It is currently Sun Nov 24, 2024 3:45 am
 Post subject: Sweet-16 on Apple ii
PostPosted: Wed Oct 31, 2018 6:48 am
Hello.
I has a question: how to configure emulator for use Sweet-16?
I took AppleWin, but i cannot load binary file at $F689.
 Post subject: Re: Sweet-16 on Apple ii
PostPosted: Wed Oct 31, 2018 7:56 am
If you select "Apple ][ (Original)" from the Configuration menu, Sweet16 will be waiting there for you at $F689.
If you would prefer a later Apple (with lower-case and Applesoft), all you need is a DOS 3.3 System Master disk image. When you boot, Integer BASIC and Sweet16 should load from the floppy into the language card area, and you can access them both by entering INT at the prompt.
PostPosted: Wed Oct 31, 2018 1:15 pm
yes, it works. Thank you!
Is way exists to switch banks via assembler? I found one call - $A59E
PostPosted: Wed Oct 31, 2018 3:16 pm
I am glad I could help with your initial question, but bank switching is beyond my pay grade ... FP and INT from the command line are the only ways I have ever intentionally switched banks, in actual hardware and in emulation.
PostPosted: Wed Oct 31, 2018 4:38 pm
BTW, welcome to our world, dwesti!
I can't answer your question, but you might try this thread:
And maybe Chapter 8 of Inside the Apple IIc? I don't have a grasp of the differences between the Apple II flavours.
PostPosted: Wed Oct 31, 2018 4:49 pm
BigEd, thank you, I will read
my attempt to use SW16, it generate A^2 table. Didn't understand all instructions, maybe code must be done simple:
ldy #0
jsr sw16
sub r0;set 0,0 ;r0=0
st 6 ;r6=r0
inr 6
rtn
mm
lda 0
sta sqt,y
lda 1
sta sqt+256,y
jsr sw16
add 6 ; r0=r0+r6
inr 6 ;r6+1
inr 6 ; r6+1
rtn
iny
bne mm
PostPosted: Sun Mar 31, 2019 8:26 pm
What AppleWin version works correct with original A2 ?
Working on SW16 and I had a question: SW16 uses R12 for store return adresses for RS/BS, seems ($18)=$FFFF. From other side writing data at adresses fails.
How to initialize data?
with
   lda #$20
   sta $18
   lda #0
   sta $19
interpreter working right.
PostPosted: Mon Apr 01, 2019 6:40 am
I have used 1.17.2.0 and 1.20.0.0 with some success.
Here's a complete example, in which I use sbasm and init register $C with a SET STK,$0110 directly after I JSR SWEET16 in MAIN:
;234567890123456789012345678901234567890123456789012345
        .CR  6502
        .TF  SWEET16B.OTX,AP1
        .LF  SWEET16B
; BEER SONG FOR THE SWEET16 PSEUDO-PROCESSOR          ;
;    BY BARRYM 2011-05-21                             ;
; THE SWEET16 PSUEDO-PROCESSOR WAS CREATED BY STEVE   ;
;    WOZNIAK IN 1977 TO HELP HIM WRITE COMPACT (BUT   ;
;    SLOWER 16-BIT CODE ON HIS NEW BABY, THE APPLE    ;
;    II.  HE NEVER BUILT IT IN HARDWARE, BUT INSTEAD  ;
;    CREATED A NIFTY LITTLE 372-BYTE INTERPRETER AND  ;
;    BURNED IT INTO THE ROM OF THE ORIGINAL INTEGER   ;
;    BASIC APPLE II.                                  ;
; SWEET16 CODE AND 6502 CODE CAN CO-EXIST PEACEFULLY  ;
;    IN AN APPLE II MACHINE LANGUAGE PROGRAM; A 6502  ;
;    'JSR $F689' IMMEDIATELY PRECEDES A BLOCK OF IN-  ;
;    LINE SWEET16 INSTRUCTIONS AND A SWEET16 'RTN'    ;
;    SWITCHES BACK TO 6502 MODE, WHICH MUST BE DONE   ;
;    AT OR BEFORE PROGRAM COMPLETION.  THE ORIGINAL   ;
