Wait state for 3.6mhz
Re: Wait state for 3.6mhz
Hi Braincell1973!
Clarify please,
what signals are applied to inputs P0 - P7 of IC5 and IC6?
What jumpers should be shorted?
Vladimir
Clarify please,
Vladimir
Braincell1973
Hi Vladimir.
The address lines 8 to 15 connect to P
The links select IO page befor the 138 chops the page into 32 bytes x 8
FC00 is 1111 1100 on links
FD00 is 1111 1101 on links
Lee
Lee
Outputs of IC2a and IC2b are connected together (totem-pole output stages!). This is unacceptable.
Braincell1973
Lee
Braincell1973 wrote:
What if i used open collector ? 74ac05 instead ?
Lee
Braincell1973
Using ac chips total delay should be less than 50ns at 5v ?
Unless i misread datasheets maybe ?
Lee
Lee
- GARTHWILSON
- Forum Moderator
Open-collector slows things waaaaaay down. The rise time's time constant is the resistor value times the capacitance of the load. Let's say there's 25pF from the connected loads (including output pins), the traces, and sockets. Then let's say you use a 3.3K pull-up resistor. 3.3K times 25pF is 82ns. Putting another gate in, if necessary, would be far better.
While I'm here, I seem to remember a mention of 4000-series logic earlier. Those are super slow too, unless you use something like 74HC4xxx (and even then, some of those are still pretty slow). Otherwise, 4000-series is best left for the times when you need higher voltage (like 12V) and speed is not important.
Braincell1973
Thanks for clarifying that chaps . Will look at alternatives to tying the outputs together.
I need to do some reading up
I guess i can do the adressing with just 1 more OR gate / ic.
Apart from the wired logic do you think the addressing is otherwise good ??
Lee
Lee
Lee
For example, if you select ROM or HIRAM, A15 must be HIGH. Right? But, at A15= HIGH your IC2c asserts /LORAMSELECT. Isn't it ?
Really, A15 and /LORAMSELECT should be the same, without any inverting.
Further. If IO is selected, the output of 74AC520 is LOW. Keep this in mind.
One more thing. It seems, you want /HIGHRAMSELECT to be in range $8000 ÷ $BFFF ( i.e. A15=HIGH and A14=LOW). But, I see, you did not do it. At SJ1 = 2-3 your /HIRAMSELECT becomes active for range $0000 - $7FFF. At SJ1 = 1-2 the range becomes $0000 - $BFFF.
And so on. You have something to think about.
Vladimir
P.S. Tell me please (if it is not a secret), what do you benefit from the opportunity to change the basic addresses of IO peripherals? I believe, permutation of any jumper entails the need to rewrite the IO routines. Isn't it?
P.P.S. A8 signal harms the working of AC138 decoders (at least of second one, IC4). Don't route it there. G2A inputs should be grounded. G1 inputs of AC520 likewise.
Braincell1973
Hi Vladimir.
You are very correct. I used my lunchtime today to download wincupl and using an atf16v8b gal i can do all the address decoding i think.
Will post sim acreenshot soon as i think i got this right now but never used wincupl or any pld before today
As learning digital logic and assembler may as learn a bit about gals too.......
Yes moving the io maps are pointless so will hard code 2 pages (16ios) using the gal.
What do you mean about the a8 ? I need to decode 32byte pages ?
Hi Lee!
Sorry for slow reply. (BTW, we live in different time zones. This is not conducive to comfortable communication).
I read some reports about problems with ATMEL SPLDs (including ATF16V8). Specifically, not any GAL programmer copes with such devices. Lattice equivalent (i.e. GAL16V8) is reputedly more preferable.
At least, you ought to make sure your programmer is suitable for those devices.
I do not understand, wich a need forces you to connect address line A8 to AC138 decoders? I see, A8 is connected to pin 4 of each AC138. What for?
I have a slight suspicion that you do it incorrectly sketched from somewhere. Perhaps there was an address line connected to different inputs of AC138 decoders, for example, to pin 6 and pin 4. Isn't it?
Vladimir
... I used my lunchtime today to download wincupl and using an atf16v8b gal i can do all the address decoding i think...
Vladimir
Braincell1973
Hi Vladimir,
I can now see why you have said this, after trying to use WINCUPL i found your posts on here referencing the "FIELD" statement.But the ideas came from Daryl Rictor's website for me to use a GAL as a quick look at his source code made it look simple enough to program a GAL (I have a tl866cs somewhere).
Here is the revised decoding logic using an atf16v8b,
2 pages for IO at FE00 and FD00 each with 8x 32 byte access
16k ROM
48k RAM
There is enough space to do the read / write qualifying too
Lee
16k ROM
48k RAM
Name address1 ;
PartNo 001 ;
Date 04/11/2016 ;
Revision 01 ;
Designer Engineer ;
Company Na ;
Assembly None ;
Location None ;
Device g16v8a ;
PIN 2 = A8 ; /* */
PIN 3 = A9 ; /* */
PIN 4 = A10 ; /* */
PIN 5 = A11 ; /* */
PIN 6 = A12 ; /* */
PIN 7 = A13 ; /* */
PIN 8 = A14 ; /* */
PIN 9 = A15 ; /* */
PIN 12 = PHI2 ; /* */
PIN 13 = RW ; /* */
PIN 19 = !IO1 ; /* */
PIN 18 = !IO2 ; /* */
PIN 17 = !ROMSEL ; /* */
PIN 16 = !RAMSEL ; /* */
PIN 15 = !WE ; /* */
PIN 14 = !OE ; /* */
/* *************** LOGIC *********************/
FIELD ADDRESS = [A15..8] ;
IO1 = ADDRESS:[FD00] ;
IO2 = ADDRESS:[FE00] ;
ROMSEL = ADDRESS:[C000..FCFF]
# ADDRESS:[FF00..FFFF] ;
RAMSEL = ADDRESS:[0000..BFFF] ;
OE = (PHI2 & RW) ;
WE = (PHI2 & !RW) ;Lee
Hi Lee!
The most important thing that I can see, this decoder should be workable.
An other thing I noticed (looking at your screenshot) that you should familiarize yourself with MPU timing diagram. Not all sets of input levels that you do WinSimulate exist in a real system. Nevertheless, the decoder should operate, therefore you can blow off the dust from your programmer and try burning PLD.
Vladimir
Vladimir
Braincell1973
After looking at the gal programs on Daryl Rictors site and the multicomp from grant searle i thought the easiest thing for me to do was start with the multicomp design....
So, I have drawn up a board based on the multicomp cyclone 2 board from ebay.
Added 2 sockets for ram -as6c4008 and a combined rom/ram socket
Expansion bus
Multicom bits ie 2off serial . Sd card . Comp / vga video . Ps2 keyboard
Added max3232 for serial 1
And finally added a ch376 port for the usb boards from ebay.
I have some ideas for a simple MMU and other cool bits
Lee
Expansion bus
Lee
