It is currently Sun Nov 24, 2024 2:35 pm
 Post subject: 6519 Forth processor
PostPosted: Thu Jan 02, 2014 8:26 pm
We've just posted about the Rockwell 6519, which is on one side strangely incompatible, but on the other hand has what looks like a "Forth instruction" register, with hardware Threaded Next etc opcodes.
https://plus.google.com/108984290462000 ... mULLYcJ1pN
André
 Post subject: Re: 6519 Forth processor
PostPosted: Thu Jan 02, 2014 8:36 pm
Edit: archive copy of André's link.
Looks like Ted Melton actually had one of these: viewtopic.php?p=2282#p2282
PostPosted: Thu Jan 02, 2014 8:56 pm
I've written code for the 'C39 (maybe the 'C29, but I think it was the 'C39), which seems to have been somewhat of a follow-on from this CPU. It's used in some Rockwell (or Connexant, or whoever they are now) modem chipsets.
PostPosted: Thu Jan 02, 2014 8:59 pm
We have the data sheet on this site, at http://archive.6502.org/datasheets/rock ... mputer.pdf
PostPosted: Sun Aug 17, 2014 9:01 pm
Let's see how the R65C19 differs from a 6502:
- (indirect,X) becomes (indirect)
- (indirect),Y becomes (indirect),X
- extra instructions - see below - for support of threaded interpreted languages, for arithmetic including multiplication, swap, multiple register push and pull, one-byte subroutine calls (8 available, vectored through ROM)
- 16-bit I register to support threaded interpreted code
- 16-bit W register to support multiply-accumulate
- six levels of IRQ each with their own ROM vector, also (configurable) RAM vector
- JSR and RTS stack the actual return address, and are both 1 cycle faster
- 512 bytes RAM on-chip (spread over half of page 0, all of page 1 and half of page 2)
- the stack is, possibly, somehow segmented into four parts
- optional 16k ROM on-chip
- 15-byte dual-ported buffer to allow the chip to act as a memory-mapped peripheral to a host micro
- various on-chip peripherals and extra I/O ports
- up to 44 GPIOs and/or external memory bus
- four pre-decoded chip select outputs for external memory chips
- comes in 64-pin, 68-pin or 80-pin packages
- stop mode and idle mode
- runs up to 8MHz
File comment: Additional instructions on 65C19
File comment: Nine "basic" instructions added to R65C19
PostPosted: Sun Aug 17, 2014 9:44 pm
Also implemented in CMOS, for better noise immunity, lower power consumption and down-to-DC clocking. And, as we'd expect, the six main bugs of the old NMOS chip are fixed (see page A-5). But, unlike the 'C02, it's not specified as treating undefined opcodes as NOPs. Of course that's generally an issue of no concern -- but still notable if you're interested in the internals of the chip.
PostPosted: Sun Aug 17, 2014 11:31 pm
More food for thought. :)
Michael A.
PostPosted: Mon Aug 18, 2014 3:41 am
There may be some interest in the opcode map of the R65C19 and how it compares to the R65C02. Pink/Light Red Cells are opcodes which have different meaning than those of the R65C02. Cells with Red Font and a white background are the additions to the 6502 instruction set made by the 65C02. The bit-oriented instructions added by Rockwell are shown in normal black font and a white background in rows 7 and F.
From the map shown in the two attached diagrams, the R65C19 instruction set demonstrates some significant deviations from that of the R65C02/W65C02.
Michael A.
