Embedding/Manipulating Assembler in Higher Level Languages
cjs
Post by cjs »
In this post from Garth Wilson he discusses a little bit about how he embeds 6502 assembly language into his Forth programs. I responded mentioning that I do this in Python and was interested in hearing more about his techniques. This started getting off-topic for that particular thread (which was actually about avoiding assembly by embedding machine language), so I'm starting this thread to continue to the assembly ideas.
Unlike the other thread, this one is not limited to embedding and/or manipulating assembly in just FORTH; discussion of doing this in any higher-level language is welcome.
The next two posts are Garth's post linked above, quoted by me, and my follow-up post.
cjs
Re: The real power of [ and ]
Post by cjs »
IamRob wrote:
I don't have a built in assembler in Forth, mostly because I have trouble grasping the RPN of assembly.
You don't have to. I had to work with RPN assembly briefly around 1990 at work and absolutely hated it. (Nothing against those who like it though.) Years later, it only took me a couple of hours to write my 6502 Forth assembler in its original form (but I did some improvements later, and still have more in mind). The bulk of it, ie, the main stuff, without going into branching for example, was this kind of thing:
: ADC#       69 C, ;     : AND#       29 C, ;     : ASL_A     0A C, ;
: ADC_ABS    6D C, ;     : AND_ABS    2D C, ;     : ASL_ABS   0E C, ;
: ADC_ZP     65 C, ;     : AND_ZP     25 C, ;     : ASL_ZP    06 C, ;
: ADC(ZP)    72 C, ;     : AND(ZP)    32 C, ;     : ASL,X     1E C, ;
: ADC,X      7D C, ;     : AND,X      3D C, ;     : ASL_ZP,X  16 C, ;
: ADC,Y      79 C, ;     : AND,Y      39 C, ;
: ADC_ZP,X   75 C, ;     : AND_ZP,X   35 C, ;
: ADC(ZP,X)  61 C, ;     : AND(ZP,X)  21 C, ;
: ADC(ZP),Y  71 C, ;     : AND(ZP),Y  31 C, ;
   <etc.>
which shows most of the '02 addressing modes. So you just put the mnemonic down followed by the operand (if any) with a comma (or C-comma, or in the case of the '816, a "3C," also, for the few times you need a three-byte operand). There is no parsing, even though the mnemonic precedes the operand. It is up to you to specify the addressing mode along with the mnemonic, and to use the right word to compile the operand (whether comma or C-comma). So you'll do for example,
        LDA_ABS  FOOBAR  ,
Later I wrote a word "comp_op", laid down by macro OP_CODE, to shorten the op-code words by five bytes each (this is from the Forth assembly source-code, not high-level Forth):
        HEADER "ADC#", NOT_IMMEDIATE
        OP_CODE  $69
so that after the header (formed by the HEADER macro), there are only the two bytes of CFA (pointing to comp_op) laid down in the code field by the OP_CODE macro, followed by the one byte of op code which the macro also lays down, and nothing more, ie, no nest, unnest, or lit, and only one byte (not two) for the op code number itself. comp_op also takes care of the semicolon's job, so it's all there, without adding more bytes.
For the places in the kernel where you'd want to jump to in various primitives you would write, I have constants like this:
  8F34  CONSTANT  POP              8F74  CONSTANT  SET-TRUE
  8F32  CONSTANT  POP2             8F86  CONSTANT  SET-FALSE
  8F7E  CONSTANT  POP2-FALSE       8F38  CONSTANT  CPUSH
  8F6C  CONSTANT  POP2-TRUE        8F3B  CONSTANT  PUSH
  8F30  CONSTANT  POP3             8F84  CONSTANT  PUSH-FALSE
  8F6A  CONSTANT  POP3-TRUE        8F72  CONSTANT  PUSH-TRUE
  8F7C  CONSTANT  POP3-FALSE       8F3D  CONSTANT  PUT
  8F6E  CONSTANT  POP-TRUE         8F42  CONSTANT  NEXT
  8F80  CONSTANT  POP-FALSE        00FD  CONSTANT  XSAVE
  00F0  CONSTANT  N                C98D  CONSTANT  setirq
     4  CONSTANT  tempA              FE  CONSTANT  irq?\
Note that no separate assembler vocabulary is needed, because for example assembly's AND will not conflict with Forth's AND because assembly's word always comes with the addressing mode, whether #, _ABS, or whatever, as part of the name.
