Understanding the SID
ttlworks
Re: Understanding the SID
Post by ttlworks »
Oscillator register, even bits:
Oscillator register, odd bits:
Frequency register, even bits:
Frequency register, odd bits:
Odd thing is, that the SID really has three 8 bit frequency registers per oscillator channel.
When the CPU writes a byte into frequency register latches bit 15..8,
frequency register latches bit 23..16 are written with '0'.
drfiemost
Post by drfiemost »
The width and length of a transistor directly relates to on-resistance, so it sounds like the 8-series part has a weighting function applied to the inputs - does that fit the facts?
Ah yes, I can see a reason for this. When both triangle and sawtooth switches are active the current will flow mostly to the output as the sawtooth transistor is bigger, offering less resistance. This way, if the noise switch is active too, there would be less chances for feedback into the LFSR reducing the risk for lockups. And the lower four bits are not connected to the noise register so those would not cause any problem.
Still I can't explain the wider transistors...
I think that the muffled sound for combined waveforms and noise lockups were two of the problems that Rob Yannes tried to address in the newer chip model.
Is there any general knowledge that the relative loudness of the triangle vs the sawtooth changed when the chip changed from 6-series to 8-series?
drfiemost
Post by drfiemost »
As far as I can remeber there is no mention of something like this anywhere. I can try to make some samplings and see if there is a difference of amplitudes between waveforms. But I'm wondering... isn't the signal still digital at this point?
Oh - maybe it is!
ttlworks
Post by ttlworks »
Generation of osc_rst drawn a bit different:
Generation of osc_rst, this time with logic gates:
V3 is bit 23 from oscillator 3 latch which goes into
osc_rst generation of oscillator 1:
I now feel a need to mention that the inverters I did draw at the outputs
of the oscillator odd bit latches actually are located at the north east
corner of an oscillator adder cell, decided to draw it this way
because IMHO this is helpful to understand the adder from the
logic design point of view.
This means that the oscillator is reset when test bit is set or when sync bit is set
and the sync source voice's MSB switches from low to high.
Exactly like that.
ttlworks
Post by ttlworks »
Now to take a look at the pulse width stuff.
Pulse with latches, even bits:
Pulse with latches, odd bits:
The pulse width comparators are nothing but a carry chain
like in the 7480... with the sum logic missing, of course.
The concept goes like this:
the adder does osc_23..12 + /pw_11..0 + 1.
Means, the carry input of the lowest bit of the adder is tied to 5V.
Because pw_11..0 is inverted before it is passed into the adder
(ones complement), and we also add 1, the adder calculates
osc_23..12 - pw_11..0.
The CMP instruction in the 6502 works somewhat similar,
so the carry output of that adder carry chain is
'0', if osc_23..12 < pw_1..0.
Else, it is '1'.
Generation of 'pulse':
If carry=1, or if test=1, then pulse=1 (what would set the DAC to $FFF).
drfiemost
Post by drfiemost »
Did a sampling of the output of both chips for every possible waveform. Selecting the noise along with other type of waves produces no output so the pictures show only the following combinations:
  1. Triangle
  2. Sawtooth
  3. Triangle+Sawtooth
  4. Pulse
  5. Triangle+Pulse
  6. Sawtooth+Pulse
  7. Triangle+Sawtooth+Pulse
  8. Noise
6581:
8580:
There is no substantial difference in the amplitude between Triangle and Sawtooth in the 8580. It is interesting to note however that combinations which include both Sawtooth and Triangle are much louder in the newer model and that there is a small DC drift when passing from wave 5 to 6 in the 6581.
In other news I've fitted the transistor list into the perfect6502 emulation engine and the results look good, confirming the validity of the work done so far :). There is only one of the three voices implemented and the emulation covers only the digital behaviour of transistors. If anyone want to have a look the code is available in the libsidplayfp repository (https://sourceforge.net/p/sidplay-resid ... rfect6581/)
Thanks for publishing your code - more transistor-level modelling is always a good thing!
ttlworks
Post by ttlworks »
Generation of TriXOR:
From the logic design point of view, it looks like V3 really gets inverted there...
but I don't know, why.
Generation of the Saw_bits:
ttlworks
Post by ttlworks »
Now for the bus interface.
First the circuitry which generates the internal inverted and non_inverted address lines
Ax_low and Ax_high from the external Ax address bus.
