It is currently Fri Nov 22, 2024 5:03 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Christmas Challenge
PostPosted: Mon Dec 20, 2021 4:32 pm
I'm a forth newb and a first time contest entrant but it reminded me of the example from "Starting Forth"
I did it in a simple minded way, I'm sure there is an elegant way using loops to do the 1,3,5,7,etc as two loops with i=0to 3 and j=0 to i except for the last 2 rows of 3. I just couldn't get my head around the logic in the time available. No excuse now though!
Nowhere near 40 or 50 bytes though at 153 bytes.
Edit: Sorry I added the attachment before I figured out how to include code with keeping the formatting.
CRCMon ver 0.8eps2w 12/07/21
> boot applications
1--EhBASIC,
2--Memory Diag,
3--CRCFig-Forth,
4--Secnd9-Forth 3 press Return to execute command
CRC65 FIG-FORTH SYM 2021
3 load OK
words DUMP HEXOUT NYBOUT ?ASCII WORDS FREE DUMPBLK 2/ 2* >> << J T.S .S P REPLACE-LINE -MOVE LINE TEXT MON VLIST TRIAD INDEX LIST ? . .R D. D.R #S # SIGN #> <# SPACES WHILE ELSE IF REPEAT AGAIN END UNTIL +LOOP LOOP DO THEN ENDIF BEGIN BACK FORGET ' R/W -BCD --> LOAD MESSAGE .LINE (LINE) BLOCK BUFFER EMPTY-BUFFERS FLUSH UPDATE +BUF PREV USE M/MOD */ */MOD MOD / /MOD * M/ M* MAX MIN DABS ABS D+- +- S->D COLD ABORT QUIT ( DEFINITIONS FORTH VOCABULARY IMMEDIATE INTERPRET ?STACK DLITERAL LITERAL [COMPILE] CREATE ID. ERROR (ABORT) -FIND NUMBER (NUMBER) UPPER WORD PAD HOLD BLANKS ERASE FILL  QUERY EXPECT ." (.") -TRAILING TYPE COUNT DOES> <BUILDS ;CODE (;CODE) DECIMAL HEX SMUDGE ] [ COMPILE ?LOADING ?CSP ?PAIRS ?EXEC ?COMP ?ERROR !CSP PFA NFA CFA LFA LATEST TRAVERSE -DUP SPACE ROT > < U< = - C, , ALLOT HERE 2+ 1+ HLD R# CSP FLD DPL BASE STATE CURRENT CONTEXT OFFSET SCR OUT IN BLK VOC-LINK DP FENCE WARNING WIDTH TIB +ORIGIN B/SCR B/BUF LIMIT FIRST C/L BL 3 2 1 0 USER VARIABLE CONSTANT ; : C! ! C@ @ TOGGLE +! DUP SWAP DROP OVER DMINUS MINUS D+ + 0< 0= R R> >R LEAVE ;S RP! SP! SP@ XOR OR AND U/ U* CMOVE CR ?TERMINAL KEY EMIT ENCLOSE (FIND) DIGIT I (DO) (+LOOP) (LOOP) 0BRANCH BRANCH EXECUTE CLIT LIT OK
free
22250 Bytes available
OK
8 load OK
8 list
SCR#8
 0 ( Christmas Challenge )
 1 : star dup 0 do 42 emit loop ;
 2 : sline dup 61 swap - 2 / dup spaces swap star spaces cr ;
 3
 4 : ntree cr 1 sline 3 sline 5 sline 7 sline 3 sline 7 sline
 5 11 sline 15 sline 5 sline 11 sline 17 sline 23 sline
 6 3 sline 3 sline ;
 7
 8
 9
10
11
12
13
14
15
OK
ntree
OK
free
22097 Bytes available
OK
ccontested.txt [2.36 KiB]
Downloaded 62 times
PostPosted: Mon Dec 20, 2021 5:21 pm
Applesoft one. This one comes in at 77 bytes
2 READ J: IF J THEN HTAB 20-J/2: FOR K=1 TO J: ? "*";: NEXT : ?: GOTO 2: DATA 1,3,5,7,3,7,11,15,5,11,17,23,3,3,0
ML one
with the Monitor bug is 50 bytes
without the bug is 43 bytes
 ORG  $300
 SHT
 LDY  #13
]LOOP  LDA  STARS,Y
 LSR
 EOR  #$FF
 ADC  #20
 TAX
 JSR  $F94A
 LDX  STARS,Y
 LDA  #"*"+$80
 JSR  APBUG      ; could have been a call to $F94C
 JSR  $FD8E
 DEY
 BPL  ]LOOP
 RTS
STARS  DFB  3,3,23,17,11,5,15,11,7,3,7,5,3,1
   LDA #$A0      ; this is the bug in the Monitor, where the BNE below branches here instead and forces the character to a space
APBUG   JSR $FDED
   DEX
   BNE APBUG
   RTS
PostPosted: Tue Dec 21, 2021 12:08 am
I knew I could do better. 36 'bytes' (of 16 bits each).