There's a little more to it, particularly in the matter of branching and labels, but It'll take me more time to describe that, which I'll do later if you're interested. For now, this should give you the ideas to get started. You assembly source code then won't look so different from how it does for a normal assembler.
cjs
Re: Embedding/Manipulating Assembler in Higher Level Languag
Post by cjs »
I'd definitely be interested in hearing about this. I'm not sure how directly applicable it would be to my work with 6502 "assembly" of sorts in Python, but what you've shown so far is pretty much exactly what I do, and I'm contemplating how to deal with the next step. Here's a unit test that shows how I currently code things up:
def test_call_push(m):
    p    = 0x406
    cont = 0x40d            # Address of continuation below
    m.deposit(p, [
        I.LDA, MB(cont-1),  # 0406: 6502 puts return addr -1 on stack
        I.PHA,              # 0408:
        I.LDA, LB(cont-1),  # 0409:
        I.PHA,              # 040b:
        I.RTS,              # 040C: jump to continuation below
        I.LDA, 0xA5,        # 040d: continuation
        I.RTS,              # 040F: return to call()
    m.call(p, trace=1)
    assert R(pc=cont+2, a=0xA5) == m.regs
I use LDA instead of LDAi for immediate load because it doesn't collide with anything else, but, just as you do, I use suffixes for other addressing modes: LDAm, LDAz, LDAmx, LDAzy, etc.
One idea I'm kicking around is to continue to use a list, use string elements for defining and referencing labels, maybe add some pseudo-ops, and feed the list into an assembler function. And one might allow 16-bit values in the list and change the LDA processing to pick an appropriate addressing mode.
So what does your system handle now, and what are your thoughts on how you'd expand it to have more functionality?
I'll keep this brief since it's not in the Forth forum section. In Forth, I have INLINE and END_INLINE to bracket a section of assembly-language programming in an otherwise high-level definition (ie, routine), per Bruce's recommendation 16 years ago from F-PC in the topic "Mixing assembly into a colon definition." Usually I just write a primitive to call from a secondary though, rather than writing some assembly language into the middle of a secondary. (For non-Forthers: "Primitive" just means the Forth word is defined in assembly language, while "secondary" just means it's defined in terms of other Forth words, possibly including both primitives and other secondaries. Either way, they are what would be called "routines" or "subroutines" in other languages.)
cjs
Post by cjs »
Sadly, that's so brief that I think it may be clearly comprehensible only to FORTH programmers. :-) I have no objection to heavy discussion of FORTH in this topic; I put it under "Programming" rather than "FORTH" just because I didn't want to limit the discussion to FORTH. (For example, I think that BBC BASIC may have some good ideas that could be discussed here.)
I should also emphasise that I'm not talking about inline assembler here (i.e., assembly code interspersed with and executed as part of the host language code, though some uses of that may be related) but actually the embedding of assembly code in a higher-level language in the manner of what's usually called an embedded domain-specific language; i.e., usually using the host langauge syntax or something that can easily fit with that. This is typically used to produce reified objects that can then be manipulated as necessary.
For example, in your post I quoted above you used LDA_ABS FOOBAR (note that there's no trailing comma there!) to define an assembly language fragment, and then at that point it can be assembled in a variety of ways, and presumably various things could be done with it afterwards, if I'm understanding your explanation correctly. ("It is up to you...to use the right word to compile the operand (whether comma or C-comma).")
And in my Python example above, I use a pseudo-assembly syntax to generate a list of bytes, which I then deposit and call. That is not inline at all; if there is a way to do inline assembly in Python, I certainly don't use it, and it wouldn't even work since my Python interpreter is running on an x86_64 processor. (The 6502 code above is run in a simulator.)
Are these secondaries assembled with a separate stand-alone assembler, or within the Forth system?
Since it's Forth, there's macro capability built in with no extra effort in the writing of an assembler, something I forgot to mention in the other topic (but I'll go back and edit it now). You could even run a whole program (although it would probably be a rather short one) to to figure out what that operand should be before you comma it in, or you could put all that code inline after the LDA_ABS (and it could even take multiple lines), to be executed during the assembly process. It's flexible to the extreme; but the system will still need to know when you're ready with a final value to lay down as an operand for that LDA, and that's what the comma is for. Without it, the value will remain on the data stack for supposed future use.
