GAL Address Decoder
Re: GAL Address Decoder
banedon wrote:
Thanks for advising as I may have wasted a lot more time on using FIELDs.
I know that WinCUPL is free software so I shouldn't complain, but you'd think that they'd fix such an obvious and important bug?
You'd think, seeing as how WinCUPL or something like it is needed to write programs for Atmel devices.
Unless perhaps it's device specific?
There appears to be no correlation between device type and the problem with FIELD statements. I'm of the opinion that it is a bug in WinCUPL, which software has not seen any attention in more than 10 years.
[EDIT] I've emailed Atmel to see what they say. Not sure it'll do any good, but they might be able to shed a little light.
When I communicate with Atmel it is with Alan Wong: alan.wong@atmel.com. Frankly, I think it's a waste of time communicating with them. They don't seem to be the least bit interested in straightening out WinCUPL.
Looks like there's an odd feature that variables which end in digits are used as column indices. See
http://www.edaboard.co.uk/help-with-atf ... 00493.html
which says you either need to align your table data very carefully in the right columns, or use variable names which don't end in digits.
That's correct. I tripped over that several times before finally figuring out that WinCUPL attaches some kind of significance to trailing numerals in variable names.
Another one of WinCUPL's obscure bugs has to do with case-sensitivity. Officially, CUPL as developed by Logical Devices Inc. is case-sensitive for variable names. Given that, one would think that via_sel and VIA_SEL would be seen as two unrelated variables. That's not the case with the simulator function associated with WinCUPL, as I discovered early on. An example program that I wrote would compile but not simulate, with the simulator reporting errors that made no sense. Here's the reply I got from Atmel:
  • The WinSim issue seems to be caused by the use of “wd” and “WD” in the CUPL design file. I tried changing “WD” to “WD_t” and that fixed the WinSim problem.
    Hope this will help you solve the problem. Please feel free to contact us at pld@atmel.com if you have any Atmel PLD related inquiries.
    Best regards,
    Alan Wong
    CSP Applications Manager / Atmel Corporation
    Tel: (+1) (408) 436-4156 / Fax: (+1) (408) 487-2538
    Alan.Wong@atmel.com / http://www.atmel.com
banedon
Post by banedon »
Here's the results of my decoder under simulation - all looks fine:
The data it ran with:
Name     AddressDecoder;
PartNo   Lattice22V10B;
Date     02/04/15;
Revision 01;
Designer shalewyn.com;
Company  shalewyn.com;
Assembly XXXXX;
Location XXXXX;
Device   g22v10;
ORDER: PHI2, R_W, A15, A14, A13, A12, A6, A5, A4, sb0, sb1, !RD, !WR, !IO, !BASERAM, !SWAPBANK0, !SWAPBANK1, !SWAPBANK2, !SWAPBANK3, !ROM;
VECTORS:
1 1   0 0 0 0   1 1 1   0 1   * *   *  *  * * * *  *
1 0   0 1 1 0   1 1 1   1 1   * *   *  *  * * * *  *
0 0   1 0 0 1   1 0 1   0 1   * *   *  *  * * * *  *
1 1   0 0 1 1   0 0 1   1 0   * *   *  *  * * * *  *
1 0   0 1 0 1   1 0 1   0 0   * *   *  *  * * * *  *
1 1   1 0 1 1   0 1 1   0 0   * *   *  *  * * * *  *
0 1   0 0 0 0   0 0 1   1 1   * *   *  *  * * * *  *
1 1   1 1 1 1   1 0 1   1 0   * *   *  *  * * * *  *
cbscpe wrote:
...As for bankswitching, sometimes you want to copy data from one bank to the other, therefore I would introduce 4 bankswitching signals, one set of 2 signals that control the bank you read from and 2 signals that control the bank you write to
R15     =  !A15 & !A14 & A13 & sb0r &  RW
        #  !A15 &  A14       & sb0r &  RW
        #  !A15 & !A14 & A13 & sb0w & !RW
        #  !A15 &  A14       & sb0w & !RW
R15     =  !A15 & !A14 & A13 & sb1r &  RW
        #  !A15 &  A14       & sb1r &  RW
        #  !A15 & !A14 & A13 & sb1w & !RW
        #  !A15 &  A14       & sb1w & !RW
without creating select signals for the RAM you have plenty of free pins on your GAL...
