Hello.
I has a question: how to configure emulator for use Sweet-16?
I took AppleWin, but i cannot load binary file at $F689.
Sweet-16 on Apple ii
- barrym95838
Re: Sweet-16 on Apple ii
If you select "Apple ][ (Original)" from the Configuration menu, Sweet16 will be waiting there for you at $F689.
If you would prefer a later Apple (with lower-case and Applesoft), all you need is a DOS 3.3 System Master disk image. When you boot, Integer BASIC and Sweet16 should load from the floppy into the language card area, and you can access them both by entering INT at the prompt.
yes, it works. Thank you!
Is way exists to switch banks via assembler? I found one call - $A59E
- barrym95838
I am glad I could help with your initial question, but bank switching is beyond my pay grade ... FP and INT from the command line are the only ways I have ever intentionally switched banks, in actual hardware and in emulation.
BTW, welcome to our world, dwesti!
I can't answer your question, but you might try this thread: And maybe Chapter 8 of Inside the Apple IIc? I don't have a grasp of the differences between the Apple II flavours.
BigEd, thank you, I will read
my attempt to use SW16, it generate A^2 table. Didn't understand all instructions, maybe code must be done simple:
ldy #0
jsr sw16
sub r0;set 0,0 ;r0=0
st 6 ;r6=r0
inr 6
rtn
mm
lda 0
sta sqt,y
lda 1
sta sqt+256,y
jsr sw16
add 6 ; r0=r0+r6
inr 6 ;r6+1
inr 6 ; r6+1
rtn
iny
bne mm
Working on SW16 and I had a question: SW16 uses R12 for store return adresses for RS/BS, seems ($18)=$FFFF. From other side writing data at adresses fails.
How to initialize data?
with
lda #$20
sta $18
lda #0
sta $19
- barrym95838
What AppleWin version works correct with original A2 ?
;234567890123456789012345678901234567890123456789012345
.CR 6502
.TF SWEET16B.OTX,AP1
.LF SWEET16B
; BEER SONG FOR THE SWEET16 PSEUDO-PROCESSOR ;
; BY BARRYM 2011-05-21 ;
; THE SWEET16 PSUEDO-PROCESSOR WAS CREATED BY STEVE ;
; WOZNIAK IN 1977 TO HELP HIM WRITE COMPACT (BUT ;
; SLOWER 16-BIT CODE ON HIS NEW BABY, THE APPLE ;
; II. HE NEVER BUILT IT IN HARDWARE, BUT INSTEAD ;
; CREATED A NIFTY LITTLE 372-BYTE INTERPRETER AND ;
; BURNED IT INTO THE ROM OF THE ORIGINAL INTEGER ;
; BASIC APPLE II. ;
; SWEET16 CODE AND 6502 CODE CAN CO-EXIST PEACEFULLY ;
; IN AN APPLE II MACHINE LANGUAGE PROGRAM; A 6502 ;
; 'JSR $F689' IMMEDIATELY PRECEDES A BLOCK OF IN- ;
; LINE SWEET16 INSTRUCTIONS AND A SWEET16 'RTN' ;
; SWITCHES BACK TO 6502 MODE, WHICH MUST BE DONE ;
; AT OR BEFORE PROGRAM COMPLETION. THE ORIGINAL ;
; APPLE II HAD AN UPPER-CASE 40-COLUMN DISPLAY AS ;
; STANDARD EQUIPMENT, SO THE OFFICIAL SONG LYRICS ;
; ARE ADJUSTED ACCORDINGLY. ;
; THANKS TO SBPROJECTS.COM FOR LOTS OF VALUABLE INFO ;
; AND A VERY NICE ASSEMBLER!! ;
; NOTE: 'ADD' AND 'SUB' ARE BUILT-IN 6502 MACROS IN ;
; THE CURRENT VERSION OF THIS ASSEMBLER AND WILL ;
; NOT ASSEMBLE TO THE CORRECT SWEET16 OPCODES (USE ;
; '.DA #$AX' FOR 'ADD X' & '.DA #$BX' FOR 'SUB X') ;
; CONSTANT EQUATES ;
SWEET16 = $F689 ROM: WOZ' INTERPRETER
BIN2ASC = $E51B ROM: PRINT UNSIGNED16
PUTCHAR = $FDED ROM: PRINT CHARACTER
MAXB = 99 MUST BE IN [1..65535]
; REGISTER EQUATES ;
ACC = $0 SWEET16 MAIN ACCUM.
BEER = $1 BEER COUNTER
TYPE = $2 SUBPHRASE TYPE
PTR = $3 TEXT POINTER
STK = $C SWEET16 STACK POINTER
; MAIN PROGRAM ;
.OR $0E00
MAIN JSR SWEET16 ENTER SWEET16 MODE
SET STK,$0110 INIT STACK POINTER
SET BEER,MAXB BEER = MAXB
.DA #$B0 (SUB ACC) TYPE = 0
BS PRSONG PRINT ENTIRE SONG
RTN BACK TO 6502 MODE
RTS EXIT
; MAIN LOOP: PRINT ALL EXCEPT THE LAST SENTENCE ;
BEERME SET PTR,TAKE PRINT "TAKE ONE ... AROUND,"
BS PRBOB PRINT " ... ON THE WALL."