If it's in the target system, they're compiled (not really assembled, unless you're building a subroutine-threaded-code Forth, where basically it all ends up in assembly language) by the Forth system that's running. Many secondaries will need to be in the kernel though, and unless you have a metacompiler (which I have used in the past), their source code will be processed by the assembler (or meta assembler or cross assembler) that you're using to form the kernel.
cjs wrote:
...I'm not talking about inline assembler here (i.e., assembly code interspersed with and executed as part of the host language code, though some uses of that may be related) but actually the embedding of assembly code in a higher-level language in the manner of what's usually called an embedded domain-specific language; i.e., usually using the host langauge syntax or something that can easily fit with that. This is typically used to produce reified objects that can then be manipulated as necessary.
I'd quite like to understand better the distinction you're drawing here. Is it that the assembly text produces a lump of binary data which can then be used in the program? That is, it's not to be executed at the point it's described, but it's to be stored, passed around, eventually put together with other code and then executed?
cjs
Post by cjs »
Yes, that's pretty much the core of one part of it.
The second part that is the key here (and where the "manipulation" comes in) is that with what Garth and I have been showing, the pieces of assembly are first-class objects within the host language. So, for example, if I need ten NOPs I can trivially generate that using the host language: in Python, [I.NOP] * 10. A slightly more sophisticated example from my post above is the use of host language variables and functions within the assembly code, such as addr = 0x400; asm = [ I.LDA, LB(addr-1) ], which takes an instruction and the low byte of a calculated value to give you a list of binary values, [ 0xA9, 0xFF ].
The most obvious way of "embedding" assembly code in a language is to simply write code in strings, e.g. A$ = "LDA #$33" in BASIC. But with just plain old strings like that, you essentially end up writing a separate interpreter to interpret those strings, and getting the kind of power with this that you see in the examples above is a huge amount of work, rather than most of that coming for nearly free when you use an embedded DSL in a reasonably powerful language. (As Alan Perlis points out in Epigram 34, "The string is a stark data structure and everywhere it is passed there is much duplication of process. It is a perfect vehicle for hiding information.")
Currently, my embedded "assembly code" (and Graham's, I think) is pretty darn simple, hardly more than assigning names to integers. So the question I'm interested in investigating is, how does one move beyond that to start handling things such as, say, labels. (Hand-counting entries in a list and then based on that setting addr =0x40d, as in the test in my previous post, is clearly neither reliable nor scalable.) The temptation is to start writing interpreters for those lists (essentially, writing an assembler), but go too far that way in a certain direction and you end up with just another assembler that you're calling from your host language, rather than having an actual embedded assembly language.
drogon
Post by drogon »
Embedding assembler into BBC Basic is "a thing" that's been there for a long time. You have to construct the 2-pass assembler using a BASIC FOR loop and the code generated can be stored and run from a byte array, or saved to disc, etc.
You can use BASIC procedures to create macros too and some quite complex systems have been built using it.
Some systems I built used the BASIC assembler to assemble and save code which was then loaded and run from disc by a 2nd program - mostly due to memory constraints, but this was really not that different from using a system that might have had a separate editor, assembler and loader - but the editor and assembler was the BASIC environment.
The BCPL system for the BBC Micro also had a separate relocatable assembler that allowed to you edit and assemble code which could then reference BCPL global variables and be called from BCPL as if it was a BCPL function. Like BBC BASIC, this was all self-hosted on the BBC Micro. I'm working on something similar for my own Ruby BCPL system - again, self hosted.
Doing it in C using cc65 and as65 is not hard either, but does require a separate system to edit, compile/assembler and link the code to produce a binary to run on the target.
I wrote in the other topic,
I was about to reply to Curt's last post (I saved my reply in a text file, so I have it all in its original form even though he moved it), but if you like, we can start a new topic
and you wrote above,
I have no objection to heavy discussion of FORTH in this topic [...]
so here it is (but yes, it is very much Forth, continuing on with the matter of the tiny macro assembler):
I'd definitely be interested in hearing about this. [...]
One idea I'm kicking around is to continue to use a list, use string elements for defining and referencing labels, maybe add some pseudo-ops, and feed the list into an assembler function. [...]
Rather than posting a long listing of code, it'd better if I give it more explanation than source code. In fact, maybe I'll try to make it a web page for my site, with diagrams and other helps.
