6502 Design & concept questions.
- GARTHWILSON
- Forum Moderator
Re: 6502 Design & concept questions.
If I understand the data sheet correctly, IC3B needs to be an OR gate (not AND), because RAM will hold op codes, operands, and data.
If it makes your wiring or board layout easier, remember you can mix up the address lines to the RAM, and you can mix up the data lines to the RAM. (Don't do it with the ROM unless you also make a programming adapter or write a program to mix up the hex file for programming accordingly.)
ElEctric_EyE
... remember you can mix up the address lines to the RAM, and you can mix up the data lines to the RAM. (Don't do it with the ROM unless you also make a programming adapter or write a program to mix up the hex file for programming accordingly.)
We have debated VPA and VDA before... You very probably don't need them...
If it makes your wiring or board layout easier you can mix up the address ... data lines to the RAM.
I’d like to choose one of the VIA ports as a configuration register. I want to take the port with lesser value. Which one could I use?
Marco
- GARTHWILSON
- Forum Moderator
Here are some pointers:
viewtopic.php?p=24907#p24907 - BDD says what happened. He's using an indexed addressing mode, and a DUART which can't handle two accesses in rapid succession.
viewtopic.php?p=9755#p9755 - the original discovery, with some helpful suggestions.
viewtopic.php?p=11901#p11901 - Garth points out that the only extraneous accesses you get when you don't qualify with VPA and VDA will be reads, and of predictable locations.
No-one is doubting that BDD had a bug which took some effort to track down. The idea that others are likely to hit the same problem is, I think, far-fetched. Certainly there's nothing mysterious happening, and it's not bad for a 6502 circuit designer to have an awareness of the stray read accesses.
Hope this helps
I'm not sure what you mean by "configuration register,"
At Startup I want to configure port A of VIA1 as output. The bits 0-5 are connected to an AVR. The AVR scans those bits continuously. The AVR is also connected to the Flash memory’s A14, A15 and A16. Which selects the ROM bank.
Bit 3 enables or prohibits writing to flash. I added also a jumper as you suggested. Bit 4 and 5 determines the clock speed which is provided by the AVR. It will give the following frequencies:
01 7,3728
10 3,6864
11 1,8432
01 3,6864
10 1,8432
11 0,9216
In the meanwhile, before I get my WDC parts, I’m going to make a simplified version on PCB. Just for practicing. I need a simpler version, the PCB gets too crowded.
The idea that others are likely to hit the same problem is, think, far-fetched.
Marco
- BigDumbDinosaur
lordbubsy wrote:
According to your RS-232 primer, the 6551 could accommodate a baud rate of 115200 with a PHI2 of 7,3728 MHz.
A continuous 115.2Kbps data stream in 8N1 format will generate 11,520 interrupts per second (an IRQ every 87 microseconds), one for each byte that has been deserialized and buffered in the 65C51's one-byte receiver holding register (RHR). The catch is that if the previous byte in the RHR has not been read by the time another byte arrives and is deserialized, the new byte will be lost and your data stream will be corrupted. Therefore, it is incumbent on your system to react without delay to a 65C51 IRQ and get that byte out of the RHR before the next one is due to arrive.
This characteristic of the 65C51 (and the Motorola 6850) is one of several reasons why I went with the 2692. The 2692's RHR is actually a FIFO that is four bytes deep (eight bytes with the 26C92), so small delays in servicing receive interrupts are tolerable. They won't be readily tolerated with the 65C51 at the speeds you may be contemplating.
- GARTHWILSON
- Forum Moderator
LDA #1 ; Else, tell the other end to stop sending data before
STA ACIA_COMM ; the buffer overflows, by storing 1 in the ACIA's
; command register.
I've designed a few commercial products where the main critical job was in the ISR and it took 80% of the processor time, and every time I see I need to change it in the development process, I have to re-count cycles and check what the worst-case senario is. If it gets tight, there have always been several ways to remedy it without starting over with a more-powerful processor.
What's more, the status register has an overrun bit which would tell you if you'd failed to service in time.
Note that you don't have to use interrupts to handle the ACIA. In cases where you need to transfer a lot of data, e.g. a bootloader, the CPU can sit in a tight loop polling for data, and writing it to memory.
- GARTHWILSON
- Forum Moderator
True, although that would be for the limited use of just transferring data into memory and not actually processing it on the fly.
which assembles:
which is 41 clocks per byte, so at 7.3728MHz, you could go about 1.8 Mbps. The ISR posted in the interrupts primer could only go about 750kbps, but it's kind of an apples-to-oranges comparison because of the ring buffer. We could re-write the ISR this way (which still does not take into account any other interrupt sources):
which assembles
which comes to 54 clocks per byte, which, at 7.3728MHz, would allow up to about 1.3 Mbps, but the background routine (which basically gets no processor time at 1.3 Mbps) has to watch for when the store pointer matches the end address.
