Okay.. on this page here: http://wilsonminesco.com/6502primer/addr_decoding.html
It shows decoding of RAM and ROM using NAND gates and inverters. I can see how to 'wire up' my lowest 32k of Static Ram, and.. I assume that if I wanted to wire up say, the next 16k of ram (8000h to BFFFh) I'd just use another few gates and inverters so that at the input of another NAND gate, the Phase 2 Clock would be '1' at the same time the Bank-Selection circuitry for A15 and A14 were properly 'active'? e.g when A15=1 and A14=0?
Sorry if this sounds like a 'stupid' question.. but for some reason i'm having a bit of a hard time wrapping my mind around the whole thing what with the Phase 2 clock needing to be high at the same time certain address lines are selected.. maybe my mind is just rusty with boolean logic after so many years of not making tables like this?
Newbie-ish ROM and RAM decoding question
Re: Newbie-ish ROM and RAM decoding question
Garth's schematic is good if you want a minimal system with minimal parts, but if you want a bit more advanced address decoding, I would recommend removing the PHI2 qualification from your address decoding, and instead add it to the Write Enable logic to your SRAM. That way, it is kept separate from the address decoding, and makes both simpler to understand. There are several older threads dealing with this subject. for example viewtopic.php?f=4&t=2449
- BigDumbDinosaur
dracosilv wrote:
Okay.. on this page here: http://wilsonminesco.com/6502primer/add ... html...I'd just use another few gates and inverters so that at the input of another NAND gate, the Phase 2 Clock would be '1' at the same time the Bank-Selection circuitry for A15 and A14 were properly 'active'? e.g when A15=1 and A14=0?...I'm having a bit of a hard time wrapping my mind around the whole thing what with the Phase 2 clock needing to be high at the same time certain address lines are selected.
Be sure to heed Arlet's advice about not using the Ø2 clock as part of the decoding logic, essential with 65xx devices, such as the 65C22 and 65C51, which must be selected before the rise of the clock. Also, as Arlet advised, use Ø2 to qualify read/write accesses. This is especially important on writes, as the data bus may contain random content during Ø2 low. See below.
Note that Ø2 qualification of read/write accesses applies only to non-65xx devices. 65xx devices should have their RWB inputs directly connected to the microprocessor's RWB output.
- GARTHWILSON
- Forum Moderator
A bit of clarification, It wasn't the FACT of the clock being high/low to signify the read/writes.. it was more the juggling of the r/w AND the clock being in a certain state AND the address logic, creating, well.. a logiclal nightmare in my slightly sleepy-ish brain.
randallmeyer2000
Good question. It seems I've neglected such considerations as well. Thanks for asking the question, it saves me the bother, and I get to look over my design in light of this new/old information.
randallmeyer2000
I am especially uncertain about the 65C22. I guess it might have helped if I coded "in the old days"; or for that matter, now. I suppose I should put together a plan for my PCB clock circuit (and gather the parts too!).
With regard to I/O, I think Garth's plan ( http://wilsonminesco.com/6502primer/pot ... ml#BAS_CPU ) seems wisest to me. Generic pin headers. That way, any ol' connector might be interfaced. I might also make certain there's some kind of I2C bus, too. I think I saw some nifty I2C connectors on a thread here, somewhere. As a minimal system, that should suit my needs.
I don't think the Phi2 thing mentioned affects me? I think I just used 74HC138s and a 74HC311?( 3-input AND); I don't think that will cascade too much and mess with clock or synchronization. bUt I just read the sentence "You must have a way of making sure microprocessor cannot write to RAM while Phi2 is low" and now I must read that section again!
I still have to put some R/W lines and OE and CE and other things on my PCB plan. Being new to this, I definitely need to look at all the timing diagrams (I am no stranger to music, symphonies, orchestration and such! Should be easy!).
I have become sidetracked, today, by physics. Still curious about light computers and Moore's Law. Seems not all speeds of light are equal (hahaha! I knew that; index of refraction is ratio of speeds of light). I know you 6502-ers like new projects. Any 6502 optical-instantiations out there? (just 3,500 transistors, right? https://commons.wikimedia.org/wiki/File ... S_6502.jpg ). Maybe I'll leaf through my Edmund Optics catalog and try to build one for less than $1000 (optics are EXPENSIVE!). I guess I am OT (off topic), but the subject of delay is on my mind.
(In the following table, c refers to the speed of light in a vacuum,
or 300,000 kilometers per second.
Medium Propagation Speed
Thick Coax .77c (231,000 km/sec)
Thin Coax .65c (195,000 km/sec)
Twisted Pair .59c (177,000 km/sec)
Fiber .66c (198,000 km/sec)
AUI Cable .65c (195,000 km/sec) )
http://stason.org/TULARC/networking/lan ... ltIAL-YG5I
And:
https://en.wikipedia.org/wiki/Velocity_factor
VF% Transmission line
95-99 Open-wire "Ladder" Line
80 Belden 9085 twin-lead
82 RG-8X Belden 9258 coaxial cable (foamed polyethylene dielectric)
66 RG-213 CXP213 coaxial cable (solid polyethylene dielectric) "
And:
https://en.wikipedia.org/wiki/Fiber-opt ... ord_speeds
In 2013, New Scientist reported that a team at the University of Southampton had achieved a throughput of 73.7 Tbit per second,
with the signal traveling at 99.7% the speed of light through a hollow-core photonic crystal fiber.[14] "
And:
And:
- GARTHWILSON
- Forum Moderator
- BigDumbDinosaur
- BigDumbDinosaur
