For reference, the following logic families are assumed:
- AVC (3.3V) — Registers
- NC7SV (3.3V) — Gates and flip-flops
- LVC (3.3V) — Decoders and counters
- CBTLV (3.3V) — Muxes
- AUC (2.5V) — 74AUC2G53 2:1 switch
Another possibility is to simply run all parts at say 3V, which is below the Absolute Maximum rating of AUC parts and only slightly below the Recommended VCC of the 3.3V families. I’m not sure what kind of safety margin is needed to keep those ICs happy. Certainly I was able to run the AUC FET Adder at 3.3V without frying any chips! Maybe a single 3V supply may work?
An alternative mix of families is:
- AUC (2.5V) — Registers
- AUC (2.5V) — Gates and flip-flops
In the meantime, I would very much appreciate any thoughts anyone might offer regarding the relative safety of running ICs a little hot, but below their rated absolute maximums. Is that pushing luck too far?
Cheers for now,
Drass
