A grid is easy to design, and it makes multiple return paths available... which means any A-to-B signal path has an approximately matching return path nearby. The return path will have extra jigs and jogs because it's confined to the east-west and north-south lines of the grid. (With a ground plane, there are no unnecessary jigs and jogs because the return current is free to follow ANY possible path. The return current "wants" to hug the signal path. The closest hugging path is the most attractive path.)
The grid falls short of perfection because jigs and jogs won't match the signal path exactly.
If the signal path is diagonal, the ideal return path is also diagonal.
If the signal path is meandering, the ideal return path is also meandering.
Notice what we're seeing here. In this latter case a longer wire is actually better.
Also: where high-frequency signals are concerned, it's useful to view a capacitor as just a piece of wire (its capacitance means it has low impedance). That's simplifying slightly, as it also has some inductance. But on the question of having two grids -- one each for Gnd and Vcc -- IMO it's almost as good to just have one grid, with "pieces of wire" as local connect points for the grid that's absent.
(Hm, Garth just posted saying he considers the Vcc grid less critical but still very helpful. IOW, we agree it's better to have two grids, but differ on the question of how much better. I concede that caps with long leads, as used in this project, make comparatively poor "pieces of wire" and thus adding a Vcc grid may be very helpful. But where SMD caps are properly used, I'd say a single grid approach is more viable, and adding a second one won't make as much difference.)
