More Information
muchtolearn
More Information
I am at the stage where I need more information not just about the CPU
but how the architecutre works and fits all together. I am finding
random docs on line like datasheets for the CPU but that only
contains a portion of what I want to know.
Then I came across this:
http://uisprocesadores2008.wdfiles.com/ ... LMDch6.pdf
This is brilliant!!!
Except it is for the PC and the 8086.
Are there books like this for the 6502?
- GARTHWILSON
- Forum Moderator
Re: More Information
There's the 6502 primer, about building your own computer, at http://wilsonminesco.com/6502primer/ . It has 22 chapters, or web pages, arranged in a logical order, with some of them being applicable to other processors as well, for example the one about displays, or the one about wire-wrapping. Many others are specific to the '02. It does assume a little background knowledge, like basic logic ICs and binary and hexadecimal number bases.
A very old 6502 hardware manual but probably still quite useful is the MOS Hardware Manual at http://wdc65xx.com/wp-content/uploads/2 ... _Jan76.pdf, on WDC's site. The software manual they have is, IMO, the best: "Programming the 65816 including the 6502, 65C02, and 65802" by David Eyes and Ron Liechty, at http://wdc65xx.com/Programming-Manual/ .
Check out the book list on this site, at http://6502.org/books, and other resources under the categories listed at the front page, http://6502.org/ .
For books about individual computer brands, I have links to loads and loads on my links page at http://wilsonminesco.com/links.html#brands . Elsewhere on the same page there are links to a lot of other valuable materials, and to others' 6502 websites, for example Rich Cini's website where he has posted scans of literally hundreds of 6502 books and documents. There are hundreds of links on my links page, mostly for 6502.
muchtolearn
I am interested in specifics of CPU. (ALU how it works with the
buses and R/W cycles). I need the technical information explained
and not just presented which I find alot of the 6502 books do.
- GARTHWILSON
- Forum Moderator
See Dieter's pages on this site, indexed at http://6502.org/users/dieter/ . He delves into ALU design.
Hey muchtolearn, I see you've been here a while, but no-one has welcomed you. Welcome!
That first PDF you posted looks pretty general to me - it might use x86 as an example, but the information is general. There are three differences, off the top of my head, of the 6502 vs the x86 or Z80 world:
- the 6502 has a RnW output, instead of having separate read and write strobes. Therefore every bus cycle is either a read or a write. Later 6502-family offerings had pins to signal valid data accesses and valid program accesses, which means the system can distinguish bus cycles where the 6502 is not making an access.
- the 6502 is clocked at memory speed, whereas the x86 and z80, AIUI, take several clock cycles for one memory access.
- the 6502 has a single address space, so I/O devices share space with RAM and ROM. The x86 and z80 machines have a separate I/O space, which means they can have a full 64k of memory and simpler decoding.
Perhaps another difference is that DMA is common in the 8-world, not so common in the 6502 world.
muchtolearn
Big Ed
Thanks for the welcome!
Buses are a mystery to me can
You explain more/give definitions.
6502 only has 1 pin for R/W how
Is this done?
And I have completely different
Question about assembly language.
Why do JSR's need a RTS? If you
Have a JSR in your code the processor
Goes to this routine, executes it
And then goes back to the next line
After the JSR. the subroutine had been
Executed. So why do you need to put
A RTS. What to return to the subroutine
You have just executed? that does
Not make sense.
Is this done?
Not make sense.
- GARTHWILSON
- Forum Moderator
muchtolearn wrote:
Buses are a mystery to me can You explain more/give definitions.
6502 only has 1 pin for R/W. How is this done?
And I have completely different question about assembly language. Why do JSR's need a RTS? If you Have a JSR in your code, the processor goes to this routine, executes it, and then goes back to the next line after the JSR. The subroutine had been executed. So why do you need to put A RTS? What to return to the subroutine You have just executed? That does Not make sense.
DerTrueForce
[Garth posted as I was writing this, but I'm going to put it here anyway]
The 6502 has only one signal for indicating a read or a write. This is not the only thing that's used for indicating an access, though. If the clock signal is low, the 6502 is not looking at the bus. This fact can be used to generate z80-style /RD and /WR signals for where that's necessary. 65-series peripheral ICs do that internally.