That's an excellent idea, Peter. Many thanks :). I'll almost certainly implement it.
I'll also have a think on your other idea.
banedon
Post by banedon »
Ok here we are with the dual read bank, write bank implemented (Many thanks to Peter).
I get an odd error with this, though, when trying to simulate it. It seems to generate a parse error in the .SO file when compiled from WinCUPL. If I then go into the Simulator and compile it I end up with what I expected.
Here's the code and the data I ran it with. Can anyone else reproduce the error?
Partno     Lattice22V10B;
Date       02/04/15;
Revision   01;
Assembly   XXXXX;
Location   XXXXX;
Device     g22v10;
 * Lattice GAL 22V10B pinout, DIP, top view
 * I/CLK.[ 1     24 ].VCC
 *     I.[ 2     23 ].I/O/Q
 *     I.[ 3     22 ].I/O/Q
 *     I.[ 4     21 ].I/O/Q
 *     I.[ 5     20 ].I/O/Q
 *     I.[ 6     19 ].I/O/Q
 *     I.[ 7     18 ].I/O/Q
 *     I.[ 8     17 ].I/O/Q
 *     I.[ 9     16 ].I/O/Q
 *     I.[ 10    15 ].I/O/Q
 *     I.[ 11    14 ].I/O/Q
 *   GND.[ 12    13 ].I
 * $1000-$1FFF	BaseRAM	%0000 0000 0000 0000 - %0001 1111 1111 1111
 * $2000-$7FFF	SwapRAM	%0010 0000 0000 0000 - %0111 1111 1111 1111
 * $8010-$801F	VIA #1	(I/O)	%1000 0000 0001 0000 - %1000 0000 0000 1111
 * $8020-$802F	VIA #2	(I/O) 	%1000 0000 0010 0000 - %1000 0000 0001 1111
 * $8040-$804F	ACIA 	(I/O)	%1000 0000 0100 0000 - %1000 0000 0010 1111
 * $9000-$FFFF	ROM		%1001 0000 0000 0000 - %1111 1111 1111 1111
 * Inputs
/* Inputs */
PIN 1      = PHI2;
PIN 2      = R_W;
PIN [3..6] = [A15..12];
PIN [7..9] = [A6..4];
PIN 10     = sbR0;
PIN 11     = sbR1;
PIN 13     = sbW0;
PIN 14     = sbW1;
/* Outputs */
PIN 15     = !RD;
PIN 16     = !WR;
PIN 17     = !IO;
PIN 18     = !BASERAM;
PIN 19     = !SWAPBANK0;
PIN 20     = !SWAPBANK1;
PIN 21     = !SWAPBANK2;
PIN 22     = !SWAPBANK3;
PIN 23     = !ROM;
/* Main */
RD    = PHI2 &  R_W;
WR    = PHI2 & !R_W;
BASERAM	= !A15 & !A14 & !A13;
SWAPBANK0	= !A15 & !A14 &  A13 & !A12 & !sbR0 & !sbR1 & WR
 		# !A15 & !A14 &  A13 &  A12 & !sbR0 & !sbR1 & WR
		# !A15 &  A14 & !A13 & !A12 & !sbR0 & !sbR1 & WR
		# !A15 &  A14 & !A13 &  A12 & !sbR0 & !sbR1 & WR
		# !A15 &  A14 &  A13 & !A12 & !sbR0 & !sbR1 & WR
		# !A15 &  A14 &  A13 &  A12 & !sbR0 & !sbR1 & WR
		# !A15 & !A14 &  A13 & !A12 & !sbW0 & !sbW1 & !WR
 		# !A15 & !A14 &  A13 &  A12 & !sbW0 & !sbW1 & !WR
		# !A15 &  A14 & !A13 & !A12 & !sbW0 & !sbW1 & !WR
		# !A15 &  A14 & !A13 &  A12 & !sbW0 & !sbW1 & !WR
		# !A15 &  A14 &  A13 & !A12 & !sbW0 & !sbW1 & !WR
		# !A15 &  A14 &  A13 &  A12 & !sbW0 & !sbW1 & !WR;
SWAPBANK1	= !A15 & !A14 &  A13 & !A12 & !sbR0 &  sbR1 & WR
 		# !A15 & !A14 &  A13 &  A12 & !sbR0 &  sbR1 & WR
		# !A15 &  A14 & !A13 & !A12 & !sbR0 &  sbR1 & WR
