I think Ben's approach knowingly takes a number of compromises which are all about making computer construction accessible and simple. Some people miss the point of that!
Excellent point Ed, thank you.
While pondering this over, I feel like I asked this question once before. So I tried some experiments on my own Acolyte board just now.
1) MCP130 (or DS1813), has internal 5K pull-up. Works upon power up and reset.
2) MCP130 + 10K pull-up = 3.3K pull-up total. Works upon power up and reset.
3) Only 10K pull-up. Power up freaks out the system, but reset works as expected.
4) MCP130 + 1K pull-up = 830 ohm pull-up total. Works upon power up and reset.
5) Only 1K pull-up. Power up freaks out the system, but reset works as expected.
Perhaps if you have sensitive data, or ways that would actually erase data and/or damage the computer if the wrong subroutine was run, then use a supervisory circuit such as the MCP130 or DS1813. If it's just for 'hobby', as you said Ed, then a simple pull-up would probably be fine as long as you are also expected to press the reset button AFTER powering up.
Any other info on this RESB line is welcome, thank you!