This one stores the run-lengths of spaces and stars in 6 bit fields, packed 5 to a 32 bit word. The runs of spaces include enough to wrap to the next line after each run of stars. There's no explicit end-of-data marker: the code follows immediately, and I've sneakily arranged that the top bit of the first 32 bit value in the code is set. So if the data is negative, we can exit the loop.
Before printing each run of characters, it switches to the other character with eor #$0a. That's an 8 bit instruction which clears the rest of the register, so the $802a loaded by the first instruction (which needed an operand with bit 15 set, so it can act as an 'end' mark when interpreted as data) becomes an 8 bit value before it's given to chrout.
The only other trick is hiding the RTS instruction in the data table. There happens to be a value of $2460 in there, and in the current version of the processor, the top 8 bits of RTS are ignored. I score points for interpreting data as code AND code as data, right?
                                 109    * = $f000
0000f000:                        110 treedata
0000f000: 0e53 2460              111    .long %100100_000011_100110_000001_010011
0000f002: 8845 0398              112    .long %000011_100010_001001_100001_000101
0000f004: 2de3 1bf1              113    .long %011011_001011_011111_000111_100011
0000f006: 784f 0d77              114    .long %001101_011110_000111_011101_001111
0000f008: 65d8 1a24              115    .long %011010_011001_010010_010011_011000
0000f00a: 4c43 0039              116    .long %000000_010011_000011_100101_000011
0000f00c:                        117 tree
0000f00c: 01a9 802a              118    ldr.w a0, #$802a
0000f00e: a4fc                   119    sub a1, a1
0000f00f:                        120 loop
0000f00f: 16b4 f000              121    ldr.l y0, treedata, a1
0000f011: 0030 00ee              122    bmi treedata+1
0000f013: 36e8                   123    inc.l a1, #2
0000f014:                        124 branches
0000f014: 30a8                   125    mov y1, y0
0000f015: 2037 003f              126    and y1, #63
0000f017: 0049 000a              127    eor a0, #$0a
0000f019:                        128 chars
0000f019: 90f0 f24e              129    bra.l chrout
0000f01b: 0488                   130    dec y1
0000f01c: 00d0 00fb              131    bne chars
0000f01e: 2242 0006              132    lsr.l y0, #6
0000f020: 00d0 00f2              133    bne branches
0000f022: 80f0 00eb              134    bra loop
PostPosted: Tue Dec 21, 2021 4:43 am
I like the one entry using the inline variable and has got my vote for the best entry. Here it is converted to Applesoft at 75 bytes.
0 ACEGCGKOEKQWCC=0: FOR I=0 TO 13: X= PEEK(2053+I)-64: FOR J=1 TO X:? TAB(20-X/2)"*";: NEXT: ?: NEXT
PostPosted: Tue Dec 21, 2021 11:44 pm
I cleaned up my code to correct some stack creep and made an attempt to be a bit more "algorythmic". Still takes 152 bytes and perhaps losing some readability but I'm not anywhere close to the smallest code even if those examples stretch my ability to comprehend what is taking place.
( PS I am having an issue with my code loading going into nether regions hence the need to stick in a deliberate error in the screen. <sigh> more debugging required! )
forget stars OK
free
21971 Bytes available
OK
29 load
21819 Bytes available
.s [0 ] OK
free
OK
29 list
SCR#29
 0 ( Christmas Challenge variable corrected )
 1 : stars 0 do 42 emit loop ;
 2 : sline dup 61 swap - 2 / dup spaces swap stars spaces cr ;
 3
 4 0 variable cl
 5 : sp cl ! 4 0 do cl @ dup 1 + i * + sline loop ;
 6 : ctree cr 1 sp 3 sp 5 sp 3 sline 3 sline ;
 7 free
 8 ; ( required to get control back ??? )
 9
10
11
12
13
14
15
OK
ctree
OK
.s [0 ] OK
PostPosted: Wed Dec 22, 2021 1:52 am
( PS I am having an issue with my code loading going into nether regions hence the need to stick in a deliberate error in the screen. <sigh> more debugging required! )[code]forget stars OK
I took the one posted code and converted it to Forth.
