It is currently Sun Nov 10, 2024 7:32 pm
Post new topic Reply to topic  [ 72 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: FT816 Core
PostPosted: Thu Nov 27, 2014 8:37 am
Work has been started on a 65c816 compatible core called FT816. I've managed to get a small test program working for it.
Sources for the '816 core are in Github: http://github.com/robfinch/Cores/tree/m ... T816/trunk
There is a sample LED/Switch test system called FT816Sys.v as a top module.
Next level is an mpu module which has chip select decoding, call FT816mpu.v
Next level down is the cpu itself FT816.v
   cpu      W65C816S
   .org   $E000
start:
   clc               ; switch to '816 mode
   xce
   rep      #$30      ; set 16 bit regs & mem
   ndx    16
   mem      16
   lda      #$0070      ; program chip selects for I/O
   sta      $F000      ; at $007000
   lda      #$0071
   sta      $F002
   ldy      #$0000
.st0001:
   ldx      #$0000
.st0002:
   inx
   bne      .st0002
   lda      $7100
   sta      $7000
   iny
   bra      .st0001
   .org   $FFFC
   dw      $E000
http://www.finitron.ca
 Post subject: Re: FT816 Core
PostPosted: Thu Nov 27, 2014 12:54 pm
Rob:
Thanks for sharing. Had a look at the project. There's certainly a lot of work that's already been done. I'm certainly looking forward to reading about your progress on this project.
Michael A.
PostPosted: Thu Nov 27, 2014 11:45 pm
I was able to make use of the '816 portion of a previous core (RTF65003) in order to speed development. Large parts of the core were 'already done' and working. One of the nice things about working in an HDL rather than with real chips, is it's easier to cut-and-paste. One can leverage the use of existing projects.
The core is fairly large, but it should fit into an slx9 or xc3s500 part (it's about 5000 LUTs). It's also fairly fast. I've got it running @64MHz. It outputs chip selects for slower memory and I/O parts, where the speed of the addressed area is controllable. 1/32, 1/4 clock rate are cs options.
PostPosted: Fri Nov 28, 2014 2:47 am
Rob:
I noticed that your approach made many of the address and ALU calculations in parallel. From that I gathered that you were optimizing for speed rather than area/size. I think that you are succeeding in meeting your apparent goal by getting the part to operate around 64MHz. I think it will make the core quite attractive, especially for the speed hounds among us.
I also saw that you were using a shift register for the clock divider. That's a nice touch. It is a simple and effective approach to get your 1/32 and 1/4 clocks for the addressed devices. It is certainly easier to maintain the speed of the core by using shift registers instead of counters for dividers. The extra logic required for counting and decoding is far less efficient than your shift register approach.
I noticed that you made an update earlier today. It appeared related to the return address differences between BRK traps, interrupts, and subroutine calls. I had thought about making my 65C02 core compatible with the idiosyncratic behavior of the 6502/65C02 for subroutine calls, BRK traps, and interrupts. Instead, I opted to make the return addresses for all three the same so that my RTS and RTI microroutines both increment the return address by 1 before the fetch of the instruction.
Is that what you were attempting to do, and if so, why not make RTS and RTI behave in a common manner with respect to the return address?
Michael A.
PostPosted: Fri Nov 28, 2014 6:33 am
Yes, that's a speed optimization, and also a coding simplicity optimization (development time). The core could probably be made more compact by making better reuse of some of the components.
I was worried about breaking existing software. I think I've got the behaviour the same as the 6502/65816. There are some pieces of software that pull and increment the return address. For instance to access inline parameters. It cost extra logic to remain 100% software compatible. One thing that's different is the PC increment. I think on the '816 only the low order 16 bits increment. In FT816 all 24 bits increment. This means that software that relies on wrapping around at the end of a bank is broken.
PostPosted: Sat Nov 29, 2014 7:32 am
Numerous bug fixes have taken place over the past couple of days. A sign the core is still in early development. But it is running code. An attempt to get strings to display onscreen is currently in progress. Clearscreen works but strings are coming out partially garbled.
Triple byte incrementing pointers are on the table tonight. On the 816 when the memory is set to 16 bits, data operations become 16 bit. That includes the memory based operations like INC and ROR. A nice to have feature would be triple-byte increments (24 bit) for zero page pointers. The question is how to implement. My thought is to have a range of zero page reserved that automatically responds to increment and decrement operations with 24 bit operations rather than 16 bit ones. Suppose the range was $20 to $2F. INC $20 would increment across three bytes ($20,$21 and $22), rather than two. It sounds simple to do, but it requires manipulating 24 bit values in the core. It might be nice to have 24 bit shifts / rotates as well.