;    APPLE II HAD AN UPPER-CASE 40-COLUMN DISPLAY AS  ;
;    STANDARD EQUIPMENT, SO THE OFFICIAL SONG LYRICS  ;
;    ARE ADJUSTED ACCORDINGLY.                        ;
; THANKS TO SBPROJECTS.COM FOR LOTS OF VALUABLE INFO  ;
;    AND A VERY NICE ASSEMBLER!!                      ;
; NOTE:  'ADD' AND 'SUB' ARE BUILT-IN 6502 MACROS IN  ;
;    THE CURRENT VERSION OF THIS ASSEMBLER AND WILL   ;
;    NOT ASSEMBLE TO THE CORRECT SWEET16 OPCODES (USE ;
;    '.DA #$AX' FOR 'ADD X' & '.DA #$BX' FOR 'SUB X') ;
; CONSTANT EQUATES                                    ;
SWEET16  =   $F689        ROM: WOZ' INTERPRETER
BIN2ASC  =   $E51B        ROM: PRINT UNSIGNED16
PUTCHAR  =   $FDED        ROM: PRINT CHARACTER
MAXB     =   99           MUST BE IN [1..65535]
; REGISTER EQUATES                                    ;
ACC      =   $0           SWEET16 MAIN ACCUM.
BEER     =   $1           BEER COUNTER
TYPE     =   $2           SUBPHRASE TYPE
PTR      =   $3           TEXT POINTER
STK      =   $C           SWEET16 STACK POINTER
; MAIN PROGRAM                                        ;
        .OR  $0E00
MAIN    JSR  SWEET16      ENTER SWEET16 MODE
        SET  STK,$0110    INIT STACK POINTER
        SET  BEER,MAXB    BEER = MAXB
        .DA  #$B0         (SUB ACC) TYPE = 0
        BS   PRSONG       PRINT ENTIRE SONG
        RTN               BACK TO 6502 MODE
        RTS               EXIT
; MAIN LOOP:  PRINT ALL EXCEPT THE LAST SENTENCE      ;
BEERME  SET  PTR,TAKE     PRINT "TAKE ONE ... AROUND,"
        BS   PRBOB        PRINT " ... ON THE WALL."
PRSONG  SET  PTR,CR       PRINT BLANK LINE
        BS   PRBOB        PRINT " ... ON THE WALL";
        DCR  ACC          TYPE = -1
        SET  PTR,COMCR    PRINT ","
        BS   PRBOB        PRINT " ... OF BEER."
        INR  ACC          TYPE = +1
        DCR  BEER         BEER = BEER - 1
        BNM1 BEERME       IF BEER <> -1 THEN BEERME
; SET UP LAST SENTENCE AND FALL THRU                  ;
;                         PRINT "GO TO ... SOME MORE,"
; SUBROUTINES FOLLOW                                  ;
; PRINT A PROPERLY PUNCTUATED BOTTLE SUB-PHRASE       ;
; (ENTRY): PTR CONTAINS PRE-STRING POINTER, ACC       ;
;    CONTAINS SUB-PHRASE TYPE (0 = " ... THE WALL",   ;
;    -1 = " ... OF BEER.", +1 = " ... THE WALL.")     ;
; (EXIT):  ACC IS CLEARED                             ;
PRBOB   ST   TYPE
        BS   PUTS         PRINT PRE-STRING
        LD   BEER         IF BEER = 0 THEN
        BZ   PRBOTT          PRINT "NO MORE";
        RTN               IF BEER > 0 THEN
        LDA  $03             ESC TO 6502 MODE JUST LONG
        LDX  $02             ENOUGH TO PRINT VALUE OF
        JSR  BIN2ASC         BEER TO ACTIVE OUTPUT.
        JSR  SWEET16+3
        SET  PTR,BOTTL
PRBOTT  BS   PUTS         PRINT " ... BOTTLE";
        DCR  BEER
        BNZ  NEQ1         IF BEER = 1 THEN
        INR  PTR             SKIP OVER THE "S"
NEQ1    INR  BEER
        BS   PUTS         PRINT " ... OF BEER";
        LD   TYPE
        BM1  NOWALL       IF TYPE >= 0 THEN
        BS   PUTS            PRINT " ON THE WALL";
        LD   TYPE
        BZ   KPUT         IF TYPE <> 0 THEN
NOWALL  SET  PTR,DOTCR       PRINT "."
