least for the CF Cards I'm currently testing with) you need to "stretch" it or delay de-assertion. Also as during the read and write buffer the CF Card "counts" the number of /IORD and /IOWR pulses. You should pay attention that there are no glitches or extra /IORD or /IOWR. In may case I had to use a dedicated circuit that generates /IOWR and /IORD only when the CF Card is selected.
I have also a question. Are you using Eagle as CAD? And yes where did you get the library for the 65Cxxx devices from? I would really need them to finally properly document my systems.
Peter
Peter
I really don't recommend the use of the MAX3232 in your application. <snip a lot of good points....
snip>
During my own review I encountered one thing that I hope you can shed some light on. Currently I have the direction pin on the 74ABT245 (IC5) connected to the /WE output from the CPLD. Would it be better/mandatory to connect it directly to the R/W pin from the CPU?
As always input is welcome!
Attached it the latest version of the schematic.
/norby
cbscpe wrote:
Hi Nobrby,
Peter
Peter
Thank you for you input. I do intend to run it in TrueIDE mode 8bit, but hotswapping is not on the agenda so I think I can live with the limitations you descibed.
I'm very interested in your input to weather this will work or not. Actually I kinda threw the CF card design in there after reading your posts about the subject. Input that will make this design actually work is very welcome.
I'm using eaglecad and I couldn't find a WDC library so I made it myself. It is attached here, but please check it berfor using and please report back errors to me!
If there is something in the lib you need let me know I and can add it.
/norby
- Attachments
- 0EN_WDC.zip
- (7.19 KiB) Downloaded 108 times
Thanks for uploading the Eagle library. I have also made my own EAGLE CAD library for the IC’s I needed.
• 65SPI PLCC
• MAX3100 DIP
• SC26C92 PLCC
• W65C02S DIP
• W65C22S DIP
• W65C51N DIP
• W65C816S DIP
At least there are a few which are not in your library, so perhaps it is helpful.
• 65SPI PLCC
• MAX3100 DIP
• SC26C92 PLCC
• W65C02S DIP
• W65C22S DIP
• W65C51N DIP
• W65C816S DIP
- Attachments
- _My_Parts03.zip
- (7.27 KiB) Downloaded 112 times
Marco
Hi norby
Thanks for the library. I will soon start to draw the schematic and will let you know how it works.
As for the CF Card Interface it works. In fact I got it working approx. one hour before my first post to this thread. I use the following schematic The /DISK signal is only asserted for a small 16-byte IO Window. The decoder (a 7ns GAL) only uses address lines and VDA to create the /DISK signal without using PHI2 etc. This same signal goes to /CS0 of the CF-Card. /IOWR and IORD are qualified via PHI2. So they are asserted only during PHI2 High-phase and de-asserted before the decoder de-asserts /DISK. Basic read/write sector routines already work with a CPU Clock of 4MHz. Higher clock speed should be possible. Currently I'm writing the bootloader for the OS.
Regards
Peter
Regards
Peter
- BigDumbDinosaur
Incidentally, I see some connections on the '245 and your '573 bank latch that don't seem to go anywhere.
I connected the /Q of the clock flip flop to GCLK2 of the CPLD, for lack of a better name I called it /PHI2.
I also changed the DIR pin of the '245 to use the MPU's R/W signal directly.
I have attached sheet 1 which is the only one that has been updated this time.
/norby
cbscpe wrote:
Hi norby
Regards
Peter
Regards
Peter
I'm looking forward to your schematic.
/norby