10 FOR X=1 TO 5: FOR Y=1 TO 4: A=X*Y: IF X>3 then A=2:Y=4
20 PRINT TAB(21-A): for z=1 to A+A-1: ?"*";: next: ?: next: next
Here is the smallest I got in Forth at 102 bytes
: t 6 1 do i 5 1 do dup dup i * swap 3 > if drop R> R> drop 1 >R >R
2 then dup 20 swap - spaces dup + 1- 0 do 42 emit loop cr loop loop ;
PostPosted: Wed Dec 22, 2021 2:27 am
Here is the another conversion to Forth from another entry comes in at 99 bytes
: IT ;
: ACEGCGKOEKQWCCC ' IT 4 + 15 1 DO 1+ DUP C@ 64 - DUP 2 / 20 SWAP - SPACES
0 DO 42 EMIT LOOP CR LOOP DROP ;
PostPosted: Wed Dec 22, 2021 4:34 am
Adapted from the above, and about a dozen bytes shorter... :P
HERE
: ACEGCGKOEKQWCCC [ LITERAL ] 15 1 DO 1+ DUP C@ 64 - DUP 2 / 20 SWAP - SPACES
PostPosted: Wed Dec 22, 2021 7:01 am
Yeah, but now try typing the word in to try to forget it. I just have to type FORGET IT. :D
PostPosted: Wed Dec 22, 2021 12:01 pm
I'm too late but my attempt comes in at 66 bytes on the C256 Foenix's 65816 using my own assembler.
cpu '65816'
org $60
const width=72
const treepattern=array(1,3,5,9,3,7,11,15,19,5,11,17,23,3,3)
PUTC             = $001018
main:
   phk
   plb
   sep #$30
   ldy #sizeof(treepattern)-1
      lda #' '
      ldx treedata,y,b
      jsr draw
      lda #'*'
      ldx tree,y,b
      jsr draw
      dey
      bpl -
   rtl
draw:
   pha
   jsl PUTC
   pla
   dex
   bne draw
   rts
var space1,space2=0
var treespace=array()
for i=0 to sizeof(treepattern)-1
   space1=trunc((width-treepattern[i])/2)
   treespace[i]=space1+space2
   space2=width-(space1+treepattern[i])
next
treedata:
   for i=sizeof(treepattern)-1 to 0 step-1
      byte treespace[i]
   next
tree:
      byte treepattern[i]
   next
PostPosted: Wed Dec 22, 2021 8:29 pm
Just because you can doesn't mean you should.... (famous last words!)
So I thought just because... I'll do it in Sweet16... Naively thinking it might be smaller than some of the 6502 asm versions here, however, at $54 or decimal 84 bytes, then sadly no. Much is taken up by switching into and out of sweet16 mode, also given that sweet16 doesn't have any logical operators (e.g. shift) then my standard (terminal width - stars) / 2 calculation to get the leading spaces was going to be tricky, and I couldn't be bothered being clever, so I implemented a 2nd table.
The output is as it ought to be:
* load tree 8000
* go
Starting program at $8000 (Emulation)
The source code... OK, here it is....
; runTree.s:
   .include   "sw16.h"
   .include   "sw16regs.h"
   .include   "runTree.h"
   .include   "osVectors.h"
.proc   runTree
   goSweet16
   set   r12,$0100   ; Sweet16 stack pointer
   set   r2,1      ; Constant 1
   set   r3,40      ; Constant 40 - width / 2
   set   r8,treeData   ; Address of the tree data table
   set   r9,spaceData   ; Address of the tree branch spaces
loop:
   ld   @r9      ; Loads and increments r9
   bz   done      ; Reached the end
   set   r7,' '      ; r7 has character to print
   bs   printIt
   ld   @r8      ; Loads and increments r8
   set   r7,'*'
   bs   printIt
; Newline
   rtn         ; Back to 6502 land
   .setcpu "65c02"
   jsr   osNewl
   jsr   _sweet16   ; Back to sweet16 land
   .setcpu   "sweet16"
   br   loop
; printIt:
;    Print Acc's worth of r7's...
