I have had this idea rattling around in my head for a 65816 SBC for some time now – and I had some free time, so I put form to that thought. The design is pretty straight forward, and leverages the ECB bus and is compatible with the IO boards from the Retrobrew Computers (formerly N8VEM) project. I have a monitor running in "emulation" mode and am working on creating a native mode monitor now. I also have the code running to control the 8272 based floppy controller card.
The system has 512K RAM and 32K ROM as well as a real time clock on board.
as it stands the memory map is:
000000 - 007FFF On Board RAM
008000 - 00FDFF On Board RAM or ROM - ROM can be software selectable to 32K or a choice of a 8 or 16K bank - bank size selectable in GAL equations
00FE00 - 00FE06 16550 UART
00FE07 - FE07 RTC & ROM SIZE SELECTION FLAG
00FE08 - 00FEFF Mapped to Z80 ports for ECB bus boards (IO)
00FF00 - 00FFFF BIOS and Hardware Vectors
00FF00 - 00FF70 Native mode jump table
00FF71 - 00FFEF Emulation Mode jump table
00FFF0 - 00FFFF Hardware Vectors
010000 - 07FFFF On Board RAM
080000 - FFFFFF Open to ECB Bus
more information including schematics can be found here:
https://www.retrobrewcomputers.org/doku ... 16_ecb_sbc
I have a few extra SBCs from the manufacturing run, so if anyone is interested in building one of these -- they are listed for sale on the Retrobrew computers "board inventory" page here:
https://www.retrobrewcomputers.org/doku ... dinventory
New 65816 SBC
- BigDumbDinosaur
Re: New 65816 SBC
You might find Supermon 816 useful, as it runs on the '816 in native mode.
Re: New 65816 SBC
Dan
Dan Werner
Re: New 65816 SBC
I successfully got it to assemble using the WDC assembler (I want to keep all of my work in the same tools, to keep my sanity
example
T 7000 7010 5000 <- works OK
T 7000 7010 7060 <- returns to prompt OK, but fails to copy anyhting
The code is pretty simple, and as far as I can tell it assembled properly (from what I can tell the WDC toolset is picky, so proper assembly is not always to be taken for granted)
I am going to keep looking, but I was wondering if there were any known bugs in this area?
Dan
Dan Werner
Re: New 65816 SBC
example
Dan
nevermind, I found the problem -- duh . . .
000000C0 opc_cpyi .equ $c0 ;CPY # opcode
000000A2 opc_ldxi .equ $a2 ;LDX # opcode
000000A0 opc_ldyi .equ $a0 ;LDY # opcode
00000054 opc_mvn .equ $54 ;MVN opcode
0000002C opc_mvp .equ 44 ;MVP opcode
000000C2 opc_rep .equ $c2 ;REP opcode
000000E2 opc_sep .equ $e2 ;SEP opcode
Dan Werner
- BigDumbDinosaur
Re: New 65816 SBC
example
0000002C opc_mvp .equ 44 ;MVP opcode <----------------
000000E2 opc_sep .equ $e2 ;SEP opcodex86? We ain't got no x86. We don't NEED no stinking x86!
Re: New 65816 SBC
Details on request.
Re: New 65816 SBC
JeeK wrote:
Details on request.
I will check it out, thanks!
Dan
Dan Werner