PRSONG SET PTR,CR PRINT BLANK LINE
BS PRBOB PRINT " ... ON THE WALL";
DCR ACC TYPE = -1
SET PTR,COMCR PRINT ","
BS PRBOB PRINT " ... OF BEER."
INR ACC TYPE = +1
DCR BEER BEER = BEER - 1
BNM1 BEERME IF BEER <> -1 THEN BEERME
; SET UP LAST SENTENCE AND FALL THRU ;
; PRINT "GO TO ... SOME MORE,"
; SUBROUTINES FOLLOW ;
; PRINT A PROPERLY PUNCTUATED BOTTLE SUB-PHRASE ;
; (ENTRY): PTR CONTAINS PRE-STRING POINTER, ACC ;
; CONTAINS SUB-PHRASE TYPE (0 = " ... THE WALL", ;
; -1 = " ... OF BEER.", +1 = " ... THE WALL.") ;
; (EXIT): ACC IS CLEARED ;
PRBOB ST TYPE
BS PUTS PRINT PRE-STRING
LD BEER IF BEER = 0 THEN
BZ PRBOTT PRINT "NO MORE";
RTN IF BEER > 0 THEN
LDA $03 ESC TO 6502 MODE JUST LONG
LDX $02 ENOUGH TO PRINT VALUE OF
JSR BIN2ASC BEER TO ACTIVE OUTPUT.
JSR SWEET16+3
SET PTR,BOTTL
PRBOTT BS PUTS PRINT " ... BOTTLE";
DCR BEER
BNZ NEQ1 IF BEER = 1 THEN
INR PTR SKIP OVER THE "S"
NEQ1 INR BEER
BS PUTS PRINT " ... OF BEER";
LD TYPE
BM1 NOWALL IF TYPE >= 0 THEN
BS PUTS PRINT " ON THE WALL";
LD TYPE
BZ KPUT IF TYPE <> 0 THEN
NOWALL SET PTR,DOTCR PRINT "."
; PRINT A NULL-TERMINATED STRING @ PTR ;
; (ENTRY): PTR POINTS TO THE START OF THE STRING ;
; (EXIT): PTR POINTS TO THE NEXT STRING IN MEMORY, ;
; ACC IS CLEARED ;
PUTS LD @PTR GRAB CHAR @ PTR, ADVANCE PTR
BZ KPUT
RTN ESC TO 6502 MODE
LDA $00 JUST LONG ENOUGH
JSR PUTCHAR TO PRINT THE CHAR
JSR SWEET16+3 TO ACTIVE OUTPUT
BR PUTS LOOP UNTIL NULL
KPUT RS RETURN
; OPTIMIZED SONG LYRIC STRING ;
TAKE .AS -"TAKE ONE DOWN AND PASS IT AROUND"
COMCR .AS -","
CR .AZ -#13
.AS -"NO MORE"
BOTTL .AZ -" BOTTLE"
.AZ -"S OF BEER"
.AZ -" ON THE WALL"
DOTCR .AZ -".",#13
.AZ -"GO TO THE STORE AND BUY SOME MORE,",#13
.EN
; HEX DUMP FOLLOWS. IF YOU COPY AND PASTE THIS INTO ;
; AN APPLE II EMULATOR SUCH AS APPLEWIN 1.17.2.0, ;
; (MY PERSONAL FAVORITE), PLEASE MAKE SURE THAT IT ;
; IS SET TO ORIGINAL APPLE II MODE (INTEGER BASIC ;
; MUST BE AVAILABLE IN ROM OR ON A LANGUAGE CARD ;
; IN ORDER FOR THIS PROGRAM TO WORK). ENJOY! :-) ;
CALL-151
0E00: 20 89 F6 1C 00 01 11 63 00 B0 0C 07 00 60 13 5C
0E10: 0E 0C 12 13 7D 0E 0C 0D F0 13 7C 0E 0C 07 E0 F1
0E20: 09 EC 11 63 00 32 0C 25 21 06 0E 00 A5 03 A6 02
0E30: 20 1B E5 20 8C F6 13 86 0E 0C 12 F1 07 01 E3 E1
0E40: 0C 0B 22 08 05 0C 06 22 06 11 13 A5 0E 43 06 0B
0E50: 00 A5 00 20 ED FD 20 8C F6 01 F2 0B D4 C1 CB C5
0E60: A0 CF CE C5 A0 C4 CF D7 CE A0 C1 CE C4 A0 D0 C1
0E70: D3 D3 A0 C9 D4 A0 C1 D2 CF D5 CE C4 AC 8D 00 CE
0E80: CF A0 CD CF D2 C5 A0 C2 CF D4 D4 CC C5 00 D3 A0
0E90: CF C6 A0 C2 C5 C5 D2 00 A0 CF CE A0 D4 C8 C5 A0
0EA0: D7 C1 CC CC 00 AE 8D 00 C7 CF A0 D4 CF A0 D4 C8
0EB0: C5 A0 D3 D4 CF D2 C5 A0 C1 CE C4 A0 C2 D5 D9 A0
0EC0: D3 CF CD C5 A0 CD CF D2 C5 AC 8D 00
E00GE000G
barrym95838,
thank you for example.
Can you explain how bytecode Dr works?
I've found description, but I do not understand:
;DR 1 ACC<-ACC-R
;Dn CPR n R13 <-- (R0) - (Rn),R14 <-- status flags.
;Dr CMP r RD=R0-Rr, set status Compare result to RD,w:CPR Rn compare