As for labels: My Forth assembler is not intended for doing whole applications, only Forth primitives, runtimes, subroutines, ML ISRs, etc., where there's really only local use of labels and they're close enough to branch to. Going further with descriptive labels for things like long jumps is possible, but not as easy.
Branching backwards was the easiest part, since you can use HERE to put an address on the stack during assembly and not even use a real label of any kind; then if a BNE for example needs to branch back to it, I would write BNE GO_BACK, where BNE only lays down the op code (with no concern for an operand), and GO_BACK takes the top data-stack item (which is an address in this case) and figures out the branch distance from that and the current dictionary pointer, and lays it down in the assembled code. If you need more than the one thing on the stack, or need to refer back to the same place from more than one branch, the normal SWAP, DUP, etc. words are available of course.
Doing forward branching with a one-pass assembler is slightly more of a challenge. What I did for that is that if you have for example BNE 1$, the 1$ (and the rest through 9$ and 0$, ten of them) are Forth words with an associated variable, and the 1$ records the place where a branch distance operand needs to get filled in later when the place to branch to is finally found. Then 1$: (with the colon) is another word that figures out the branch distance to fill in back where the 1$ (without the colon) was encountered. Besides the labels not being descriptive, it's somewhat less than ideal in that if you have multiple places that need to branch to the same instruction, you'll need multiple labels, meaning sometimes I'll have something like:
    1$: 2$:  LDA_ZP,X  TOS  C,
The code for them is this:
: SET_BR      ( var_addr -- ) HERE SWAP !  0 C,	    ;
: RESOLVE_BR  ( addr -- )   @ HERE OVER - 1- SWAP C!  ;
WSIZE VAR 0‡    : 0$  0‡  SET_BR  ;	: 0$: 0‡ RESOLVE_BR  ;
WSIZE VAR 1‡    : 1$  1‡  SET_BR  ;	: 1$: 1‡ RESOLVE_BR  ;
WSIZE VAR 2‡    : 2$  2‡  SET_BR  ;	: 2$: 2‡ RESOLVE_BR  ;
  <etc.>
(The special character there, ‡, was chosen only for the unlikelihood of ever conflicting with anything else I do. Make it anything you want.)
So then you can have for example,
                      \ Unfortunately there's no INC (DP,X) instruction to use below.
CREATE  INCR  PRIMITIVE         ( addr -- )
        LDA(ZP,X) 0 C,   INA   STA(ZP,X) 0 C,   BNE 1$    INC_ZP,X  0 C,
        LDA(ZP,X) 0 C,   INA   STA(ZP,X) 0 C,       1$:   JMP POP      ,
CREATE  DECR  PRIMITIVE         ( addr -- )
        LDA(ZP,X) 0 C,   DEA   STA(ZP,X) 0 C,   CMP# FF C,   BNE 1$    INC_ZP,X  0 C,
        LDA(ZP,X) 0 C,   DEA   STA(ZP,X) 0 C,                    1$:   JMP POP      ,
In future improvements, I tentatively plan to use software buffers to set up things like local variables and arrays, constants (and in this case, label names with associated addresses), even code, and when I'm done with a buffer, I can delete it and reclaim the memory. Since it's at the opposite end of RAM from the main code I'm working on, deleting a buffer does not affect that area where the dictionary pointer is advancing as you compile or assemble things. Also, remaining buffers can get scooted around to close up holes in buffer memory, so memory never gets fragmented. I wrote words for buffers like this in Forth a few years ago, and wrote it up here. It was absolutely the worst I've ever done insofar as stack gymnastics go, and could definitely benefit from local variables to remedy that, which I need the buffers for. Chicken and egg. I will probably re-write the words in assembly language for performance before putting them to serious work, since I'll want them for a lot more than just running my assembler.
IamRob wrote:
In ProForth one creates a code word like this:
: TEST ;CODE [ HEX 20 C, FC58 , A0 , ... etc ] ;
I had to do something similar with the metacompiler I started out with at work when I first started in 6502 Forth. As the source code got longer as the project progressed, the metacompiler would sometimes, without explanation or error messages, just skip over a line or two of source code. I had to pick through the .hex code output to find the bug. (I find bugs in every commercial piece of software I use!) The supplier didn't want to fix it. Anyway, I had to do some hand assembly and comma-in the hex numbers.
