Does RESET meed a pull-up if using a DS1813?
cbmeeks
Post by cbmeeks »
Subject pretty much says it all.
The protoboard I'm making will assume you have a DS1813. If so, do I still need to put a pull-up resistor on the RESET line?
Thanks
Re: Does RESET meed a pull-up if using a DS1813?
No. As explained in the datasheet, the DS1813 includes an internal pullup resistor.
One thing to note is theDS1813's internal pullup is 5.5K.
pnoyes
Post by pnoyes »
Just to confirm, I am using the DS1813 in my project without an external pullup.
cbmeeks
Post by cbmeeks »
Thanks for the information.
@BDD
Concerning the 5.5K pullup, I normally use 3.3K. That shouldn't be a problem, usually. Right?
Thanks
@BDD
Thanks
I use 3.3K as well and have not run into any issues with it.
