BillO wrote:
But I'm really not condoning using TTL in CMOS environments.
You and I are on the same page if your point is that there's a degree of compromise when TTL outputs drive CMOS inputs (other than those such as 'HCT series inputs). Trouble may result... Or not, depending on your luck
BillO wrote:
What I'm really trying to say is those CMOS RAM, ROM and PLD devices we use (and only get TTL load specs for) will do fine in CMOS environments and we need to stop taking those TTL environment specs so seriously because that is just no longer the reality.
upthread, BillO wrote:
4) Basically 100% of CMOS devices have the nice, simple stacked MOSFET outputs we are all familiar with. They all work the same.
It's not all across the board. For example, 74AC Series logic and similar products do still feature rail-to-rail output voltage swings (and the specs reflect this). But modern 5 volt LSI devices such as RAMs and CPLDs typically do not. I have a couple of theories on why that might be, but I'm not an expert and I'll save those details for another time. But for economic reasons the industry is tending toward smaller process geometries, and with those come lower operating voltages.
Again and again in this thread we're asking ourselves how conservative the specs are.
- We know TTL chips typically exceed their output specs, and that one can (with a compromise, as noted) feed a TTL output to a CMOS input.
- you seem to be saying that we're safe in assuming that CMOS chips exceed the TTL spec even more, based on their simple stacked MOSFET outputs.
This is not CMOS like we had in the old days. So, correct me please if I've mistaken your point, but if you're saying that any CMOS chip is automatically OK voltage-level-wise to drive other CMOS, I can't agree. There's definitely been a change since you & I entered the biz. These new-fangled, so-called "CMOS" outputs on 5V-powered LSI devices do still manage to produce levels that conform to TTL spec. But we can't assume that they exceed the spec by a greater margin simply because of the device's CMOS-ness!
