Advice on laying out a PCB...
Posted: Fri Sep 28, 2018 1:54 pm
I'm in the layout and routing stage of my next SBC. This one is quite a bit larger than the others I've done in the past. It's a 2-layer board that also contains some headers (or slots). I got most of the board done with manual tracing (they removed the autorouter in KiCad 5...which may be a good thing for me).
Actually got about 2/3's done when I realized that in order to finish the last 1/3, I would need an obscene amount of via's. I was quite proud that I had almost no via's up to that point.
I also have an Apple IIe motherboard I am studying for reference. I noticed they used the "classic" pattern of horizontal traces on the top layer and vertical traces on the bottom.
Frustrated, I deleted all of my traces to start again. I also moved my components around to try for a better layout. What confuses me is that the A2 seemed to put all of the components upside down (pin 1 facing down). Also, none of the components run perpendicular to each other. They are all parallel (vertically oriented). Which I really like. Having OCD I'm really attracted to things that are symmetrical.
I'm going to take a multimeter and see if I can determine how they ran those traces. In the meantime, do you have any suggestions on how I can achieve something similar?
Board size is obviously an issue but I'm not interested in having a super tiny board. Even if it means costing a little more.
Could I skip the ground traces and just wait until the last minute after I do a ground pour? Then connect them to the pour? Or, should I always do both power traces first?
I did, however, use a much thicker trace for the power lines.
Oh, one more thing...I seemed to notice that the A2 board doesn't have traces BETWEEN pins. Not that I can see. This is even more amazing if you ask me because I was running traces between pins and I still couldn't finish. :-/
Thanks for any tips!