However, note that the ; above is not necessary, since the primitive will need to end with something like JMP NEXT anyway. Also, once you set up the header and make the CFA point to the parameter field (ie, you're making a primitive), you don't need to turn STATE on at all, and then you won't need the [ and ] either. ; is an immediate word that lays down the unnest (or EXIT) and turns STATE off.
cjs
Post by cjs »
Garth, that was an excellent reply, just the kind of thing I was looking for. (Though I did have to go and do a bit of research to remember what Forth immediate words words are. It has been many decades since I have typed even a word of Forth.)
Yes, that's pretty much exactly where I'm at, too, though perhaps with one caveat. My unit test system loads an entire assembly (which is potentially huge) into simulator's memory and also returns and the assembly's symbol table as a Python object. So I am often using those symbols in new code I assemble and add to the loaded assembly.
From looking at what you've written, it seems that your assembly system is working very much the way the standard Forth word compiler works: you start with CREATE ____ PRIMITIVE to start building a new word and then non-immediate words get compiled, immediate words to deal with things like branch targets get executed, and then , finishes off the whole thing. Is that right?
And though your examples use this along the lines of inline assembler, it seems to me that one could of course use a different dictionary and produce code for another system, in words that one would save and then load into the other system. So you could do this assembly in Forth running on a modern PC, producing words for a 6502 system, right? (Isn't this essentially how a Forth metacompiler works?)
Also, do you have any way to mix Forth and assembly compilation within a single word, or does a word have be one or the other? Can assembly code call into Forth code?
Yes; "immediate" just means that when the word is encountered during compilation, it normally gets executed rather than compiled. (I say "normally" because there is also a way to compile immediate words.) That's one of the beauties of Forth. Even though the compiler is only something like a hundred bytes long (I haven't counted them), you can write a new word, even a word that defines other words, or forms a new structure of your own invention, and define both its compile-time behavior and its runtime behavior.
I won't go into that much here though, because when we assemble an assembly-language section in Forth, we're usually not in compile mode, ie, flag variable STATE is usually off (ie, the variable just contains a 0), meaning the input stream of source code gets executed, not compiled.
I can see how this could be confusing if not described well. I'll give it a try. When STATE is ON (ie, non-0), words encountered in the input stream get compiled, not executed (unless they're immediate). When STATE is OFF (ie, contains 0), words encountered are interpreted, ie, looked up in the dictionary to find their addresses to run right now. Assembly happens this way, ie, with STATE off. Take the example case of LDA#. If STATE were ON, the two-byte address of LDA# would get compiled (in ITC or DTC Forth, not STC). This is not what we want. We want it to actually do its job at that time, which is to lay down the machine-language op code, in this case $A9. In RPN assemblers (unlike mine), an LDA word would have more to do, to take what you put on the stack and determine which addressing mode to use, and lay down the correct op code and the correct length of operand (if any), or even report an error if for example you specified an addressing mode that the 6502 does not support for a particular instruction, like INC (ZP,X).
My work goes in waves, and there are long periods where I don't do any more than just the basics myself; so sometimes I have to look stuff up again too.
Not quite. I started out with CREATE ___ PRIMITIVE, where CREATE forms the header with the name you specify, and PRIMITIVE fixes the two-byte code field which is an address that points to the machine-language code you want to run when this word gets executed. In this case we want it to point to the very next byte which is where the code you're about to assemble starts. It does not turn STATE ON like : does. Later I changed it to CODE ____ so the header is generated with code field already correct without saying PRIMITIVE. Other systems' word CODE sets the vocabulary to the assembler vocabulary, and then you need END-CODE at the end of the assembly-language section to return the vocabulary to what it was before encountering the word CODE. I don't need a separate vocabulary for it though, because since I specify the addressing mode with every mnemonic, there's no confusing it as in the case of Forth's AND and 6502's assembly-language AND as I mentioned earlier, since the assembly-language one will always be AND#, AND_ZP, etc., never just AND by itself. It makes it simpler.
For non-Forthers: Vocabularies let you have different meanings of words, depending on context. An example that may be silly but makes the point is that "ball" has different meanings depending on whether the context is baseball, Times Square, dance, or bearings.
Yes; that would be a metacompiler. Forming a new system with a metacompiler works really neat if it works right. Unfortunately the only one I've used (around 1990) had some pretty serious bugs.
