MCP120 vs DS1813
EugeneNine
MCP120 vs DS1813
Post by EugeneNine »
Re: MCP120 vs DS1813
EugeneNine wrote:
The DS1813 does everything that the MCP130 does, plus responds to the reset line being grounded, which it appears the MCP130 can't do. In other words, if you ground the /RESET output of the DS1813 it will go through the full reset sequence, same as what happens at power on. Hence you can hook up a push button to /RESET and you will get a clean reset no matter how much contact bounce occurs. The MC(130 doesn't appear to have that capability.
floobydust
Post by floobydust »
In general they are fairly similar, sans the reset time (150ms vs 350ms) and apparent lack of adding a reset switch. As I'm also looking at some other I/O devices which have a active high reset, I'm now looking at the TI TL7705A. It has both active high and low open collector outputs and is a bit more flexible but does require a few additional parts. It's also less expensive listed for $0.74 at Mouser.
http://www.mouser.com/ProductDetail/Tex ... TL7705ACP/
