Breaking 6502 apart
org
Re: Breaking 6502 apart
Post by org »
I still can't fully understand execution order :)
In top part I have problems with flags input/outputs (still dont know what to do first - input flags from databus, or output current flag values)
In bottom part I have bunch of control lines which can lead to bus conflicts, for example :
If X/SB and Y/SB are become asserted at same time they encounter bus conflict (X and Y are put on SB at same time).
6502 addict
Ah, yes, outside of normal operation there could be bus conflicts - the undefined opcodes may do this - and you'll most likely get either an AND or an OR of the various writers.
org
Post by org »
I will apply "ground wins" rule :)
BTW, I updated PSD sources too : http://breaknes.com/files/6502/6502.zip [150 MB]
6502 addict
org
Post by org »
NMI pad logic
Transistor schematics:
6502.org wrote:
Image no longer available: http://breaknes.com/files/6502/NMI_PAD0.jpg
Logic circuit:
6502.org wrote:
Image no longer available: http://breaknes.com/files/6502/NMI_PAD1.jpg
After removing inverters it turned out to be D flip/flop :D
6502.org wrote:
Image no longer available: http://breaknes.com/files/6502/NMI_PAD2.jpg
6502 addict
org
Post by org »
- Complete decoder labels
- Fixed names for /T0, /T1X and T1 lines
Latest version here : http://breaknes.com/files/6502/6502.jpg
6502 addict
One small point - for a transparent latch, I've seen a symbol used where the clock input is marked with a half- square, instead of a triangle. The triangle means it's an edge-triggered flop.
zellyn
Post by zellyn »
The triangle looks like half a square to me... :-p
Funny!
org
Post by org »
Thanks, didn't know this detail )
Those D-triggers are implemented as floating gate transistors. And its level-triggered of course. Is there any better way to represent it as logic block ?
6502 addict
Like this, then? Up until now I've just used "LE" to label such an input, but a symbol would be preferable.
That's exactly what I've seen before, thanks Jeff. I couldn't find it though. What I did find was the idea of using a plain input called "E" instead of a triangle-marked input.
Ditto on both points! -- I did a search and found the "E" suggestion but not the symbol. So, I drew one myself. Glad you like it! :D
org
Post by org »
Fixed) I found "custom element" in circuitlab and made "E" input.
6502 addict
