It is currently Thu Nov 21, 2024 10:29 pm
Post new topic Reply to topic  [ 114 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Sun Jul 08, 2012 8:41 am
That's a very good point. I'm only familiar with Xilinx, where the the tools appear to be zero cost and unencumbered. If you (or anyone) know of unpleasant limitations on the altera tools, it would be good to record that here.
PostPosted: Fri Sep 14, 2012 4:00 pm
I see that Lattice have an offer on: FPGA dev boards for $19.
Note that Lattice are a minority player, but it seems like a good price. 68 I/Os on a 0.1" pitch, 3V3 logic levels, 1280LUTs. No mention of 5V tolerance. No fancy peripherals at this price: just LEDs and buttons.
There's a low power (L) version and a high speed (H) version.
PDF: http://www.latticesemi.com/documents/EB73.pdf
Other docs: http://www.latticesemi.com/dynamic/inde ... ce=sidebar
Chip family: http://www.latticesemi.com/products/cpl ... /index.cfm
Via: http://www.eetimes.com/electronics-prod ... -eval-kits
PostPosted: Thu Dec 06, 2012 7:05 am
Elsewhere, enso has drawn our attention to Waveshare's boards:
http://www.wvshare.com/column/XILINX_De ... tBoard.htm
From under $50, for a Xilinx Spartan3 3Volt breakout board. Also available via ebay.
PostPosted: Thu Dec 06, 2012 6:28 pm
I don't need FPGA dev boards, i need a cheap replacement for the now already antique XC95xx CPLD series. I want something that i can plug in a big socket(64 pin dip is ok), and that i can use with my existing 5V hardware. Also it would need to have an eeprom on board. As for programing the JTAG pins could be among all the other pins, so i can solder the JTAG connector on the board that i am building.
I also think that there are other people that would appreciate a cheap and easy to interface CPLD replacement.
Do you understand what i am looking for?
And can it be done?
PostPosted: Thu Dec 06, 2012 6:44 pm
Dajgoro, in the first post there's a link to these OHO boards, which seem to fit your requirements.
PostPosted: Thu Dec 06, 2012 7:18 pm
And can it be done?
Perhaps you should look at the Atmel 15xx series, which is a 5 volt product available in PLCC, as well as other packages. Atmel also sells a programming rig that accepts various adapters for the different package types, or you can implement the JTAG port on your PCB. I selected an Atmel 1508AS for use in my POC V2 project.
Despite what some around here may think, Xilinx isn't the only maker of CPLDs. :D
PostPosted: Thu Dec 06, 2012 10:15 pm
Yes, something like that, but that board is bit expensive, and it has additional features which are noncritical, for the example the usb port and crystal oscillator, ect...
As for Atmels CPLD-s they are like the XC series that i use, bu a bit better. What application are used for writing hdl and programming it?
PostPosted: Thu Dec 06, 2012 10:21 pm
I doubt you can get much cheaper than 50-60 Euros for something like this, and you'd probably end up spending more if you try to make it yourself.
PostPosted: Thu Dec 06, 2012 10:30 pm
Of course, but when removing some of that additional parts, and maybe eve using cheaper FPGA, it could be sold on ebay in mass. Such a small pcb shouldn't be too expensive, Garthwilson could sell it through his company(like the 4MB ram module).
How much would a stripped down prototype cost?
PostPosted: Fri Dec 07, 2012 6:19 am
The problem is that this isn't really a mass market item, so your development and production cost will still be relatively high. And the more you strip it down, the less attractive it becomes.
PostPosted: Fri Dec 07, 2012 2:39 pm
You can use WinCUPL, which is free for the downloading from Atmel's site. WinCUPL is a complete package that includes editor, compiler, simulator and device fitter.
PostPosted: Fri Dec 07, 2012 6:17 pm
Err, Dajgoro, for future reference, I think it would be better for you(*), and this thread, and for future searches, if you had started a new thread on a subject like "I need a cheap replacement for the now already antique XC95xx CPLD series"
I'm not picking on you, but using this as an example: everyone should please consider starting a new thread when an idea or question comes to them while reading an existing thread.
(*) better for you to get answers
Edit: Thanks Dajgoro for the new thread:
viewtopic.php?f=10&t=2354
PostPosted: Fri Dec 07, 2012 7:34 pm
If it's going to start another whole subject of conversation instead of just being a passing comment or quick question that is only partially related, then definitely. And, as Ed has been good about doing, make the two link to each other so the reader can see what other conversation the new one came from, and someone reading the older one can know where to read and post about the offshoot.
PostPosted: Tue Dec 11, 2012 4:16 pm
just had this in my twitter feed: http://hackaday.com/2012/12/11/breadboa ... dly-fpgas/
the comments and mentions of other boards later on may be as interesting as the article itself eventually too.
I`m also chatting/hinting/urging/arm twitsing a designer friend of mine to develop a small FPGA board as well, so fingers crossed ;)
Also on Twitter as "YT2095".
PostPosted: Tue Dec 11, 2012 5:55 pm
Haha, just saw it on my own, and posted in the other topic. :D
