Discussion here:
viewtopic.php?p=76604#p76604
; When we come here the first time after selection, NEW_KEY_FLAG was
TREATMENT: ; cleared in MENU_CASE_PRELUDE, and MENU_ITEM_STATE was cleared in
MOVF MENU_ITEM_STATE, W ; MENU_TASK case 0. If TREATMENT was already selected, then NEW_KEY_FLAG
CASE ; will remain set if a new keypress was made.
CASE_OF_ 5 ; Case 5 is for running the treatment.
GOTO TREATING ; (CALL, RETURN) I'm separating out this routine. Case 5 is first, to
END_OF_ ; reduce the number of instructions taken each time the task is called up
; after a treatment is actually started.
CASE_OF_ 0 ; Case 0 is for when we first arrive here from the main menu. Display
DISP_ROM_STR CLR, Sel_a_Rx_STR ; "Rx #1 (Use < > )" (but replace < and > with the arrow characters).
INCF MENU_ITEM_STATE, F ; Transition to state 1, offering the choice of Rx #1.
CLRF MENU_ITEM_STATE_L2
GOTO trm1 ; Go about 100 lines down, to test the validity of the Rx.
END_OF_ ; (The _ after the END_OF prevents wasting memory on a GOTO <END_CASE>.)
CASE_OF_ 6 ; Case 6 is for exiting, to time the "Exiting" message.
MOVF MENU_ITEM_STATE_L2, W
IF_ZERO ; This is kind of like a "CASE_OF 0", and, further down, "CASE_OF 1".
DISP_ROM_STR CLR, Exiting_STR ; Display, "Exiting".
CALL _1_SEC_DISP ; Put the current time plus one second in LCD_TARGET_TM.
INCF MENU_ITEM_STATE_L2, F
ELSE_
IF_FLAG_VAR NEW_KEY_FLAG, IS_CLEAR
CALL TM_2_LCD_TARGET_TM? ; How long left to see "Exiting"? Take current time minus LCD_TARGET_TM.
RETURN_IF_ACCb_NEG ; If it's negative, we must still give more time to see msg, so just exit.
END_IF
; If we've reached the target time, or if a key was pressed,
CLRF LCD_TARGET_TM ; make sure nothing else could think LCD_TARGET_TM is in use,
CLRF MENU_STATE ; set _main_ menu state to 0, (MENU_TASK will clear MENU_ITEM_STATE)
END_IF ; and proceed to clear key status and exit.
CLR_FLAG NEW_KEY_FLAG
RETURN
END_OF_ ; The _ at the end of END_OF_ eliminates the jump to END_CASE, since it was
END_CASE ; immediately preceded by an unconditonal RETURN, & END_CASE is next anyway.
; We're waiting for the 1st keypress to select a Rx.
RETURN_IF_FLAG_VAR NEW_KEY_FLAG, IS_CLEAR ; If no key was pressed (which is the usual situation), just exit.
CLR_FLAG NEW_KEY_FLAG ; A key has been pressed.
MOVF NEW_KEY, W ; We only watch for <--, -->, HOME, END, NO, and YES. Other keys ignored.
CASE
CASE_OF_ RAW_LEFT_KEY
DECF MENU_ITEM_STATE, F ; Decrement with left_arrow key, but
BTFSC STATUS, Z ; don't let it get below 1. If it did,
INCF MENU_ITEM_STATE, F ; put it back to 1.
END_OF
CASE_OF_ RAW_RIGHT_KEY
MOVF MENU_ITEM_STATE, W ; Check MENU_ITEM_STATE
SUBLW 4 ; against 4 (the max allowable).
BTFSS STATUS, Z ; If it's not already there,
INCF MENU_ITEM_STATE, F ; you can increment it.
END_OF
CASE_OF_ RAW_HOME_KEY
PUT 1, IN, MENU_ITEM_STATE
END_OF
CASE_OF_ RAW_END_KEY
PUT 4, IN, MENU_ITEM_STATE
END_OF
CASE_OF_ RAW_NO_KEY
PUT 6, IN, MENU_ITEM_STATE ; This gets trapped above, to time the "Exiting" message.