		# !A15 &  A14 & !A13 &  A12 & !sbR0 &  sbR1 & WR
		# !A15 &  A14 &  A13 & !A12 & !sbR0 &  sbR1 & WR
		# !A15 &  A14 &  A13 &  A12 & !sbR0 &  sbR1 & WR
		# !A15 & !A14 &  A13 & !A12 & !sbW0 &  sbW1 & !WR
 		# !A15 & !A14 &  A13 &  A12 & !sbW0 &  sbW1 & !WR
		# !A15 &  A14 & !A13 & !A12 & !sbW0 &  sbW1 & !WR
		# !A15 &  A14 & !A13 &  A12 & !sbW0 &  sbW1 & !WR
		# !A15 &  A14 &  A13 & !A12 & !sbW0 &  sbW1 & !WR
		# !A15 &  A14 &  A13 &  A12 & !sbW0 &  sbW1 & !WR;
SWAPBANK2	= !A15 & !A14 &  A13 & !A12 &  sbR0 & !sbR1 & WR
 		# !A15 & !A14 &  A13 &  A12 &  sbR0 & !sbR1 & WR
		# !A15 &  A14 & !A13 & !A12 &  sbR0 & !sbR1 & WR
		# !A15 &  A14 & !A13 &  A12 &  sbR0 & !sbR1 & WR
		# !A15 &  A14 &  A13 & !A12 &  sbR0 & !sbR1 & WR
		# !A15 &  A14 &  A13 &  A12 &  sbR0 & !sbR1 & WR
		# !A15 & !A14 &  A13 & !A12 &  sbW0 & !sbW1 & !WR
 		# !A15 & !A14 &  A13 &  A12 &  sbW0 & !sbW1 & !WR
		# !A15 &  A14 & !A13 & !A12 &  sbW0 & !sbW1 & !WR
		# !A15 &  A14 & !A13 &  A12 &  sbW0 & !sbW1 & !WR
		# !A15 &  A14 &  A13 & !A12 &  sbW0 & !sbW1 & !WR
		# !A15 &  A14 &  A13 &  A12 &  sbW0 & !sbW1 & !WR;
SWAPBANK3	= !A15 & !A14 &  A13 & !A12 &  sbR0 &  sbR1 & WR
 		# !A15 & !A14 &  A13 &  A12 &  sbR0 &  sbR1 & WR
		# !A15 &  A14 & !A13 & !A12 &  sbR0 &  sbR1 & WR
		# !A15 &  A14 & !A13 &  A12 &  sbR0 &  sbR1 & WR
   		# !A15 &  A14 &  A13 & !A12 &  sbR0 &  sbR1 & WR
		# !A15 &  A14 &  A13 &  A12 &  sbR0 &  sbR1 & WR
		# !A15 & !A14 &  A13 & !A12 &  sbW0 &  sbW1 & !WR
 		# !A15 & !A14 &  A13 &  A12 &  sbW0 &  sbW1 & !WR
		# !A15 &  A14 & !A13 & !A12 &  sbW0 &  sbW1 & !WR
		# !A15 &  A14 & !A13 &  A12 &  sbW0 &  sbW1 & !WR
   		# !A15 &  A14 &  A13 & !A12 &  sbW0 &  sbW1 & !WR
		# !A15 &  A14 &  A13 &  A12 &  sbW0 &  sbW1 & !WR;
IO		=  A15 & !A14 & !A13 & !A12 & !A5 & !A4;
ROM		=  A15 & !A14 & !A13 &  A12
  		#  A15 & !A14 &  A13 & !A12
		#  A15 & !A14 &  A13 &  A12
		#  A15 &  A14 & !A13 & !A12
		#  A15 &  A14 & !A13 &  A12
		#  A15 &  A14 &  A13 & !A12
		#  A15 &  A14 &  A13 &  A12;
There .SI file:
Date     02/04/15;
Revision 01;
Assembly XXXXX;
Location XXXXX;
Device   g22v10;
ORDER: PHI2, R_W, A15, A14, A13, A12, A6, A5, A4, sbR0, sbR1, sbW0, sbW1, !RD, !WR, !IO, !BASERAM, !SWAPBANK0, !SWAPBANK1, !SWAPBANK2, !SWAPBANK3, !ROM;
VECTORS:
1 1   0 0 1 0   1 1 1   0 1   1 0   * *   *  *  * * * *  *
1 0   0 0 1 0   1 1 1   0 1   1 0   * *   *  *  * * * *  *
1 1   0 0 1 0   1 1 1   1 1   0 0   * *   *  *  * * * *  *
1 0   0 0 1 0   1 1 1   1 1   0 0   * *   *  *  * * * *  *
And my eventual results after recompiling from within the Simulator:
Confirmed as working (so far) in a GAL :)
[EDIT] I've just removed A5-A7 (pins 7-9) as they are not used. Frees up 3 pins for future use.