PostPosted: Sat Nov 29, 2014 11:29 pm
When you mentioned triple-byte increments, I misunderstood, maybe, and pictured an operation performed byte-serially in three pieces. Doing it that way means if there's no carry you can take an early exit and save cycles (or one, at least). If the triple-byte value lives in 8-bit external RAM, that idea seems like a win. But I think you're anticipating Direct Page will be in on-chip RAM, is that right? So you can grab 24 bits at once? If 16 bits at once is easier, you could still break the 24-bit operation down into two pieces.
But I wonder whether, deep in its heart, FT816 wants to be a native 24-bit machine. (Or 32/24-bit.) I mean with downgraded 8/16-bit modes to match the 65816. :)
PostPosted: Sun Nov 30, 2014 2:21 am
Yes, the increment is byte serial. I modified the core to skip the store on a RMW instruction if the high-byte didn't change.
I think I'm scrapping the triple-byte increment mode, in favor of a couple of 24 bit counters I/O devices located in zero page. I coded the counters at the MPU level. Leaving the cpu alone. With the CPU clock so fast, 24 bit counters rather 16 would be more useful. It's also possible to trigger a count cycle in software, so the counters could be used as interpretive pointers as well. I have the one counter operating as a down counter to generate periodic interrupts. It takes 19 bits to divide down to 100Hz from the cpu clock.
I have to resist temptations on that one. The thought of full 24 bit registers did cross my mind.
I've managed to find some free opcode space in the 65816 instruction set - it's the branches. A branch displacement of $FF is a no-no, so the branch opcodes could be reused if the displacement is $FF, to mean something else. I've though of using them as prefix codes and maybe stealing some from Michael's cpu core.
PostPosted: Mon Dec 01, 2014 3:25 am
The $FF branch displacements have been allocated to long forms for the branches. Code below shows how it's working. Long branching has been put to use in a parser for terminal emulation. Long branching has been made a core parameter should it not be desired. The following code was assembled with the Finitron 65816 assembler.
   5306 00E0E0                             DisplayChar:
   5307 00E0E0 29 FF 00                        AND      #$0FF
   5308 00E0E3 24 3C                           BIT      EscState
   5309 00E0E5 30 FF 87 00                     LBMI   processEsc
   5310 00E0E9 C9 08 00                        CMP      #BS
   5311 00E0EC F0 FF 31 01                     LBEQ   doBackSpace
   5312 00E0F0 C9 91 00                        CMP      #$91         ; cursor right
   5313 00E0F3 F0 FF 7F 01                     LBEQ   doCursorRight
   5314 00E0F7 C9 93 00                        CMP      #$93         ; cursor left
   5315 00E0FA F0 FF 84 01                     LBEQ   doCursorLeft
   5316 00E0FE C9 90 00                        CMP      #$90         ; cursor up
   5317 00E101 F0 FF 86 01                     LBEQ   doCursorUp
   5318 00E105 C9 92 00                        CMP      #$92         ; cursor down
   5319 00E108 F0 FF 88 01                     LBEQ   doCursorDown
   5320 00E10C C9 99 00                        CMP      #$99         ; delete
   5321 00E10F F0 FF 35 01                     LBEQ   doDelete
   5322 00E113 C9 0D 00                        CMP      #CR
   5323 00E116 F0 44                           BEQ      doCR
   5324 00E118 C9 0A 00                        CMP      #LF
   5325 00E11B F0 44                           BEQ      doLF
   5326 00E11D C9 94 00                        CMP      #$94
   5327 00E120 F0 FF 46 01                     LBEQ   doCursorHome   ; cursor home
   5328 00E124 C9 1B 00                        CMP      #ESC
   5329 00E127 D0 05                           BNE      .0003
   5330 00E129 64 3C                           STZ      EscState      ; put a -1 in the escape state
   5331 00E12B C6 3C                           DEC      EscState
   5332 00E12D 60                              RTS
The FT816 test system runs Supermon816 but there are some display issues still. These are believed to be a software problem with the terminal emulation and not a softcore problem. That is not to say the core doesn't have bugs - the latest fix was to JMP (indirect) - but the core seems more stable the last day or so.
PostPosted: Mon Dec 01, 2014 6:16 am
The download version of SuperMon 816 has a WYSE 60 driver in it. The mumbo-jumbo that makes it work is well-commented and can be readily changed to support a different terminal type.
PostPosted: Mon Dec 01, 2014 7:34 am
How exactly does this work, Rob?
