It is currently Fri Nov 01, 2024 3:42 am
Post new topic Reply to topic  [ 155 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
PostPosted: Sun Oct 21, 2012 7:08 am
You could make a test pattern with wide alternating bars at the top, say 64 pixels of each color, followed by rows with 32 pixel bars, all the way down to single pixel alternating at the bottom.
PostPosted: Sun Oct 21, 2012 1:05 pm
This may be abit off-topic, but have you ever seen the ORSOC Graphics Accelerator @opencores.org? Looks very impressive, says it is to be used with another VGA/LCD core for RGB output. I'm currently looking it over...
PostPosted: Sun Oct 21, 2012 1:22 pm
Haven't seen it before, but it looks impressive, both in the features as in size.
PostPosted: Sun Oct 21, 2012 9:07 pm
Yes, I see it takes 10,000 slice LUTs and was made for a XC6SLX45 on the Digilent Atlys board. This 320-pin Spartan 6 that Digilent uses, is the smallest BGA package version of the XC6SLX45 (27,288 slice LUTs). Our little XC6SLX9 only has 5720.
But it still may be a design worth referring to, and removing some extras in order to take advantage of the overall design of triangle plotting. Too much may have to be removed though, because it must work in unison with the VGA_LCD core previously mentioned, and this would take even more space in the FPGA. Not to mention the CPU core.
May be best to stay on course with humble beginnings, but with an eye towards what can be achieved...
I thought I'd mention an article I happened across today, a very recent article dated June 4, 2012 regarding the 'ORGFXSoC' effort is here.
And here on ProjectVGA.
PostPosted: Mon Oct 22, 2012 12:43 pm
And another similar project, although it uses a Spartan 3, called openVGA with verilog HDL available on sourceforge. Associated homepage is here.
EDIT: Tomorrow, I need to do some reading on the 'VGA/LCD Core v2.0 Specifications'. It has info I need to learn about video bandwidth...
PostPosted: Tue Oct 23, 2012 3:59 pm
Such a struggle, but I finally made a successful test to alternate black and white pixels straight from the FPGA to the videoDAC. So far I just tested 320x200 resolution. I don't see anything out of order. I've attached the zipped ISE 13.4 project file.
module VDACif( input clk108,
               input hstart,
               input vstart,
               input hblank,
               output reg [4:0] Red_data,
               output reg [5:0] Green_data,
               output reg [4:0] Blue_data,
               output reg DACBLANKn = 1
reg countflag;
reg [8:0] Hcount;
reg [7:0] Vcount;
always @(posedge clk108)
      if ( !hblank )
         Hcount <= Hcount + 1;
      else if ( hblank )
         Hcount <= 0;
      if ( hstart )
         countflag <= 1;   //countflag active in display area
      else if ( hblank )
         countflag <= 0;
   if ( countflag )
      begin
         Red_data <= hblank ? 0 :
               Hcount[0] ? 0 :
               5'b11111;
         Green_data <= hblank ? 0 :
                 Hcount[0] ? 0 :
                 6'b111111;
         Blue_data <= hblank ? 0 :
                Hcount[0] ? 0 :
                5'b11111;
   end
endmodule
EDIT: Seeing a moire pattern side effect at 1280x1024 resolution. Also, 320x200 not such a square pixel. Might have to go for 320x240 as a lower resolution.
PVBSSOtest.zip [1.07 MiB]
Downloaded 72 times
PostPosted: Tue Oct 23, 2012 6:03 pm
Now try a blue border around the pattern.
PostPosted: Tue Oct 23, 2012 7:01 pm
I tried my best, but it doesn't work for some reason. My brain is burnt, so I am pretty much done for today, but here is my code. I took your previous advice and divided up the RGB signals for manipulation. There is no difference in the output, still alt black/white pixels w/black borders:
               input hstart,
               input vstart,
               input hblank,
reg countflag;
reg [8:0] Hcount;
reg [7:0] Vcount;
      if ( !hblank )
      else if ( hblank )
         Hcount <= 0;
      if ( hstart )
      else if ( hblank )
         countflag <= 0;
   if ( countflag )
                     Hcount[0] ? 0 :
                     5'b11111;
   else if ( hblank )
         Red_data <= 0;
   if ( countflag )
                       Hcount[0] ? 0 :
                       6'b111111;
   else if ( hblank )
         Green_data <= 0;
   if ( countflag )
                      Hcount[0] ? 0 :
                      5'b11111;
   else if ( hblank )
         Blue_data <= 5'b11111;
endmodule
EDIT: 1 SEC I think I see my prob. I must remove the hblank MUX now that it is defined by the else-if statements...
