As usual, you are likely correct on this issue, but I would not have gotten the fig-FORTH kernel running if was not relocatable. Since to be relocatable requires relative offsets, I think that is a benefit to the fig-FORTH model. Most older processors like the 6502/65C02 do not provide good support for relative addressing. What support for relative addressing they do provide is in a form that's not generally available for direct use by the FORTH VM, i.e. native 8-bit relative conditional/unconditional branch instructions.
When I looked at the BRANCH and 0BRANCH words of the fig-FORTH model, there are a lot of FORTH VM operations being performed to synthesize the relative branches used in the fig-FORTH kernel. That process is expensive in terms of native machine instruction cycles due to the repeated use of DOCOL (ENTER) and NEXT to advance the FORTH VM through the code.
Some time ago, I extended the M65C02A instruction set to include the BRA rel16 and the PHR rel16 instructions. Thus, with the incorporation of the FORTH VM registers, IP and W, (per your recommendation, or more accurately, with your prodding
I have been considering implementing this support by overloading the IND prefix instruction. If IND is applied to the native Bcc rel8 instructions, the microprogram will implement Bcc [IP++] rather than the normal Bcc [PC++].
PS: Thanks for the congratulations.
All:
Have a safe and happy New Year's and we'll communicate again next year.
