We've just posted about the Rockwell 6519, which is on one side strangely incompatible, but on the other hand has what looks like a "Forth instruction" register, with hardware Threaded Next etc opcodes.
https://plus.google.com/108984290462000 ... mULLYcJ1pN
André
6519 Forth processor
Re: 6519 Forth processor
Edit: archive copy of André's link.
Looks like Ted Melton actually had one of these: viewtopic.php?p=2282#p2282
I've written code for the 'C39 (maybe the 'C29, but I think it was the 'C39), which seems to have been somewhat of a follow-on from this CPU. It's used in some Rockwell (or Connexant, or whoever they are now) modem chipsets.
- GARTHWILSON
- Forum Moderator
We have the data sheet on this site, at http://archive.6502.org/datasheets/rock ... mputer.pdf
Let's see how the R65C19 differs from a 6502:
- (indirect,X) becomes (indirect)
- (indirect),Y becomes (indirect),X
- extra instructions - see below - for support of threaded interpreted languages, for arithmetic including multiplication, swap, multiple register push and pull, one-byte subroutine calls (8 available, vectored through ROM)
- 16-bit I register to support threaded interpreted code
- 16-bit W register to support multiply-accumulate
- six levels of IRQ each with their own ROM vector, also (configurable) RAM vector
- JSR and RTS stack the actual return address, and are both 1 cycle faster
- 512 bytes RAM on-chip (spread over half of page 0, all of page 1 and half of page 2)
- the stack is, possibly, somehow segmented into four parts
- optional 16k ROM on-chip
- 15-byte dual-ported buffer to allow the chip to act as a memory-mapped peripheral to a host micro
- various on-chip peripherals and extra I/O ports
- up to 44 GPIOs and/or external memory bus
- four pre-decoded chip select outputs for external memory chips
- comes in 64-pin, 68-pin or 80-pin packages
- stop mode and idle mode
- runs up to 8MHz
- runs up to 8MHz
Also implemented in CMOS, for better noise immunity, lower power consumption and down-to-DC clocking. And, as we'd expect, the six main bugs of the old NMOS chip are fixed (see page A-5). But, unlike the 'C02, it's not specified as treating undefined opcodes as NOPs. Of course that's generally an issue of no concern -- but still notable if you're interested in the internals of the chip.
There may be some interest in the opcode map of the R65C19 and how it compares to the R65C02. Pink/Light Red Cells are opcodes which have different meaning than those of the R65C02. Cells with Red Font and a white background are the additions to the 6502 instruction set made by the 65C02. The bit-oriented instructions added by Rockwell are shown in normal black font and a white background in rows 7 and F.
From the map shown in the two attached diagrams, the R65C19 instruction set demonstrates some significant deviations from that of the R65C02/W65C02.
Michael A.
