It is currently Thu Nov 21, 2024 8:23 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Mon Dec 04, 2023 12:58 pm
10a) register 4 //vertical total
10b) register 6 //vertical displayed
10c) register 7 //vertical SYNC position
PostPosted: Mon Dec 04, 2023 12:59 pm
11) HCC counter plus logic
Counts the horizontal characters.
PostPosted: Mon Dec 04, 2023 1:08 pm
12) MA counter
(display) Memory address counter,
and it's a lot of stuff.
PostPosted: Mon Dec 04, 2023 1:11 pm
13a) register 17 //light pen L
13b) register 15 //cursor position L
13c) register 16 //light pen H
13d) register 14 //cursor position H
PostPosted: Mon Dec 04, 2023 1:12 pm
14) CBC counter plus logic
Cursor blink counter.
This is, what makes the cursor blink.
PostPosted: Mon Dec 04, 2023 1:15 pm
15a) register 10 //cursor end
15b) register 11 //cursor start
15c) register 9 //scan lines
15d) RA counter //raster address
PostPosted: Mon Dec 04, 2023 1:17 pm
16) RA logic
Big blob of conventional logic, tied to the RA counter.
It turned out that most of it is for turning the cursor on/off
in a specific raster line.
And I have to say that the interlaced mode sure adds a lot to the complexity.
PostPosted: Mon Dec 04, 2023 1:19 pm
17) VRC counter
Counts the horizontal characters. //I think.
//Hey, I had to give that thing a name...
PostPosted: Mon Dec 04, 2023 1:23 pm
18) VAC counter
For vertical total scan line adjust.
Note that Schmitt Trigger in 18d),
which implicates that the designer expected to have some spikes
in the output signal from the register 0 comparator:
PostPosted: Mon Dec 04, 2023 1:29 pm
19a) register 8, Bit 7..6 //mode control
19b) register 3, Bit 7..6 //HSYNC, VSYNC widths
//To me it feels like the chip designers ran a bit out of space in 19),
//and tried to squeeze all that stuff in a limited amount of space.
19c) register 8, Bit 5..0 //mode control
19d) register 3, Bit 5..0 //HSYNC, VSYNC widths
PostPosted: Mon Dec 04, 2023 1:34 pm
19ef) HSW counter plus logic //width of the horizontal SYNC pulse.
19g) VSW counter plus logic //width of the vertical SYNC pulse.
19h) HSW counter control
Note that low pass filter in 19h),
which is built from a FET resistor and the gate capacitance of an inverter.
The designers obviously expected to have some spikes
in the output of the register 2 comparator.
PostPosted: Mon Dec 04, 2023 1:37 pm
20) status register
Because RES isn't your average reset signal,
the designers had added some power_on reset circuitry
for clearing Bits in the status register.
PostPosted: Mon Dec 04, 2023 1:38 pm
21) register 31 read write
Mostly some shenanigans for incrementing the address pointer
when it comes to register 31 reads/writes.
//Note, that the Rockwell R6545 keeps the drivers to the
//D0..D7 external data bus in high impenance
//for register 31 reads.
And that's all.
PostPosted: Sun Dec 10, 2023 3:32 am
Many thanks for that great amount of work! I'll certainly have a deeper look!
Users browsing this forum: Google [Bot] and 23 guests