RETURN
END_OF_ ; The _ at the end of END_OF_ eliminates the jump to END_CASE, to save a
; program-memory word since there's an unconditional RETURN right before it.
CASE_OF_ RAW_YES_KEY
IF_FLAG_VAR Rx_VALID_FLAG, IS_SET ; If not valid Rx, YES key gets ignored. For checking, the decryp-
CALL INSTALL_DECRYPT_ARRAY ; tion was already done when the left or right arrow was pressed.
DISP_ROM_STR CLR, Treating_STR ; Display "Treating" briefly before asking for AGL.
CALL _4_SEC_DISP ; Tell it to display for 4 seconds before asking for initial AGL.
; (No delay loops, but it puts current time + 4 sec in LCD_TARGET_TM.)
CALL XFER_HI_TM_2_ACCb ; We'll ask for first AGL right away (but it will wait until the
MOVF ACCbLO, W ; "Treatment begun" message has shown for a few seconds first).
MOVWF NEXT_AGL_TM ; We'll forgo the macro usage here since we're copying the time
MOVWF TREATMENT_BEG_TM ; to two variables, and we can avoid re-loading bytes this way.
MOVF ACCbHI, W
MOVWF NEXT_AGL_TM+1
MOVWF TREATMENT_BEG_TM+1
_8V_UP ; Make the 8V pulse output high for 5 or 10ms. (DELAY's parameter is the
DELAY 1 ; number of ms if interrupts are off, with a 2ms resolution so input is
_8V_DN ; rounded up. Here, interrupts are on though, and I'm seeing about 7ms.)
CLRF AGL_IMG_TO_STORE ; (This will get changed 3 lines down to reflect Rx number.)
CALL SET_TREATMENT_BOUNDARY ; Store a fake AGL with Rx#=0 to mark the beginning of another treatment.
; Only the first byte of the fake AGL is significant; rest are random.
COPY MENU_ITEM_STATE, TO, AGL_IMG_TO_STORE ; Before overwriting MENU_ITEM_STATE, store Rx# for STORE_AGL.
PUT 5, IN, MENU_ITEM_STATE ; This will make the rest get handled (or re-routed) above. The "ELSE_"
END_IF ; would be that YES was pressed on an invalid Rx; but that does nothing,
RETURN ; so we don't have to specify. (With an unconditional RETURN right before the
END_OF_ ; END_OF, we can put the _ after END_OF to keep it from assembling GOTO END_CASE.)
RETURN ; All other keys are ignored.
END_CASE ; But if <--, -->, HOME, or END were pressed, we will continue here to display the
; Rx number, followed by either "Rx is invalid", "Rx is blank", or the Rx itself.
; Invalid ones won't be stored here, but a crook may try to store by different way.
< snip >Code: Select all
MIN
LDA 1,X
CMP 0,X
BCC .2
.1 LDA 0,X
.2 INX
RTS
MAX
LDA 1,X
CMP 0,X
BCC MIN.1
INX
RTS
OUTSPACES.1
.1 JSR OUTSPACE
OUTSPACES
SEC
SBC #1
BCS .1
RTS
_OUTSPACES
.1 JSR OUTSPACE
.2 SEC
SBC #1
BCS .1
RTS
OUTSPACES = _OUTSPACES.2
{LDX #$00 : LOOP INX : CPX #$40 : BNE LOOP} // Count to 64Code: Select all
{LDX #$00 LOOP INX CPX #$40 BNE LOOP} // Count to 64Code: Select all
ORG $8000
START:
LDX #$00
.NEXTCHAR:
LDA HELLOTEXT,X
BEQ .DONE,2 ; search within 2 global labels
JSR $FFD2
INX
JMP .NEXTCHAR
HELLOTEXT:
.BYTE 'Hello World',0
.DONE:
RTS
CLC
LDA FOO ADC BAR STA FOO ; Add the low byte of a pair of 3-byte variables,
LDA FOO+1 ADC BAR+1 STA FOO+1 ; then the mid byte,
LDA FOO+2 ADC BAR+2 STA FOO+2 ; then the high byte.Code: Select all
rrc ! rrc ! rrc ! rrc ; Shift upper nybble to lower
