Druzyek wrote:
... By the way, is there a reference anywhere that would show what op codes are doing internal operations when? If it is not that many, maybe I can have the microcontroller look out for them.
Do you mean a document that shows what's going on during each cycle? Something like this?
Instructions accessing the stack
BRK
# address R/W description
1 PC R fetch opcode, increment PC
2 PC R read next instruction byte (and throw it away),
increment PC
3 $0100,S W push PCH on stack, decrement S
4 $0100,S W push PCL on stack, decrement S
5 $0100,S W push P on stack (with B flag set), decrement S
6 $FFFE R fetch PCL
7 $FFFF R fetch PCH
RTI
3 $0100,S R increment S
4 $0100,S R pull P from stack, increment S
5 $0100,S R pull PCL from stack, increment S
6 $0100,S R pull PCH from stack
RTS
4 $0100,S R pull PCL from stack, increment S
5 $0100,S R pull PCH from stack
6 PC R increment PC
