It is currently Fri Nov 22, 2024 9:00 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: 6502 in Logisim
PostPosted: Sun Dec 05, 2021 10:55 am
Hi, we have completed the 6502 circuit design in Logisim.
https://github.com/emu-russia/breaks/tr ... 02_logisim
There are two options there: for classic Logisim 2.7.1 (6502.circ) and for Logisim Evolution 3.7.2 (6502_Evo.circ).
The schematics kind of works and all main processor parts are implemented, but it obviously still needs to be debugged.
Probably, it will be interesting for someone and we will finish it together :)
6502 addict
 Post subject: Re: 6502 in Logisim
PostPosted: Sun Dec 05, 2021 11:08 am
Bravo!
PostPosted: Sun Jan 23, 2022 5:42 pm
We are making some progress.
The 6502 in Logisim successfully passes the BRK sequence and executes the first few instructions. Some kind of problem with the JSR. We are working on it.
Next to it is visual6502.hex in Logisim format, which can be loaded into RAM.
Also there is a script bin2hex.py, which converts binary files into Logisim format.
6502 addict
PostPosted: Mon Jan 24, 2022 12:39 pm
All problems have been eliminated. The 6502 now works in Logisim as well.
6502 addict
PostPosted: Mon Jan 24, 2022 1:56 pm
Hurrah! Anything interesting about the difficulty with JSR?
PostPosted: Tue Jan 25, 2022 11:45 am
Nothing new :) Again there were problems with the bi-directional transistors used for SB/DB and SB/ADH commands. I had to do a little hack for the logisim, which does not support bidirectional connections, to account for the "dirty" buses.
6502 addict
PostPosted: Sun Apr 03, 2022 3:12 pm
@org, I am a college teacher at a Philippine university and I would like to assign as an undergraduate student project the task of converting your Logisim design into a Digital design. (The Digital software is the one at https://github.com/hneemann/Digital.) It will be made very clear in the documentation and presentation that the Logisim design was made by you. Is this all right with you?
PostPosted: Tue Apr 05, 2022 11:05 am
No problem, but it's better to mention the `Breaks` project on GitHub (https://github.com/emu-russia/breaks) rather than me, since it's a team effort :)
6502 addict
PostPosted: Wed Apr 06, 2022 7:15 am
@org, thank you very much. I'll show you their work when they're finished (a few months from now).
PostPosted: Wed Apr 06, 2022 7:47 am
Good luck to your students! I'm very curious what they will do :)
6502 addict
PostPosted: Sun May 08, 2022 6:55 am
@org, my students downloaded the Logisim circuit currently available at github, and they're getting errors when they run the Logisim circuit. The 6502 circuit has wires that are "red" and in error (SB OUT, DB OUT, etc.). Has this been fixed?
PostPosted: Fri May 13, 2022 5:57 pm
Yes, the 6502.circ works well.
Maybe they downloaded the "Evo" version (for Logisim Evolution), which may still contain bugs since it hasn't been updated in a while.
6502 addict
PostPosted: Sat May 14, 2022 1:24 pm
If I'm not mistaken, the file named 6502.circ currently at https://github.com/emu-russia/breaks/tr ... 02_logisim, when opened in Logisim, looks like below.
File comment: This seems to be an older version of the circuit.
PostPosted: Wed May 18, 2022 10:03 am
I get it. You are looking at the state after the very first half cycle (PHI1), during which 6502's behavior is Undefined.
This is due to the fact that the command latches for the lower part are only updated during PHI2, so on the first half-cycle of PHI1 the lower part "goes crazy", as almost all latches issue down all commands at once.
It is enough to perform one more half-cycle and the processor stabilizes.
6502 addict
PostPosted: Wed May 18, 2022 10:04 am
See more about very first half-cycle here: https://github.com/emu-russia/breaks/bl ... ops/brk.md
6502 addict
Users browsing this forum: jds and 15 guests