It makes creative use of super buffers:
From the logic design point of view, it's something like this:
If sid_rst = 1, then Ax_high = 0 and Ax_low = 0.
Else, Ax_high = Ax and AX_low = /Ax.
The circuitry which generates /read and /write also makes creative use of super buffers:
Logic design point of view:
For write cycles, the falling edge of R/W is delayed.
//Considering the C64 bus timing, it would be interesting to compare the 6522 and 6526 bus interface...
Note, that /write is forced to '0' if sid_rst = 1.
When taking a look at the data bus buffers later, it becomes evident that the internal data bus
is forced to $00 while sid_rst = 1.
So during a RESET, if sid_rst = 1, all the NOR address decoder gates tied to /write
will go active because all their address inputs are 0.
This forces a write of $00 into _all_ of the registers that could be written from the bus.
Nice trick.
Now a code snippet from vice 2.4 > resid > resid.cc
// Write registers.
// Writes are one cycle delayed on the MOS8580. This is only modeled for
// single cycle clocking.
void SID::write(reg8 offset, reg8 value)
  write_address = offset;
  bus_value = value;
  bus_value_ttl = 0x4000;
  if (sid_model == MOS8580) {
    // One cycle pipeline delay on the MOS8580; delay write.
    write_pipeline = 1;
  else {
    // No pipeline delay on the MOS6581; write immediately.
    write();
But after dissecting the bus interface circuitry of 6581R3 and 8580R5,
I'd say that the bus interfaces just have different geometries,
but they seem to be identical at transistor level from the
In other words: we were unable to find any proof that there might be something
like a one cycle write delay on the 8580.
Also, vice 2.4 resid source code implicates, that when writing a register,
the byte also stays on the internal data bus, and if you try to read a register
that can't be read you are just "getting that byte back".
But after $2000..$4000 clock cycles, bits that were 1 on the internal data bus
are "fading" to 0.
BTW: don't get confused by the overly simplified schematics from the logic point of view above,
they are just there to show how things are working in general.
Trying to build a 6502 compatible bus interface for a peripheral chip can give you some grey hairs,
especially when trying to aim for speed.
When I did an experimental TTL implementation of the 6522... but I'm getting off topic. :)
ttlworks
Post by ttlworks »
Buffer from external data bus Dx to internal data bus DBx for writing registers:
Note, that sid_rst = 1 places $00 on the internal data bus DBX if /write = 0
for writing all registers that can be written from the bus with $00 at RESET.
Buffer from internal data bus DBx to external data bus Dx for reading registers:
ttlworks
Post by ttlworks »
The register which reads the upper 8 Bits of the Osc 3 DAC output:
One bit of the three control registers:
IMHO they just had to build it that way because capacitive load on the CTLx lines could be big...
if a CTLx line drives 12 waveform switches, for instance.
I think the flipflop won't work reliable when connecting CTLx directly to the output
of the second inverter which holds the bit in the flipflop if sid_clk1 = 1.
ttlworks
Post by ttlworks »
Now for the DAC buffer:
It's a _digital_ non_inverting buffer,
built from a normal inverting buffer and an inverting super buffer.
Means, we could assume that the buffer gives out either nearly 0V, or nearly 5V.
"Nearly" depends on the on_resistance of the FETs at the output and the output current.
For the input, I think we could assume a treshold between 0.8V..2.0V,
where "treshold" is the turning point between low and high.
Waveform selectors:
Evil. Eeevil...
In the 8580, osc_23 is buffered by a flipflop before it enters that "Sawtooth" switch.
In the 6581, it is not.
The Pulse line which is switched to the DAC buffer inputs in pulse width mode
has a push/pull output, while everything else that could be switched to the
DAC buffer inputs just has a pullup plus an open drain FET switching to GND as an output.
Means, on the 6581, it might be possible that if the "Sawtooth" and "Pulse"
selector switches are closed, the Pulse line might probably override the output
of the osc_23 flipflop... causing _really_ odd effects.
BTW: in the 6581 and the 8580, the noise selector switches really connect to
the LFSR bits 0,2,5,9,11,14,18,20 in the same order. Checked this...
drfiemost
Post by drfiemost »
One of those nasty side effects is that if the pulse is pulling the output low it will force a zero in the oscillator's adder MSB even if the bit is high, thus resetting the top bit in the following cycle.
