Sources for the '816 core are in Github: http://github.com/robfinch/Cores/tree/m ... T816/trunk
There is a sample LED/Switch test system called FT816Sys.v as a top module.
Next level is an mpu module which has chip select decoding, call FT816mpu.v
Next level down is the cpu itself FT816.v
cpu W65C816S
.org $E000
start:
clc ; switch to '816 mode
xce
rep #$30 ; set 16 bit regs & mem
ndx 16
mem 16
lda #$0070 ; program chip selects for I/O
sta $F000 ; at $007000
lda #$0071
sta $F002
ldy #$0000
.st0001:
ldx #$0000
.st0002:
inx
bne .st0002
lda $7100
sta $7000
iny
bra .st0001
.org $FFFC
dw $E000