BitWise
In Memoriam
Post by BitWise »
The field command is used in their barrel shifter example for the 22V10 and compiles without complaint but it failed when I tried it. The parser must be very sensitive to case, names or layout of the commands but I don't have time to fathom it out.
Andrew Jacobs
8BIT
Post by 8BIT »
I know I'm kind of late, but I took up the problem with the FIELD and TABLE command and have it worked out I think.
Here's the source:
Date       02/04/15;
Revision   01;
Assembly   1;
Location   1;
Device     g22v10;
 *   I.[ 2     23 ].I/O/Q
 *   I.[ 3     22 ].I/O/Q
 *   I.[ 4     21 ].I/O/Q
 *   I.[ 5     20 ].I/O/Q
 *   I.[ 6     19 ].I/O/Q
 *   I.[ 7     18 ].I/O/Q
 *   I.[ 8     17 ].I/O/Q
 *   I.[ 9     16 ].I/O/Q
 *   I.[ 10    15 ].I/O/Q
 *   I.[ 11    14 ].I/O/Q
 * GND.[ 12    13 ].I
 * $1000-$1FFF   -   %0001 0000 0000 0000 - %0001 1111 1111 1111
 * $2000-$2FFF   -   %0010 0000 0000 0000 - %0111 1111 1111 1111
 * $8000-$800F   -   %1000 0000 0000 0000 - %1000 0000 0000 1111
 * $8010-$801F   -   %1000 0000 0001 0000 - %1000 0000 0001 1111
 * $8020-$802F   -   %1000 0000 0010 0000 - %1000 0000 0010 1111
 * $8040-$804F   -   %1000 0000 0100 0000 - %1000 0000 0100 1111
 * $9000-$FFFF   -   %1001 0000 0000 0000 - %1111 1111 1111 1111
 * !Pin 18 - non-swap RAM   $0000-$1FFF
 * !Pin 19 - Swap bank 0 or bank 1  - $2000-$7FFF
 * !Pin 20 - /VIA 1       - $8000-$800F
 * !Pin 21 - /VIA 2       - $8010-$801F
 * !Pin 22 - /ROM         - $9000-$FFFF
 * Inputs
Pin 1 = phi2;
Pin 2 = cpuRW;
Pin [3..11] = [A15..7];
Pin [13..15] = [A6..4];
Pin 16 = Swapbit;
 * Outputs
 * Pin 18 = !selBaseRAM;
 * Pin 19 = !selSwapRAMbank;
 * Pin 20 = !selVIA1;
 * Pin 21 = !selVIA2;
 * Pin 22 = !selROM;
 * Pin 23 = !WE out;
Pin [18..22] = [s0..4];
 * Main
FIELD AddressBus = [A15..4];
FIELD Selects = [s4..0];
TABLE AddressBus => Selects {
   [0000..01FF] => 'b'00001; /* S0 - Non-swap RAM */
   [2000..7FFF] => 'b'00010; /* S1 - Swap RAM */
   [8000..800F] => 'b'00100; /* S2 - VIA 1 */
   [8010..801F] => 'b'01000; /* S3 - VIA 2 */
   [8020..8FFF] => 'b'00000; /* none */
   [9000..FFFF] => 'b'10000; /* S4 - ROM */
I noticed a few things on your original post. The Selects field had 6 bits vs. 5, so I corrected that.
It also appears that it does not matter if I define Selects as [s4..0] or [s0..4], WinCUPL formats it as [s4..0].
The manual also said the default value is HEX so I removed the 'h' prefixes. The example in the manual also had a full
16-bit hex address even thought the AddressBus only had A15..A12 defined, so it must strip off any extra bits. That is why I used the
full 16-bit address in the table.