I don't know how your native mode works, so I have to ask the following (please forgive my ignorance if it's already been explained elsewhere):
1) The 8-bit BIT $3C instruction ANDs the value in A with the 8-bit value in $3C, using it to set or clear Z. It transfers the contents of bits 6 and 7 in $3C to V and N, respectively, right?
2) The 16-bit BIT $3C instruction would then AND the value in A with the 16-bit value in $3C and $3D, little-endian style, and use it to set or clear Z. It would then transfer the contents of bits 14 and 15 of the contents of $3C and $3D to V and N, respectively, right?
3) Where are bits 14 and 15 of the 16-bit value "in" $3C? Are they not in bits 6 and 7 of $3D? I don't know how you implemented your ZP variable EscState, but is it possible that your terminal emulation bug lies in this vicinity?
Mike
PostPosted: Mon Dec 01, 2014 10:00 am
I was referring to a probable bug in my own code to emulate a WYSE 60 terminal no Supermon. I had read through the comments. Supermon816 works great. I found one display bug in the text video controller I had set up - readback of character attribute codes wasn't working. Nothing to do with the '816 emulation.
You are right on with #1 and #2. There are no modes to this core - it's a straight '816 emulation. So it's supposed to work exactly like the '816 would. Accumulator and memory are both set to 16 bits before the subroutine is called. There are two bytes of zero page reserved for the EscState flag. $3C,$3D. The bit test is using the MSB as a flag that an escape sequence is present. The flag is set to -1 later in code if an ESC char is present. The program does get into processing escape sequences, as things like reverse video, and cursor on/off seem to work. It's just that the display goes nuts when I try running Supermon's disassemble function. It does disassemble code, but it's all over the screen rather than being neatly laid out. I could post the code, but it's a little long.
PostPosted: Mon Dec 01, 2014 10:09 am
Code for the terminal emulation.
Vars:
- VIDBUF is the text video memory, laid out PC style with high byte attribute, and low byte screen char
- VideoPos is an index into video memory.
- NormAttr is the normal display attribute in use
- VIDREGS is text controller video register set. +13,14 an index for the cursor position
; Display a character on the screen device
DisplayChar:
   AND      #$0FF
   BIT      EscState
   LBMI   processEsc
   CMP      #BS
   LBEQ   doBackSpace
   LBEQ   doCursorRight
   LBEQ   doCursorLeft
   LBEQ   doCursorUp
   LBEQ   doCursorDown
   CMP      #$99         ; delete
   LBEQ   doDelete
   CMP      #CR
   BEQ      doCR
   CMP      #LF
   BEQ      doLF
   CMP      #$94
   CMP      #ESC
   BNE      .0003
   DEC      EscState
   RTS
.0003:
   ORA      NormAttr
   PHA
   LDA      VideoPos
   ASL
   TAX
   PLA
   STA      VIDBUF,X
   LDA      CursorX
   INA
   CMP      #$56
   BNE      .0001
   STZ      CursorX
   LDA      CursorY
   CMP      #$30
   BEQ      .0002
   INA
   STA      CursorY
   BRL      SyncVideoPos
.0002:
   JSR      SyncVideoPos
   BRL      ScrollUp
.0001:
   STA      CursorX
   BRL      SyncVideoPos
doCR:
   STZ      CursorX
   BRL      SyncVideoPos
doLF:
   LDA      CursorY
   CMP      #30
   LBEQ   ScrollUp
   INA
   STA      CursorY
   BRL      SyncVideoPos
processEsc:
   LDX      EscState
   CPX      #-1
   BNE      .0006
   CMP      #'T'   ; clear to EOL
   BNE      .0003
   LDA      VideoPos
   ASL
   TAX
   LDY      CursorX
.0001:
   CPY      #55
   BEQ      .0002
   LDA      #' '
   ORA      NormAttr
   STA      VIDBUF,X
   INX
   INX
   INY
   BNE      .0001
.0002:
   STZ      EscActive
   RTS
.0003:
   CMP      #'W'
   BNE      .0004
   STZ      EscState
   BRL      doDelete
.0004:
   CMP      #'`'
   BNE      .0005
   LDA      #-2
   STA      EscState
   RTS
.0005:
   CMP      #'('
   BNE      .0008
   LDA      #-3
   STA      EscState
   RTS
.0008:
   STZ      EscState
   RTS
.0006:
   CPX      #-2
   BNE      .0007
   STZ      EscState
   CMP      #'1'
   LBEQ   CursorOn
   CMP      #'0'
   LBEQ   CursorOff
   RTS
.0007:
   CPX      #-3
   BNE      .0009
   CMP      #ESC
   BNE      .0008
   LDA      #-4
   STA      EscState
   RTS