Hopefully I didn't do this so quickly so as to have a dumb mistake like I did on my recent post about indexed table jumps which I had to go back and correct.
- You would gain a small amount of speed by the fact that you don't have to keep checking to see if the background program is keeping up and thus deciding whether or not to tell the other end to pause
- and you would gain a small amount by eliminating the interrupt overhead (which again can be small, unlike so many ISRs I've seen in books)
- but then you would need to increment a two-byte indirect pointer to where you're filling memory, losing a little performance,
- and compare to the final 16-bit address to know when to quit, again losing a little performance;
; (2-byte variables in ZP:)
POINTER: DFS 2
END_ADR: DFS 2
BEGIN
LDA POINTER ; Has the low byte of the pointer reached
CMP END_ADR ; the low byte of the ending address?
IF_EQ ; If they match,
LDA POINTER + 1 ; go on to compare
CMP END_ADR + 1 ; the high byte also.
END_IF ; (Actually, 16-bit comparisons could be made a macro also, cutting out 5 lines of source code.)
WHILE_NEQ ; As long as they don't both match, go for another byte. Otherwise, exit the program structure.
BEGIN
LDA ACIA_STAT ; Read the status register
UNTIL_NEG ; until it says there's a chage of status (indicated by bit 7).
AND #00000111B ; Check the overrun, framing, and parity error bits (overrun should always be fine in this case)
BNE REPORT_ERR ; and handle errors. Normally, this branch will never be needed.
LDA ACIA_DATA ; Get the data byte that just came in, and
STA (POINTER) ; store it. (NMOS 6502 must use Y here, previously loaded with 0.)
INC POINTER ; Now we have to increment the 16-bit pointer, low byte first,
IF_EQ ; and if it rolled over to 00,
INC POINTER + 1 ; increment the high byte too.
END_IF
REPEAT ; Then go back up to see if there's another byte, and if so, to get it.Code: Select all
; cycles
top: LDA POINTER ; 3
CMP END_ADR ; 3
BNE 1$ ; 3 usually
LDA POINTER+1 ; 3 (usually not taken)
CMP END_ADR+1 ; 3 (usually not taken)
1$: BEQ end ; 2 usually
2$: LDA ACIA_STAT ; 4
BPL 2$ ; 2 if we're going as fast as possible
AND #00000111B ; 2
BNE REPORT_ERR ; 2 normally
LDA ACIA_DATA ; 4
STA (POINTER) ; 5
INC POINTER ; 5
BNE 3$ ; 3 usually (but this could BRA directly to top)
INC POINTER+1 ; 5 (usually not taken)
3$: BRA top ; 3 normally
end:Code: Select all
ISR: PHA
PHX
LDA ACIA_STAT
IF_MINUS
AND #00000111B
BNE REPORT_ERR
LDA ACIA_DATA
STA (POINTER)
END_IF ; (Actually 16-bit increments could be made a macro too, cutting out 3 lines of source code.)
END_IF
PLX
PLA
RTICode: Select all
; 7 (for the interrupt sequence)
ISR: PHA ; 3
PHX ; 3
LDA ACIA_STAT ; 4
BPL 1$ ; 2 usually
AND #00000111B ; 2
BNE REPORT_ERR ; 2 usually
LDA ACIA_DATA ; 4
STA (POINTER) ; 5
INC POINTER ; 5
BNE 1$ ; 3 usually
1$: PLX ; 4
PLA ; 4
RTI ; 6Hopefully I didn't do this so quickly so as to have a dumb mistake like I did on my recent post about indexed table jumps which I had to go back and correct.
Of course, in practical applications, the ISR is fixed, and needs to check for multiple interrupt sources, which includes at least the transmit side of the UART. While you're in tight polling loop downloading data, you know you aren't transmitting, so there's no need to check it.
Also, in the polling loop, maybe you know you only need to receive < 256 bytes in a burst, so you could use absolute indexed addressing.
- GARTHWILSON
- Forum Moderator
and another thing I forgot to say is that of course the ACIA won't go 1.8Mbps.
I don't know that I've ever had more than two or three IRQ sources enabled at once; but I have routines to modify the ISR so it doesn't have to check all the possible sources that are not even enabled.
True. So, at least we can confirm that 115200 is possible, as long as you're a bit careful with the software. Having the hardware option to enable that speed is useful, and for applications that don't need 115200, you can easily divide it down to a slower rate.
OK, I’ve made a simplified schematic and replaced the WDC’s for NMOS IC’s.
I hope there aren’t too many errors and loose ends?
If all is OK, I’d like to place the components on the board.
By placing them I look for the air wires the least tangled up and as short as I can.
My question is how do I place the components optimally?
I zipped all the files for compactness.
- Attachments
- simplified.zip
- (354.04 KiB) Downloaded 218 times
Marco