You can embed some assembly language in an otherwise high-level definition, like this:
: FOOBAR   ( n1 n2 - n3 n4 n5 f )
   BEGIN
       <do_stuff_in_Forth>
       <do_more_in_Forth>
   WHILE
       <do_something_else_in_Forth>
       INLINE
           <do_some_assembly_language>
           <do_some_more_assembly_language>
       END_INLINE
       <do_some_more_in_Forth>
   REPEAT       ;
I've written the INLINE and END_INLINE words per Bruce Clark's suggestion from F-PC, but have not used them yet, and I suspect it's rare. More common would be to just write the assembly-language part as a primitive and refer to that in the Forth word.
You can do basically anything you want; but my initial reaction to this one is one of avoidance. The closest I've come is that in my '816 Forth's system of prioritized very-low-overhead interrupt support, the interrupts that need the greatest performance in their servicing are of course serviced in assembly language, but then if there's a condition that needs special attention like to tell the user that there's a problem and ask him how he wants to handle it, it passes it on to a different ISR that handles it in high-level Forth.
I am mostly writing from a standpoint of indirect-threaded code (ITC) or direct-threaded code (DTC) Forth. I have not worked with subroutine-threaded code (STC) Forth which is where basically everything is converted to machine language, and can be a really hot performer, especially if the compiler's optimizer is intelligent enough to understand your goal and rework the approach to the way that's best suited for how the particular microprocessor works. In that case, for highly complex processors, there's almost no point in doing your own sections of assembly language, because there'd nothing to be gained. I took the following from Forth Inc.'s website. Their SwiftForth optimizer takes the following Forth source code for the common Forth word DIGIT
and turns out this assembly language:
with fewer instructions in machine language than in the Forth version! No one has written this kind of thing for the 6502 or '816 though, probably because there's just not the market to justify the number of programming man-hours to make such a product for 65xx, and also because 65xx (especially '816) assembly language is simple enough to write by hand. My '816 version is hardly any longer.
cjs
Post by cjs »
With such clear and descriptive variable names as STATE, how could anybody get confused? :-P
Anyway, I think I see what's going on here. Let me know if I've got any major errors in the following summary of my understanding of the Forth part of this.
Essentially there are two main interpreters in Forth. The first is the runtime interpreter (let's call it "interpreter I," unless there's a more standard name for it) which reads lexical tokens, looks them up in a dictionary (I am eliding parsing of numeric literals for the moment), and immediately executes the routines to which they refer. Then there is the "compiler" interpreter ("interpreter C") which reads lexical tokens and looks them up in the dictionary, but then checks to see if they're marked "immediate" or not. If the word is marked immediate it's executed just as with interpreter I, but if not a reference to the word is instead appended to a buffer it's using to build a new word to be added to the dictionary.
So a when interpreter I reads a ":", interpreter C is started, which reads the next lexical token as a name for the new word, allocates a buffer somewhere in which to build the word, and then continues parsing as described for interpreter C above. Eventually it reaches a ";" and, upon reading that, does whatever it needs to do to finish up the generation of the new word and then returns control to interpreter I.
(As a side note, this idea of multiple interpreters all sharing lexical analysis and data about the current system but interpreting identical series of lexical tokens in various different ways is central to Lisp, too. Central even to Lisp without macros, I mean; macros add a whole new level to this of course.)
Presumably it would be possible to add further interpreters that could also take over reading of the input stream and do their own thing, if they wanted to. (This may or may not require some changes to the core of the interpretation system.) One could use such a technique to write an interpreter for an assembly language compatible with Forth's lexical analyzer.
But in your case you've decided to embed assembly in a different way, by having words read and executed by interpreter I, which set up and use their own data areas to build and register new Forth words. And "C," and "," (used to generate instructions and finalize the new word, respectively?) are nothing special to the interpreter but just words to be called like any other.
This is very interesting, and I realize now that a similar technique is available to me in Python. Currently I seem to be heading towards the "separate interpreter" approach, where I build up a program in the language and then apply an interpreter function to it, e.g.,
    #   `ORG`, `LDX` etc. are just a variable names, bound in this environment.
    count = 4
    init = [ ORG, 0x300, LDX, count ]
    loop = [ 'loop:', DEX, BNE, 'loop', RTS ]
    obj = assemble(init + loop)
But an alternative would be to do the assembly on the fly using the Python interpreter itself to drive this execution:
    count = 4
    obj = Assembly()    # Object constructor.
       .org(0x300)      # Methods return `self` to allow
       .ldx(count)      #   method call chaining.
    obj.label('loop')   # You can resume assembly after interspersing
       .dex()           #   other host language code.