PostPosted: Tue Oct 23, 2012 7:22 pm
Try running a simulation. It will show you the timing diagrams, and then it should be easier to understand what's going wrong. But this is tricky stuff. I still remember the first designs I made. It took days before it finally worked, and then I looked at the design and wondered why it took so long to write 50 lines :)
PostPosted: Tue Oct 23, 2012 7:32 pm
Ok, I fixed my code to the following which seems like it should work but it still has the same action:
               input hstart,
               input vstart,
               input hblank,
reg countflag;
reg [8:0] Hcount;
reg [7:0] Vcount;
      if ( !hblank )
      else if ( hblank )
         Hcount <= 0;
      if ( hstart )
      else if ( hblank )
         countflag <= 0;
   if ( countflag )
         Red_data <= Hcount[0] ? 0 :
                     5'b11111;
   else if ( hblank )
         Red_data <= 0;
   if ( countflag )
         Green_data <= Hcount[0] ? 0 :
                       6'b111111;
   else if ( hblank )
         Green_data <= 0;
   if ( countflag )
         Blue_data <= Hcount[0] ? 0 :
                      5'b11111;
   else if ( hblank )
endmodule
Sim's on these video circuits are so long... I will continue tomorrow.
PostPosted: Tue Oct 23, 2012 7:39 pm
What I usually do is make the screen size smaller in simulation. Say 32x20 pixels, and then it won't take so long. Also, initialize the counters so that you're just above the visible part of the screen, so you don't have to wait for the blanking intervals.
PostPosted: Tue Oct 23, 2012 8:01 pm
What I usually do is make the screen size smaller in simulation. Say 32x20 pixels, and then it won't take so long...
Excellent advice, thanks!
PostPosted: Wed Oct 24, 2012 5:51 pm
Well this was the best I could do without help:
               input hstart,
               input vstart,
               input hblank,
               input vblank,
               output reg [4:0] Red_data = 0,
               output reg [5:0] Green_data = 0,
               output reg [4:0] Blue_data = 0,
reg countflag;
reg Alt;                                    //
      if ( hstart )
      else if ( hblank | vblank )
         countflag <= 0;
always @(posedge clk108)                  //Alternate on-off pixel value
   //if ( countflag )
      Alt <= ~Alt;
always @(posedge clk108)                  //outgoing data to videoDAC
      if ( countflag ) begin
         if ( Alt ) begin                               //white pixel
            Red_data <= 5'b11111;
            Green_data <= 6'b111111;
         end
            else begin                            //black pixel
               Red_data <= 0;
               Green_data <= 0;
               Blue_data <= 0;
            end
      end
      else if ( vblank | hblank ) begin               //border
            Red_data <= 0;
            Green_data <= 0;
         end
endmodule
And the result:
PostPosted: Wed Oct 24, 2012 6:09 pm
Instead of picking colors based on countflag and hblank/vblank, you could make a x/y counter.
Restart x = 0 at htstart, and increment x when countflag = 1. If you get it right, x should go from 0 to 639 (for normal VGA). Then, you can select a pixel color based on x value.
PostPosted: Wed Oct 24, 2012 6:59 pm
Counters, yes I started with counters earlier. So I modified my code and have this now, with same action in previous pic:
               input hstart,
               input vstart,
               input hblank,
               input vblank,
reg countflag;
reg [8:0] X = 0;
reg [7:0] Y = 0;
      if ( hstart )
         countflag <= 0;
   if ( countflag )
      X <= X + 1;
      else
         X <= 0;
         Red_data <= 0;
         Green_data <= 0;
      end
         else if ( X[0] ) begin
         end
            else begin
               Red_data <= 0;
               Green_data <= 0;
               Blue_data <= 0;
            end
endmodule
Much easier to see in sim now I can see the X counter, it is resetting properly...
Now that nasty retrace going across the back of the screen, how do we get rid of it? Is it possible for a different colored border without using the videoDAC DACBLANK signal? or will we be forced to use black borders?
EDIT: video is presently 320x200.