.0009:
   CPX      #-4
   BNE      .0010
   CMP      #'G'
   BNE      .0008
   LDA      #-5
   STA      EscState
   RTS
.0010:
   CPX      #-5
   BNE      .0008
   STZ      EscState
   CMP      #'4'
   BNE      .0011
   LDA      NormAttr
   ; Swap the high nybbles of the attribute
   XBA
   SEP      #$30      ; set 8 bit regs
   NDX      8         ; tell the assembler
   MEM      8
   ROL
   ROL
   ROL
   ROL
   REP      #$30      ; set 16 bit regs
   NDX      16         ; tell the assembler
   MEM      16
   XBA
   AND      #$FF00
   STA      NormAttr
   RTS
.0011:
   CMP      #'0'
   BNE      .0012
   LDA      #$BF00      ; Light Grey on Dark Grey
   STA      NormAttr
   RTS
.0012:
   STA      NormAttr
   RTS
doBackSpace:
   LDY      CursorX
   BEQ      .0001      ; Can't backspace anymore
   LDA      VideoPos
   ASL
   TAX
.0002:
   LDA      VIDBUF,X
   STA      VIDBUF-2,X
   INX
   INX
   INY
   CPY      #56
   BNE      .0002
.0003:
   LDA      #' '
   ORA      NormAttr
   STA      VIDBUF,X
   DEC      CursorX
   BRL      SyncVideoPos
.0001:
   RTS
; Deleting a character does not change the video position so there's no need
; to resynchronize it.
doDelete:
   LDY      CursorX
   LDA      VideoPos
   ASL
   TAX
.0002:
   CPY      #55
   BEQ      .0001
   LDA      VIDBUF+2,X
   STA      VIDBUF,X
   INX
   INX
   INY
   BRA      .0002
.0001:
   LDA      #' '
   ORA      NormAttr
   STA      VIDBUF,X
   RTS
doCursorHome:
   LDA      CursorX
   BEQ      doCursor1
   STZ      CursorX
   BRA      SyncVideoPos
doCursorRight:
   LDA      CursorX
   CMP      #55
   BEQ      doRTS
   INA
doCursor2:
   STA      CursorX
   BRA      SyncVideoPos
doCursorLeft:
   LDA      CursorX
   BEQ      doRTS
   DEA
   BRA      doCursor2
doCursorUp:
   LDA      CursorY
   BEQ      doRTS
   DEA
   BRA      doCursor1
doCursorDown:
   LDA      CursorY
   CMP      #30
   BEQ      doRTS
   INA
doCursor1:
   STA      CursorY
   BRA      SyncVideoPos
doRTS:
   RTS
HomeCursor:
   LDA      #0
   STZ      CursorX
   STZ      CursorY
; Synchronize the absolute video position with the cursor co-ordinates.
SyncVideoPos:
   LDA      CursorY
   ASL
   TAX
   LDA      LineTbl,X
   CLC
   ADC      CursorX
   STA      VideoPos
   STA      VIDREGS+13      ; Update the position in the text controller
   RTS
 Post subject: Re: FT816 Core - SPH01
PostPosted: Fri Oct 02, 2015 6:55 pm
Fixed a subtle bug in the core today. The stack pointer high byte was not being set to 01h when a switch to emulation mode occurs. Instead the core forced stack address calculations in emulation mode to use '01h' as the stack page without modifying SPH. This bug did not appear to break any software that was tested so far. However when switching back to native mode from emulation mode, the SPH register didn't contain an 01h. Instead it would contain the previous value set in native mode. It is now fixed to switch to page 01h.
I have not tested this fix yet. I need to upgrade my toolset to be Window 10 compatible.
PostPosted: Fri Oct 30, 2015 3:51 pm
I've copied the FT816 core and am adding 32 bit support to create the FT832 core. It will be backwards compatible. As suggested by others on the board, the FT832 will have all 32 bit registers in native mode. The program bank register is turned into a code segment register, and the data bank register is turned into a data segment register. In order to switch to emulation mode from native mode a long jump JML instruction will be used that specifies both the program counter and code segment. In this case the code segment value will be $FFFFFFFF to switch to 8 bit emulation or $FFFFFFFE to switch to 16 bit emulation. The reason a jump instruction is used because the code segment needs to be zeroed on the switch, and the programs execution address forced to a known value. In native 32 bit mode the eight bit displacement instruction will be shifted left twice before put to use. This will allow more efficient use of zero page (extending it to 1kB). Also in native mode long address mode instructions are 32 bit addresses rather than 24 bit. Otherwise the instruction set remains the same. It is necessary to flip bits in the status register to get byte or 16 bit operations from native mode.
