Great job Bill! Looks great!
from PIL import Image
im = Image.open("finch-indexed.png")
with open("finch-indexed.img", "wb") as f:
f.write(im.tobytes())
f.close()
im = Image.open("finch-640x480x3bpp.png")
print(im.size)
print(im.getpalette())
reddata = []
greenbluedata = []
def pack(bit,*v):
r = 0
for x in v:
r <<= 1
if x & bit:
r += 1
return r
for y in range(im.height):
for x in range(0, im.width, 4):
v0 = im.getpixel((x,y))
v1 = im.getpixel((x+1,y))
v2 = im.getpixel((x+2,y))
v3 = im.getpixel((x+3,y))
r = pack(1, v0, v1, v2, v3)
g = pack(2, v0, v1, v2, v3)
b = pack(4, v0, v1, v2, v3)
reddata.append(r)
greenbluedata.append((g << 4) + b)
print(len(reddata), len(greenbluedata))
with open("imgfinch.dat", "wb") as fp:
fp.write(bytes(reversed(greenbluedata)))
fp.write(bytes(reversed(reddata)))
fp.close()
from PIL import ImagePalette
# Create a palette that matches what the hardware does
palette = []
for v in range(16):
base = 0
mag = 160
if v>=8:
base += 255-mag
r = base + mag * ((v>>2)&1)
g = base + mag * ((v>>1)&1)
b = base + mag * ((v>>0)&1)
palette.extend((r,g,b))
# Make a copy of the palette with some bias towards 0x80, so that the quantization works better
palettedata = []
bias = 12
for v in range(16):
r,g,b = palette[3*v:3*(v+1)]
r = bias + (r * (0xff-2*bias)) // 0xff
g = bias + (g * (0xff-2*bias)) // 0xff
b = bias + (b * (0xff-2*bias)) // 0xff
palettedata.extend((r,g,b))
# PIL requires 256-colour palettes
palettedata.extend([0] * (768-len(palettedata)))
# PIL has a quirky API that requires us to wrap an image around the palette in order to use it
palimage = Image.new("P", (1,1))
palimage.putpalette(palettedata)
im = Image.open("finch.jpg")
im2 = im.resize((160,100)).quantize("P", palette=palimage, kmeans=10)
im2.save("finch2.png")
# Save out a scaled-up version of the palettized image so that it's easier to see for debugging
scale = 8
im3 = Image.new("RGB", (im2.width*scale,im2.height*scale))
for y in range(im2.height):
for x in range(im2.width):
v = im2.getpixel((x,y)) & 15
for v in range(16):
for xx in range(scale):
for yy in range(scale):
im3.putpixel((x*scale+xx,y*scale+yy),(r,g,b))
im3.save("finch3.png")
# Save out the binary data
with open("finch.img", "wb") as f:
f.write(im2.tobytes())
f.close()