       .bne('loop')
       .rts()
A notable difference here is that this is latter approach seems a lot less readable in Python than it is in Forth. And of course, like Forth, this approach seems limited to being a one-pass assembler. (Though I suppose you could instead treat this as an intermediate object and ask the user to call .assemble() on it to get the assembly output.)
Well, perhaps not for optimization, but there are other good reasons to have in-line assembly, such as calling a routine written in another language or, perhaps, direct access to hardware.
It's simpler than that, and a new word gets formed directly where it will reside, without first going to a buffer or other data area. I'll try to find a concise way to describe it though, so we don't lose any remaining readers; maybe a flowchart. I could just post the code which is pretty short but still requires ability to read Forth, and then they won't use the ideas to apply to other languages either.
It's the compiler's state of being on or off.
Perhaps a nod to the routines written in other languages; but high-level Forth itself does not keep you from directly accessing hardware, only processor flags. You can try ideas in high-level Forth and then re-write the words as primitives (ie, in assembly language) without changing any of the code that uses them.
For a simple example, here're my words to initialize my 8-bit D/A and then write to it. It's a DAC0808 converter with an 8-bit parallel input and no clocking, and 150ns typical settling time. It's connected to VIA #2's port A, and initializing only involves making all 8 bits of VIA2PA to be outputs, by writing $FF (all 1's) to Data Direction Register A (DDRA). Then writing to the D/A converter only requires writing to Port A (PA) itself. First purely in Forth:
: INIT_D/A  FF VIA2DDRA C!  ;  ( -- )
: WR_D/A       VIA2PA   C!  ;  ( c -- )
and now in assembly for my workbench computer's onboard one-pass assembler:
CODE INIT_D/A     ( -- )
        LDY#      FF       C,
        STY_ABS   VIA2DDRA  ,
        JMP       NEXT      ,
CODE WR_D/A       ( byte -- )
        LDY_DP,X  TOS_LO   C,
        STY_ABS   VIA2PA    ,
        JMP       POP       ,
I use Y there because my '816 Forth keeps the index registers in 8-bit almost full time and the accumulator in 16-bit, and here I want an 8-bit operation. In the 6502 Forth, I just use A instead of Y. TOS_LO is top of stack (top data-stack cell), low byte. In the DP,X (or ZP,X) addressing modes, TOS_LO is just a 0, so you get 0,X.
Note that you can use almost any characters in Forth names, including <>/?!@#$%^&*+\|;:' and characters that aren't on the keyboard, so you could have a word with the name ±½°F or Ω/" (ohms per inch) for example. The Greek characters are especially useful in engineering. There are only a few you wouldn't want to put in a name, like <NUL>, <CR>, <LF>, <FF>, and sometimes ones that can be used as delimiters like " and ).
cjs
Post by cjs »
I just figured out how switching parsers works; it's explained on the Wikipedia Forth page at Parsing words and comments. Basically, words are able to consume the current input stream from the point just after they are executed, do what they will, and then when the main parser resumes it will continue after the text consumed by the parsing word.
Well, that's fair enough. Essentially, the "buffer" being filled is the target area of memory where the word will reside, then. Pretty much the same general idea.
...but high-level Forth itself does not keep you from directly accessing hardware, only processor flags.
Sure; for simple things where the equivalant of BASIC's PEEK(), POKE, IN() and OUT will do the trick, that's fine. But I was thinking of things like using the Apple II disk controller directly, where timing constraints are critical (certain loops must be a specific number of cycles), or switching in different bank of memory and copying something from it (where the Forth interpreter may no longer be mapped into the address space). For these sorts of things it may be possible to do them only with machine code.
Note that you can use almost any characters in Forth names...
Yup, I'm used to that. Lisp is similar; in the expression (- 5 3), the minus sign is just another variable name that happens to be bound to a particular function. You could even have fun confusing people, if that turns your crank, by using (let ((+ -)) (+ 5 3)) to do that same subtraction.
(The reader is in fact just an ordinary Lisp function, so you're free to replace it with something else if you like using, I don't know, BEGIN and END instead of ( and ), or even want a totally different syntax. Perhaps some people would find more pleasing a reader that interprets ' + ' - let 5 3 + as my let subtraction example above.)
BTW, just out of curiousity, what character set and encoding are you using on your system with those Greek characters and whatnot, and how do you deal with displaying them?
