It is currently Sat Nov 23, 2024 10:52 am
Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Aug 30, 2021 2:38 pm
Ouch! That hurts.... more fancy coasters for the workshop it seems.
Also, their straight edges make them good for drawing short lines. :shock:
J64C wrote:
Gotta post pics of the boards anyway though! Can’t leave us hanging. 8)
I suppose. I'll see what I can do.
PostPosted: Tue Aug 31, 2021 2:19 am
The PCBs arrived on Monday, and as I was preparing to get the SMT stuff soldered in place, I discovered a major boo-boo in the layout. :oops: The board is electrically correct but the footprint I used for the 'AC245 transceiver was wrong. It has the right number of lands but is the wrong package width
Welcome to the club. :) On my first build, back in 2017, I picked the narrow (7mm) DIP footprint for my 6850 instead of the 15mm one. Fortunately I was able to rig up an adapter with some perf board, a socket, and some headers. Didn't even bother fixing that problem until I upgraded the design earlier this month.
PostPosted: Tue Aug 31, 2021 12:29 pm
If it is any comfort, I'm the record holder of the biggest IC footprint mistake: That's a BIG 64-pin 68000 tilting about 45 degree to fit a 600 mil-wide footprint; correct footprint is 900 mil wide.
PostPosted: Tue Aug 31, 2021 1:05 pm
Pythagoras to the rescue!
PostPosted: Tue Aug 31, 2021 1:37 pm
Bill, I love the stubborn, "don't take no for an answer" attitude! More of your obstinate artistry in this thread...
PostPosted: Tue Aug 31, 2021 2:32 pm
I would just mount a tiny 5V fan at one end and call it extra cooling surface area. 8)
PostPosted: Tue Aug 31, 2021 3:46 pm
it is a different way to shrink the size of 64 DIP to save pcb real estate. 8)
I also have a footprint error involving a 64-pin "Shrink DIP". There is nice photo of it somewhere...
Edit, here is the picture. Notice the row of 32 pins at the bottom of picture; it is not wide angle lens distortion. :wink:
PostPosted: Tue Aug 31, 2021 8:57 pm
Yikes! That looks downright dangerous. At least you were able to salvage the PCB and complete the assembly.
PostPosted: Wed Sep 01, 2021 6:52 am
Would that be 1.87mm spacing instead of 1.78mm ???
PostPosted: Thu Sep 02, 2021 4:43 am
The PCBs arrived on Monday, and as I was preparing to get the SMT stuff soldered in place, I discovered a major boo-boo in the layout...Supposedly, I'll have the new PCBs and stencil on Thursday.
The new boards and stencil arrived. The bus transceiver footprint is now correct. Time to build the contraption and see if she goes or blows.
PostPosted: Thu Sep 16, 2021 1:16 pm
I had a chance to put the scope on the board I built based on the POC2 design.
Starting with the clock stretching, both 1 and 2 wait states appear to be inserted as expected. Seen here with 1 wait state selected.
File comment: longer shot of the wait states
The average frequency detected by the scope shows that particular section of code (probably keyboard scanning) has a 5 to 6% slowdown over all as the master clock is 20mhz for a nominal CPU speed of 10mhz. That's a small price to pay compared to running the board ad the speed of the slowest I/O component.
The first test runs were done with a slightly out of spec HC parts, both flip flops have been replaced with newly arrived AC parts and the clock from the flip flop shows a little ringing:
File comment: Scoping the clock side of the damping resistor
On the CPU side of the 120R resistor the ringing is gone, but the waveform is somewhat rounded:
File comment: CPU side of the damping resistor
Not that the CPU seems to mind, the rise and fall rate in the mid range is nice and fast.
PostPosted: Thu Sep 16, 2021 4:03 pm
Martin A wrote:
On the CPU side of the 120R resistor the ringing is gone, but the waveform is somewhat rounded...
Looks as though your clock circuit has higher-than-average parasitic capacitance, or your probe is loading down the circuit.
PostPosted: Thu Sep 16, 2021 8:16 pm
I wouldn't bet against either to be honest. The important thing is your design appears to be working as intended.
PostPosted: Sat Sep 18, 2021 4:47 am
Here's a pic of the bad board and the good board. The bottom board is the good one.
PostPosted: Sat Sep 18, 2021 4:51 am
Here are a few more pics.
File comment: POC V2.0 PCB Top Layer
File comment: POC V2.0 PCB Bottom Layer
File comment: POC V2.0 PCB w/SMT Components
Users browsing this forum: No registered users and 35 guests
