It is currently Sat Nov 23, 2024 7:46 am
 Post subject: New 65816 SBC
PostPosted: Sat Oct 07, 2017 7:08 pm
I have had this idea rattling around in my head for a 65816 SBC for some time now – and I had some free time, so I put form to that thought. The design is pretty straight forward, and leverages the ECB bus and is compatible with the IO boards from the Retrobrew Computers (formerly N8VEM) project. I have a monitor running in "emulation" mode and am working on creating a native mode monitor now. I also have the code running to control the 8272 based floppy controller card.
The system has 512K RAM and 32K ROM as well as a real time clock on board.
as it stands the memory map is:
000000 - 007FFF On Board RAM
008000 - 00FDFF On Board RAM or ROM - ROM can be software selectable to 32K or a choice of a 8 or 16K bank - bank size selectable in GAL equations
00FE00 - 00FE06 16550 UART
00FE07 - FE07 RTC & ROM SIZE SELECTION FLAG
00FE08 - 00FEFF Mapped to Z80 ports for ECB bus boards (IO)
00FF00 - 00FFFF BIOS and Hardware Vectors
00FF00 - 00FF70 Native mode jump table
00FF71 - 00FFEF Emulation Mode jump table
00FFF0 - 00FFFF Hardware Vectors
010000 - 07FFFF On Board RAM
080000 - FFFFFF Open to ECB Bus
more information including schematics can be found here:
https://www.retrobrewcomputers.org/doku ... 16_ecb_sbc
I have a few extra SBCs from the manufacturing run, so if anyone is interested in building one of these -- they are listed for sale on the Retrobrew computers "board inventory" page here:
https://www.retrobrewcomputers.org/doku ... dinventory
Dan Werner
 Post subject: Re: New 65816 SBC
PostPosted: Sat Oct 07, 2017 7:26 pm
You might find Supermon 816 useful, as it runs on the '816 in native mode.
PostPosted: Sat Oct 07, 2017 7:46 pm
Thanks, will check it out!
Dan
Dan Werner
PostPosted: Sun Oct 08, 2017 3:08 am
Supermon 816 is exactly what I was looking for, so I abandoned my monitor and decided to use Supermon.
I successfully got it to assemble using the WDC assembler (I want to keep all of my work in the same tools, to keep my sanity :D ), and everything checks out -- except reverse copies. forward works, but reverse does not.
example
T 7000 7010 5000 <- works OK
T 7000 7010 7060 <- returns to prompt OK, but fails to copy anyhting
The code is pretty simple, and as far as I can tell it assembled properly (from what I can tell the WDC toolset is picky, so proper assembly is not always to be taken for granted)
I am going to keep looking, but I was wondering if there were any known bugs in this area?
Dan
Dan Werner
PostPosted: Sun Oct 08, 2017 3:14 am
example
Dan
nevermind, I found the problem -- duh . . .
 000000C0   opc_cpyi .equ $c0                  ;CPY # opcode
 000000A2   opc_ldxi .equ $a2                  ;LDX # opcode
 000000A0   opc_ldyi .equ $a0                  ;LDY # opcode
 00000054   opc_mvn  .equ $54                  ;MVN opcode
 0000002C   opc_mvp  .equ 44                  ;MVP opcode
 000000C2   opc_rep  .equ $c2                  ;REP opcode
 000000E2   opc_sep  .equ $e2                  ;SEP opcode
Dan Werner
PostPosted: Sun Oct 08, 2017 4:05 am
example
 0000002C   opc_mvp  .equ 44                  ;MVP opcode   <----------------
Dan
Amazing what a missing dollar sign can do. :D
PostPosted: Tue Oct 10, 2017 12:03 pm
Maybe you will find Jammon (Jamaica Monitor) also useful. Despite it's old, it works nicely at least for my environment. I translated it to the ACME assembler syntax for better integration into my project, which is based on C64 SuperCPU for testing and a 16-bit C64 expansion board (c't magazine, 1987) (sorry, currently just german docs available) on real hardware. In addition to the embedding glue code needed I fixed a minor bug concerning disassembling in alternate display mode and how the cpu flags are handled.
Details on request. ;)
PostPosted: Thu Oct 12, 2017 2:34 am
I will check it out, thanks!
Dan
Dan Werner
