Subject pretty much says it all.
The protoboard I'm making will assume you have a DS1813. If so, do I still need to put a pull-up resistor on the RESET line?
Thanks
Does RESET meed a pull-up if using a DS1813?
Re: Does RESET meed a pull-up if using a DS1813?
No. As explained in the datasheet, the DS1813 includes an internal pullup resistor.
- BigDumbDinosaur
Just to confirm, I am using the DS1813 in my project without an external pullup.
My 6502 Game System: https://hackaday.io/project/9325-dodo-6 ... ame-system
Thanks for the information.
@BDD
Concerning the 5.5K pullup, I normally use 3.3K. That shouldn't be a problem, usually. Right?
Thanks
@BDD
Thanks
- BigDumbDinosaur
@BDD
Thanks
@BDD
Thanks
