Voltage and Current
Voltage and Current
Hello everyone!
I feel like my question deserves to be here in the Newbie section. I don't mind that, I am still new to all of this.
Been trying to configure my new color scheme for VGA output. Nothing new there for me. I use resistors to bring 5V down to a range of 0V to 0.7V, super straight forward.
What I never considered was the current. I am using falstad.com for simulation purposes, and I'm seeing that even my most basic circuit to display a white color is taking around 25mA. All of this coming from a single 74HC166. Here is a link to the datasheet, https://assets.nexperia.com/documents/d ... HCT166.pdf. According to the datasheet (if I'm reading this correctly) it is only able to supply 25mA of output current. Is this correct?
So then, I'm barely within margin! That is not good.
My new planned configuration that is more complicated and using diodes seems to take around 40mA. If I am understanding all of this correctly, then that would not work at all. Right? Not just to a monitor, but what in general are the effects of not having enough amps to power something? Sporadic behavior? "Always off"?
Likewise that would be 40mA going through a 1N914 diode. I see on it's datasheet that it is rated up to 200mA, I think, so this shouldn't be a problem, correct? If I am pushing margins on current supplied to a diode, would it just get hot? Could it explode?
I am not an electrical engineer, obviously. This is 101 material for most of you. Any help and clarification is much appreciated.
Thank you everyone!
Thank you everyone!
Re: Voltage and Current
Hi Chad,
Can you post a schematic of your "resistor" and your "diode" versions of your circuit? The monitor has 75 Ohm resistors to ground on the signal lines, so to get 0.7V you shouldn't be sending more than about 9mA into the monitor on any given signal line.
-SamCoVT
-SamCoVT
Sure!
Here is my falstad.com link, for the white output using only resistors:
http://falstad.com/circuit/circuitjs.ht ... irUc4yS2EA
Attached is a picture of my 'diode' setup. I ran that through falstad.com as well, but I didn't save a link.
Thank you!
EDIT: I realize that I don't have resistor values on that picture. I found some configuration to make it work, but again it was showing 40mA of current usage on falstad.
Thank you!
- Attachments
- DiodeSetup.png (9.71 KiB) Viewed 2062 times
25mA is the absolute maximum for that chip. It probably won't last very long at that kind of current out.
What is the frequency of the output? You could probably use a 2N2222 in an emitter follower configuration to amplify the current.
I went looking at the 2N2222 (datasheet here https://media.digikey.com/pdf/Data%20Sh ... itches.pdf)
I am ALL thrilled to be able to use transistors, in particular a common 2N2222 would be fantastic! But, seeing the datasheet, it has a 'rise time' of 25ns and a 'fall time' of 60ns. I do not know exactly what that means in my situation, is that 'switching speed'? What is the highest frequency a 2N2222 can go?
Thank you.
sburrow wrote:
Sure!
For your dioded version, having values on your schematic (even if you aren't sure if they are right) will allow a more thorough analysis. It looks like PIX1 and PIX2 will have to source a bit more current if PALLETE is low, but you should be looking at the branch currents rather than the total from the supply because that's what the IC driving that line will have to source (or sink, in the case of PALLETE with the diodes).
-SamCoVT
SamCoVT wrote:
That simulation is helpful as it shows the resistor values (470 Ohms series resistor on each line). In that simulation, I see the TOTAL current from the 5V supply in your simple simulation is about 25mA, however the 74HC166 will only be driving one of the three paths (eg. you will need one '166 for PIX1, another for PIX2, and a third for PALLETE (unless you want to use something simpler like a latch to control the pallete).
In your simulation, you can see there is only 9.2mA going down a particular branch, and that's what the '166 will be sourcing for current (probably a tiny bit less, if you were to measure). That is comfortably within the limits of the part.
-SamCoVT
-SamCoVT
I can redo the falstad simulation for the diodes, but I really like BillO's suggestion to use transistors. I was looking online and some folks are saying the 2N2222 will go like 500 MHz or something crazy. Still, I didn't see that in the datasheet (though I don't think I looked terribly well either).
Thank you Sam!
Here is the link to the diode version in falstad.
http://falstad.com/circuit/circuitjs.ht ... vi3uxBWFAA
I turned off PIX2 and PALETTE, so that makes PIX1 needing to drive 45mA! I can adjust the resistor values some to minimize this, but then that affects my intended colors which I'm hoping to not do.
Those rise and fall times are ~ 0V-30V. If you just going 0V-1V the rise and fall times are going to be much quicker. It should do fairly well at 26MHz driving the base @ ~15mA.
Let me do a test and get back to you.
Thank you!
EDIT: Here (https://www.etechnophiles.com/2n2222-tr ... ent-specs/) it says that the operating frequency is 250 MHz. I just don't understand why the datasheet would have those values? I feel like I'm missing something in one way or another.
- GARTHWILSON
- Forum Moderator
Well, here it is and it's not very promising.
This trace is using the 2N2222. The input signal (yellow) is 27MHz @ 5V p-p and the output is 2.5v p-p into 47 ohms. Base is being driven through 360 ohms.
This trace is using a 2N3904. A tad better with an output of 3V p-p.
A better transistor will be needed to get closer to your goal.
- GARTHWILSON
- Forum Moderator
What's the transistor circuit? And wouldn't it need to do a squarish wave at 25MHz, meaning there will be frequency components ten times as high? It looks like it's about 55° behind at 25MHz.
But if you are saying there would be signal loss at 25 MHz, then indeed I would need a better transistor. I am sure I can handle delay, but I cannot handle signal loss.
@Garth: Yes, square wave. So are you saying it could only operate at 2.5 MHz with a square wave?
However, I did try running the signal through a 74HCT14 too, but the result was no better (worse, actually). So I'm not sure his 74HCT166 is producing perfect square waves either.
The 6ns delay is in line with the spec sheet for the 2N2222. It quotes a max delay of 10ns.
