It is currently Thu Nov 21, 2024 1:22 pm
 Post subject: MCP120 vs DS1813
PostPosted: Tue Jan 03, 2017 2:23 am
Anyone used the Microchip MCP130 for reset? http://www.microchip.com/wwwproducts/en/MCP130
Prices are about ~.50 where the DS1813 is about $2.50
http://www.mouser.com/ProductDetail/Max ... pUOPq17hJ0
http://www.mouser.com/All-Manufacturers ... 30&FS=True
 Post subject: Re: MCP120 vs DS1813
PostPosted: Tue Jan 03, 2017 2:44 am
EugeneNine wrote:
The DS1813 does everything that the MCP130 does, plus responds to the reset line being grounded, which it appears the MCP130 can't do. In other words, if you ground the /RESET output of the DS1813 it will go through the full reset sequence, same as what happens at power on. Hence you can hook up a push button to /RESET and you will get a clean reset no matter how much contact bounce occurs. The MC(130 doesn't appear to have that capability.
PostPosted: Tue Jan 03, 2017 3:21 am
In general they are fairly similar, sans the reset time (150ms vs 350ms) and apparent lack of adding a reset switch. As I'm also looking at some other I/O devices which have a active high reset, I'm now looking at the TI TL7705A. It has both active high and low open collector outputs and is a bit more flexible but does require a few additional parts. It's also less expensive listed for $0.74 at Mouser.
http://www.mouser.com/ProductDetail/Tex ... TL7705ACP/