Here is the output from the Simulator (click to enlarge):
Vector 1 = $0000
Vector 2 = $2000
Vector 3 = $8000
Vector 4 = $8010
Vector 5 = $8020
Vector 6 = $8040
Vector 7 = $9000
Vector 8 = $FFFF
It appears correct in the simulation, I have not tried it on actual silicon.
banedon
Post by banedon »
Hi 8bit
Nice work. So it's just badly explained in the documentation or have I just misunderstood it? Either way, how would you go about adding the swap bank selects? They're comprised of 2 read bits (sbR0, sbR1) and 2 write bits (sbW0, sbW1). These can give a pattern of 00, 01, 10, 11 to gives 4 possible banks that can be read from and written to, but reading and writing can be to separate banks.
I was looking at the APPEND command for this, but I think that just adds an OR and then your code afterwards.
I.e. APPEND s0 = sbR0 & !sbR1; would simply add # (sbR0 & !sbR1); from what I understand. Where-as I would need to add something into the table itself...
Time for some experimentation!
banedon
Post by banedon »
Ok, the following seems to work. I've added in the bank control selects with appropriate inputs and restrictd the ability to write to a device until phi2 goes HI.
Date       02/04/15;
Revision   01;
Assembly   1;
Location   1;
Device     g22v10;
 *     I.[ 2     23 ].I/O/Q
 *     I.[ 3     22 ].I/O/Q
 *     I.[ 4     21 ].I/O/Q
 *     I.[ 5     20 ].I/O/Q
 *     I.[ 6     19 ].I/O/Q
 *     I.[ 7     18 ].I/O/Q
 *     I.[ 8     17 ].I/O/Q
 *     I.[ 9     16 ].I/O/Q
 *     I.[ 10    15 ].I/O/Q
 *     I.[ 11    14 ].I/O/Q
 *   GND.[ 12    13 ].I
 * $0000-$1FFF : %0000 0000 0000 0000 - %0001 1111 1111 1111 : Base RAM area
 * $2000-$7FFF : %0010 0000 0000 0000 - %0111 1111 1111 1111 : Swap RAM area
 * $8000-$8FFF : %1000 0000 0000 0000 - %1000 1111 1111 1111 : I/O area (VIAs, ACIAs, etc.)
 * $9000-$FFFF : %1001 0000 0000 0000 - %1111 1111 1111 1111 : ROM
 * Inputs
Pin 1 = phi2;
Pin 2 = cpuRW;
Pin [3..6] = [A15..12];
Pin 13 = SbR0;
Pin 14 = SbR1;
Pin 15 = SbW0;
Pin 16 = SbW1;
 * Outputs
/* s0 - NonSWAP RAM
 * s1 - Swap RAM bank 0
 * s2 - Swap RAM bank 1
 * s3 - Swap RAM bank 2
 * s4 - Swap RAM bank 3
 * s5 - I/O (VIAs, ACIAs, etc.)
 * s6 - ROM */
Pin [17..23] = ![s0..6];
 * Main
FIELD AddressBus = [A15..12];
FIELD Selects = [s6..0];
/* Note that each device which can be written to has 2 entries - one for reading and
 * one for writing. This is because writing should only ever happen when phi2 is HI
 * so we need one rule which allows read if cpuRW is HI and one rule which only
 * allows writes when cpuRW is LOW and phi2 is HI. */
   [0000..1FFF] => 'b'0000001 & cpuRW; 				/* S0 - Non-swap RAM read */
   [0000..1FFF] => 'b'0000001 & !cpuRW & phi2; 			/* S0 - Non-swap RAM write */
   [2000..7FFF] => 'b'0000010 & !SbR0 & !SbR1 & cpuRW; 	/* S1 - Swap RAM read bank 0*/
   [2000..7FFF] => 'b'0000100 & !SbR0 & SbR1 & cpuRW; 		/* S2 - Swap RAM read bank 1 */
   [2000..7FFF] => 'b'0001000 & SbR0 & !SbR1 & cpuRW; 		/* S3 - Swap RAM read bank 2 */
   [2000..7FFF] => 'b'0010000 & SbR0 & SbR1 & cpuRW;		/* S4 - Swap RAM read bank 3 */
   [2000..7FFF] => 'b'0000010 & !SbW0 & !SbW1 & !cpuRW & phi2;/* S1 - Swap RAM write bank 0 */
   [2000..7FFF] => 'b'0000100 & !SbW0 & SbW1 & !cpuRW & phi2; /* S2 - Swap RAM write bank 1 */
   [2000..7FFF] => 'b'0001000 & SbW0 & !SbW1 & !cpuRW & phi2; /* S3 - Swap RAM write bank 2 */
   [2000..7FFF] => 'b'0010000 & SbW0 & SbW1 & !cpuRW & phi2;	/* S4 - Swap RAM write bank 3 */
   [8000..8FFF] => 'b'0100000 & cpuRW; 				/* S5 - IO read */
   [8000..8FFF] => 'b'0100000 & !cpuRW & phi2;			/* S5 - IO write*/
   [9000..FFFF] => 'b'1000000; 					/* S6 - ROM */
Test results
Date     02/04/15;
Revision 01;
Assembly 1;
Location 1;
Device   g22v10;
ORDER: phi2, cpuRW, A15..A12, SbR0, SbR1, SbW0, SbW1, !s0, !s1, !s2, !s3, !s4, !s5, !s6;
VECTORS:
/* each test comprises of a set of read and a set of writes.
