I did it in a simple minded way, I'm sure there is an elegant way using loops to do the 1,3,5,7,etc as two loops with i=0to 3 and j=0 to i except for the last 2 rows of 3. I just couldn't get my head around the logic in the time available. No excuse now though!
Nowhere near 40 or 50 bytes though at 153 bytes.
Edit: Sorry I added the attachment before I figured out how to include code with keeping the formatting.
CRCMon ver 0.8eps2w 12/07/21
> boot applications
1--EhBASIC,
2--Memory Diag,
3--CRCFig-Forth,
4--Secnd9-Forth 3 press Return to execute command
CRC65 FIG-FORTH SYM 2021
3 load OK
words DUMP HEXOUT NYBOUT ?ASCII WORDS FREE DUMPBLK 2/ 2* >> << J T.S .S P REPLACE-LINE -MOVE LINE TEXT MON VLIST TRIAD INDEX LIST ? . .R D. D.R #S # SIGN #> <# SPACES WHILE ELSE IF REPEAT AGAIN END UNTIL +LOOP LOOP DO THEN ENDIF BEGIN BACK FORGET ' R/W -BCD --> LOAD MESSAGE .LINE (LINE) BLOCK BUFFER EMPTY-BUFFERS FLUSH UPDATE +BUF PREV USE M/MOD */ */MOD MOD / /MOD * M/ M* MAX MIN DABS ABS D+- +- S->D COLD ABORT QUIT ( DEFINITIONS FORTH VOCABULARY IMMEDIATE INTERPRET ?STACK DLITERAL LITERAL [COMPILE] CREATE ID. ERROR (ABORT) -FIND NUMBER (NUMBER) UPPER WORD PAD HOLD BLANKS ERASE FILL QUERY EXPECT ." (.") -TRAILING TYPE COUNT DOES> <BUILDS ;CODE (;CODE) DECIMAL HEX SMUDGE ] [ COMPILE ?LOADING ?CSP ?PAIRS ?EXEC ?COMP ?ERROR !CSP PFA NFA CFA LFA LATEST TRAVERSE -DUP SPACE ROT > < U< = - C, , ALLOT HERE 2+ 1+ HLD R# CSP FLD DPL BASE STATE CURRENT CONTEXT OFFSET SCR OUT IN BLK VOC-LINK DP FENCE WARNING WIDTH TIB +ORIGIN B/SCR B/BUF LIMIT FIRST C/L BL 3 2 1 0 USER VARIABLE CONSTANT ; : C! ! C@ @ TOGGLE +! DUP SWAP DROP OVER DMINUS MINUS D+ + 0< 0= R R> >R LEAVE ;S RP! SP! SP@ XOR OR AND U/ U* CMOVE CR ?TERMINAL KEY EMIT ENCLOSE (FIND) DIGIT I (DO) (+LOOP) (LOOP) 0BRANCH BRANCH EXECUTE CLIT LIT OK
free
22250 Bytes available
OK
8 load OK
8 list
SCR#8
0 ( Christmas Challenge )
1 : star dup 0 do 42 emit loop ;
2 : sline dup 61 swap - 2 / dup spaces swap star spaces cr ;
3
4 : ntree cr 1 sline 3 sline 5 sline 7 sline 3 sline 7 sline
5 11 sline 15 sline 5 sline 11 sline 17 sline 23 sline
6 3 sline 3 sline ;
7
8
9
10
11
12
13
14
15
OK
ntree
OK
free
22097 Bytes available
OK