printIt:
   .setcpu "65c02"
   lda   r7l      ; r7l has character to print
   jsr   osWrch
   .setcpu   "sweet16"
   sub   r2      ; Subtract r1 (1) from Acc
   bnz   printIt
   rs         ; Return from subroutine
done:
   exSweet16
   rts
.endproc
; treeData:
treeData:
   .byte   1,3,5,7, 3,7,11,15, 5,11,17,23, 3,3
spaceData:
   .byte   39,38,37,36,38,36,34,32,37,34,31,28,38,38,0
So if anyone ever wanted to know what sweet16 looks like then there you are ;-)
Oh, small confession, actually the whole thing is rather longer as my Ruby 816 OS no-longer has Sweet16 as a part of it (the 6502 version still has, but I'm running this on my '816 board), so I had to include the sweet16 code too (my version which can be assembled anywhere), as well as the standard code header I use (to make it an Acorn compatible ROM. That takes it to
-rw-rw-r-- 1 gordon gordon 782 Dec 22 20:21 tree
So, 782 bytes in total... But then I could also include the Ruby 816 OS, but where would you stop...
PostPosted: Thu Dec 23, 2021 9:07 am
Regarding:
set r2,1
sub r2
I think
dcr r0
should be your friend here (unless I messed up and dcr doesn't affect flags). Also, I noticed that there are always an odd number of stars, so you could go back to a single table with entries of (stars-1)/2 and then
ld @r8
st r1
set r0,20
sub r1
for your space count and
ld r1
add r1
inr r0
for your star count (or something like that ...)
PostPosted: Thu Dec 23, 2021 9:14 am
barrym95838 wrote:
Regarding:
set r2,1
sub r2
I think
dcr r0
should be your friend here.
Duh! Why did I forget the inr/dcr instructions. Obviously had too many sherrys last night, or something!
I'll have a look at the rest when I've done the morning tasks (dog, horse, house, etc.)
ld @r8
st r1
set r0,20
sub r1
ld r1
add r1
inr r0
PostPosted: Thu Dec 23, 2021 11:19 am
barrym95838 wrote:
Regarding:
set r2,1
sub r2
I think
dcr r0
ld @r8
st r1
set r0,20
sub r1
ld r1
add r1
inr r0
And yes, that works. Output:
* ftp get tree
*load tree 8000
* go
code length is now $47, or decimal 71 bytes.
; runTree.s:
   .include   "sw16.h"
.proc   runTree
   goSweet16
   set   r3,40      ; Constant 40 - tWidth / 2, also end of data marker
loop:
   ld   @r8      ; Fetch data into Acc; Loads and increments r8
   cpr   r3      ; End of data?
   st   r1      ; Temp. store
   ld   r3      ; 40 -> Acc
   sub   r1      ; To get No. spaces
   bs   printIt      ; Subroutine to print leading spaces
   ld   r1      ; Get original table data
   add   r1      ; double it
   inr   r0      ; Add 1
   set   r7,'*'
   bs   printIt      ; Subroutine to print a banch of cones
; Newline
   exSweet16      ; To 6502 land
   jsr   osNewl
   goSweet16      ; Back to sweet16 land
   br   loop
printIt:
   jsr   osWrch
   dcr   r0      ; Subtract 1 from Acc
   bnz   printIt
done:
   exSweet16
   rts
.endproc
; treeData:
;   As per the suggestion iof  barrym95838, we're storing a computed
;   number here - it's the number (stars - 1) / 2.
;   So the number of spaces is 40 - n
;   and the numbe of stars  is n + n + 1.
treeData:
   .byte   0,1,2,3, 1,3, 5, 7, 2, 5, 8,11, 1,1, 40
;   .byte   1,3,5,7, 3,7,11,15, 5,11,17,23, 3,3
Minor improvements can be made by utilising the 3 unused sweet16 non-register opcodes - e.g. one could be print new line and another could be print Acc - that saves the jump to 6502 land and back again twice, however is that overstepping the mark?
for those wondering, exSweet16 and goSweet16 are macros:
.macro   goSweet16
       jsr   _sweet16
   .setcpu "sweet16"
.endmacro
.macro   exSweet16
   rtn
   .setcpu "65c02"
.endmacro
Anyway, that is I think, enough for now!
PostPosted: Thu Dec 23, 2021 4:23 pm
Trade-offs are part of the game. Charlie liked Sweet16 enough to install an optimized (!) version on his PET and added opcodes for EXT, a DTC Forth NEXT, DUP and DROP. I hope he's doing well ... I haven't heard from him in months.
Users browsing this forum: Google [Bot] and 19 guests