* 1st test is for PHI2 being HI and the 2nd for PHI being LOW */
/* Base RAM test 2xRead, 2xW1rite */
11 '1' 0110*******
01 '1' 0110*******
10 '1' 0110*******
00 '1' 0110*******
/* Swap RAM bank 1 read, bank 2 write tests 2xRead, 2xWrite */
11 '2' 0110*******
01 '2' 0110*******
10 '2' 0110*******
00 '2' 0110*******
/* Swap RAM bank 3 read, bank 0 write tests 2xRead, 2xWrite */
11 '2' 1100*******
01 '2' 1100*******
10 '2' 1100*******
00 '2' 1100*******
/* I/O test 2xRead, 2xW1rite */
11 '8' 1100*******
01 '8' 1100*******
10 '8' 1100*******
00 '8' 1100*******
/* ROM test 2xRead */
11 'F' 1100*******
01 'F' 1100*******
banedon
Post by banedon »
And finally here's the 1Mbit RAM IC version. This one doesn't use 4 different modules, but utilises a 1Mbit (128KB) RAM. It splits the IC into quarters, maps banks 0-3 to each quarter by controlling A15 and A16 address pins.
Base RAM sits in the first quarter (bank 0).
Memory map now looks something like this:
Total RAM space is:
24KB x 4 banks = 96KB + 8KB base RAM = 104KB Total RAM
Additionally, you have 4KB of I/O address space and 28KB of ROM space for the OS.
Total addressable space (by cheating)? 136KB. Not too shoddy.
Please see attached for the .PLD and .SI files (I had to rename them as TXT so I cold upload them to the forum):
[EDIT] Now changed to be compatible with the 65C816 (thanks BigD :))
ADDRESSDECODER_PLD.TXT
(4.2 KiB) Downloaded 118 times
ADDRESSDECODER_SI.TXT
(514 Bytes) Downloaded 104 times
My next step is to drop this into a 4Mbit SRAM and also find a way of possibly using the slack 8KB lost in each bank area except bank 0 (i.e. +$0 to +$1FFF).
If it were me, I would also qualify reads with Ø2 so your design is 65C816 compatible.
banedon
Post by banedon »
Sounds good to me. I don't know much about the 65C816, but I can't see this hurting one bit. Thanks :). One moment while I make the adjustment.
The reason for my suggestion is that the '816 is driving the data bus with the bank bits when Ø2 is low during a valid memory cycle. You wouldn't want another device trying to drive the data bus at that time.
banedon
Post by banedon »
OK all done. Thanks for the explanation with regards to the bank bits.
After I've experimented with using the 65C02 I'm then going to try my hand at the 65C816 (I've got a few already).
banedon
Post by banedon »
A related question:
I'm going to use a TI SN74HC259N addressable latch to set SBR0,SBR1,SBW0,SBW1 (the lines connect to the Address Decoder and are used to determine which RAM bank to use). The latch is controlled by a 65C22S VIA.
As part of the 65C02 reset code I plan to bring the above lines LOW so that initially all RAM access is to bank 0. Before this happens I have a concern that the lines will be floating and might possibly end up selecting the wrong RAM bank.
This shouldn't really be a concern as the address will determine that the base RAM is used. However, in principle should I bother tying the outputs of the latch low via 4K7 resistors? I.e. is it good practice or even necessary?