RTS exists to mark the end of a subroutine.
The 6502 executes instructions in roughly this order:
I think it's a poor choice of mnemonic, because it suggests something like "Return To Subroutine". According to WDC, it actually stands for "ReTurn from Subroutine", which is highly counter-intuitive. I think of it as "Return To Sender". Same goes for RTI("ReTurn from Interrupt"), which I think of as "Return To Interrupted".
<code leading up to subroutine>
JSR
<subroutine>
RTS
<code right after JSR>
muchtolearn
This is great stuff!!
Thanks for the replies and answers.
so basically the RTS operand is used
Push and pull the JSR address onto the stack,
Correct?
I have some more questions.
address bus- information transfers takes
Place in one direction. From the CPU
To memory. (correct?)
Now please comment, correct discuss etc
When a CPU wants to transfer information
Between itself and a certain memory location,
It generates the 16 but address from an internal
Register on its 16 address pins, which then
Appears on the address bus. These 16 address
Bits are decided to determine the desired memory
Location. The decoding process normally requires
Hardware (decoder). Does this happen for
The 6502? What are the decodes?
Correct?
- GARTHWILSON
- Forum Moderator
muchtolearn wrote:
so basically the RTS operand is used [to] push and pull the JSR address onto the stack, correct?
muchtolearn
yes correction. the JSR pushes the address
Of the JSR onto the stack and the RTS pulls
The address off the stack.
as for the answer you gave in the 2nd
Part it is confusing. can you please
Explain within a computer. I am
Only concerning myself at this
Stage to the motherboard and no other
Devices or peripherals.
- GARTHWILSON
- Forum Moderator
muchtolearn wrote:
yes correction. the JSR pushes the address of the JSR onto the stack and the RTS pulls the address off the stack.
RTS, RTI, and JSR can also be used for other things besides the obvious, as discussed in section 11 of the 6502 treatise on stacks (stacks plural, including virtual stacks, not just the page-1 hardware stack).
as for the answer you gave in the 2nd part it is confusing. can you please explain within a computer. I am only concerning myself at this stage to the motherboard and no other devices or peripherals.
VIA: EQU $6000 ; The base address of the 6522 Versatile Interface Adapter is $6000.
PB: EQU VIA ; Its port B is at that address.
PA: EQU VIA+1 ; Its port A is at address $6001.
DDRB: EQU VIA+2 ; Its data-direction register for port B is at $6002.
DDRA: EQU VIA+3 ; Its data-direction register for port A is at $6003.
T2CL: EQU VIA+8 ; Its timer-2 counter's low byte is at $6008.
T2CH: EQU VIA+9 ; Its timer-2 counter's high byte is at $6009.
SR: EQU VIA+10 ; The shift register is at $600A.
ACR: EQU VIA+11 ; The auxiliary control register is at $600B.
PCR: EQU VIA+12 ; The peripheral control register is at $600C.
IFR: EQU VIA+13 ; The interrupt flag register is at $600D.
IER: EQU VIA+14 ; The interrupt enable register is at $600E.http://WilsonMinesCo.com/ lots of 6502 resources
muchtolearn
The computer I use does not have ports.
Anyway, I went to your website and went to the page
on address decoding.
In fact, the Apple II did two memory accesses per cycle, two million per second at 1MHz, with the video accessing the memory during the first half of Φ2, and the processor during the second half, interleaving, so both could access the same memory at the same time at full speed, with no conflicts.
Where does this information come from? (Or can you explain this
in detail).
in detail).
DerTrueForce
What computer is that, then? A computer with no I/O sounds awfully limited.
The reason the Apple II did two memory accesses per cycle is because the video circuitry accessed the RAM when the 6502 wasn't looking at the bus. The 6502 doesn't access the memory while the clock signal (Φ2) is high, so if the Bus Enable pin is used to tri-state the 6502's outputs, something else(in this case, the video circuitry) can access the memory if everything is fast enough.
muchtolearn
And this information comes from where exactly?