; PRINT A NULL-TERMINATED STRING @ PTR                ;
; (ENTRY): PTR POINTS TO THE START OF THE STRING      ;
; (EXIT):  PTR POINTS TO THE NEXT STRING IN MEMORY,   ;
;          ACC IS CLEARED                             ;
PUTS    LD   @PTR         GRAB CHAR @ PTR, ADVANCE PTR
        BZ   KPUT
        RTN               ESC TO 6502 MODE
        LDA  $00             JUST LONG ENOUGH
        JSR  PUTCHAR         TO PRINT THE CHAR
        JSR  SWEET16+3       TO ACTIVE OUTPUT
        BR   PUTS         LOOP UNTIL NULL
KPUT    RS                RETURN
; OPTIMIZED SONG LYRIC STRING                         ;
TAKE    .AS  -"TAKE ONE DOWN AND PASS IT AROUND"
COMCR   .AS  -","
CR      .AZ  -#13
        .AS  -"NO MORE"
BOTTL   .AZ  -" BOTTLE"
        .AZ  -"S OF BEER"
        .AZ  -" ON THE WALL"
DOTCR   .AZ  -".",#13
        .AZ  -"GO TO THE STORE AND BUY SOME MORE,",#13
        .EN
; HEX DUMP FOLLOWS.  IF YOU COPY AND PASTE THIS INTO  ;
;    AN APPLE II EMULATOR SUCH AS APPLEWIN 1.17.2.0,  ;
;    (MY PERSONAL FAVORITE), PLEASE MAKE SURE THAT IT ;
;    IS SET TO ORIGINAL APPLE II MODE (INTEGER BASIC  ;
;    MUST BE AVAILABLE IN ROM OR ON A LANGUAGE CARD   ;
;    IN ORDER FOR THIS PROGRAM TO WORK).  ENJOY!  :-) ;
CALL-151
0E00: 20 89 F6 1C 00 01 11 63 00 B0 0C 07 00 60 13 5C
0E10: 0E 0C 12 13 7D 0E 0C 0D F0 13 7C 0E 0C 07 E0 F1
0E20: 09 EC 11 63 00 32 0C 25 21 06 0E 00 A5 03 A6 02
0E30: 20 1B E5 20 8C F6 13 86 0E 0C 12 F1 07 01 E3 E1
0E40: 0C 0B 22 08 05 0C 06 22 06 11 13 A5 0E 43 06 0B
0E50: 00 A5 00 20 ED FD 20 8C F6 01 F2 0B D4 C1 CB C5
0E60: A0 CF CE C5 A0 C4 CF D7 CE A0 C1 CE C4 A0 D0 C1
0E70: D3 D3 A0 C9 D4 A0 C1 D2 CF D5 CE C4 AC 8D 00 CE
0E80: CF A0 CD CF D2 C5 A0 C2 CF D4 D4 CC C5 00 D3 A0
0E90: CF C6 A0 C2 C5 C5 D2 00 A0 CF CE A0 D4 C8 C5 A0
0EA0: D7 C1 CC CC 00 AE 8D 00 C7 CF A0 D4 CF A0 D4 C8
0EB0: C5 A0 D3 D4 CF D2 C5 A0 C1 CE C4 A0 C2 D5 D9 A0
0EC0: D3 CF CD C5 A0 CD CF D2 C5 AC 8D 00
E00GE000G
PostPosted: Tue Apr 02, 2019 9:21 am
barrym95838,
thank you for example.
Can you explain how bytecode Dr works?
I've found description, but I do not understand:
;DR   1   ACC<-ACC-R
;Dn          CPR  n          R13 <-- (R0) - (Rn),R14 <-- status flags.
;Dr CMP r RD=R0-Rr, set status Compare result to RD,w:CPR Rn compare
Users browsing this forum: No registered users and 70 guests
cron
