I know a good number of you have more experience at more up-to-date design principles than I do, so I beg to pick your brains.
In the past, most of my designs have been for slower systems (<= 4MHz). Now I'd like to up that to 20MHz. So, my questions are as follows:
1) Do ground and VCC planes cause more problems from added capacitance than they solve WRT noise suppression at these frequencies?
2) Do ground or VCC connected inter-trace copper pours help keep the noise down?
3) Hence, which are better, voltage planes, or inter-trace pours, or both?
4) Are there any other critical things I may need to know to avoid grief at these clock frequencies?
Any and all help is appreciated.
PCB design questions
ElEctric_EyE
First thing to consider is your clock source. It needs to be well powered with thick traces and well bypassed first of all. Also, you can't just jump in at 20MHz. I think most here will agree with me that there are so very many other variables that can screw up a design from the outset. You may want to consider either a variable frequency source like a VCO, or have more than a few "can" oscillators you can swap in and out in order to test your design at will.
Thanks E_E. Just not sure that approach will work in a financially feasible way when committing the design to copper. I need to get it right the first time if possible.
I found this:
http://www.altera.com/literature/an/archives/an075.pdf
It goes into techniques for GHz applications and some of it might prove helpful. Still, any actual 'real life' experience will be most beneficial.
I found this:
- BigDumbDinosaur
Re: PCB design questions
In multilayer designs, "planes" generally refer to inner layers that distribute Vcc and Gnd to the circuit. In such a design, the two planes act as a giant capacitor, as well as electrostatic shields, and hence offer a number of benefits:
- Virtually no crosstalk between traces on opposites side of the board, especially in cases where traces are coincidental.
- Greatly improved noise immunity. Due to the large capacitance between the power and ground planes, switching noise is suppressed to an extent not otherwise possible.
- No ground bounce. The ESR (effective series resistance) of the ground plane is a tiny fraction of an ohm, so stability killing ground bounce is eliminated.
- Improved Vcc regulation. As with the ground plane, the power plane has vanishingly small ESR, so every component sees the full voltage, and that voltage is as stable as the power source.
- Better board density. Not having to run Vcc and Gnd traces everywhere means your circuit can fit into less board area (real estate). Aside from possibly reducing the cost of the board, the tighter density helps to keep the signal traces short (see below).
- Keep signal traces as short and direct as possible. Long traces produce more reactance and cause waveform distortion that can lead to anomalous chip behavior.
- Avoid circular routing, that is, routing traces so they wind around several pins to which they are not connected.
- Work with the smallest trace width that is consistent with the current that will pass through it. For most digital work, traces widths can be in the .006" to .007" range, and via should be .025" to .030" diameter. I used .006" inch on my POC unit, with .026" via. It will run at 15 MHz without the SCSI host adapter plugged in. The trace width can become critical when multiple traces run parallel to each other.
- Limit trace routing to vertical, horizontal and 45 degrees. In my designs, vertical traces are on the component side and horizontal are on the solder side. The side for angle traces is dependent on the board layout, so I really can't suggest anything specific.
- Arrange your clock signal source so the distance from the source to the chips that use it is approximately equal in all cases. As the frequency increases, slew rate becomes critical. If four chips have short paths to the clock and the fifth has a long path, that fifth chip will be operating slightly out of phase with the others.
- Be liberal with your bypass capacitors. Every chip should be bypassed and the capacitor should be as close to the chip as possible. Bypass capacitors are cheap. Scrapping a PCB because it suffers from noise-induced instability is not. A good choice for most bypassing is 0.1uF MLCC, with a 50 VDC rating, of the X7R type. The seemingly high voltage rating has to do with a quirk in MLCC capacitors that causes them to "derate" themselves when the instantaneous voltage exceeds the working rating. The result is less bypassing than expected. The particular brand I used on the POC is AVX, part number SR275E104MAA. Scoping the circuit shows that it is dead quiet.
- Be sure to add some electrolytics to the bypass capacitor roster, including one right at the point where power is applied to the board. Use low ESR electrolytics, with a working voltage as low as practical. Also bypass the electrolytic with a 0.1uF capacitor to assure adequate noise dissipation.
- If possible, use PLCC and other small outline packages. You'll get a tighter layout, and in many cases, may find trace routing to be easier. When I designed the PCB for the POC unit, I did layouts for both the DIP40 and PLCC44 versions of the MPU (65C816). The PLCC44 part used about 60 percent of the area of the DIP40 part, and I was able to use shorter traces to make the critical address and data bus connections.
- Avoid chip sockets.
- Place pullup resistors as close to the device(s) they serve as possible. This is especially important with IRQ, which is wire-ORed and therefore vulnerable to a lazy rise transition due to distributed capacitance.
- Speaking of pullup resistors, SIP or DIP resistor packages typically insert less capacitance into the circuit than discrete parts (especially carbon comp resistors). Also consider that other leaded components can put reactance into your circuit and possibly sabotage timing.
Something that is somewhat hard to explain is that PCB layout has a sort of feng shui to it, which becomes obvious after you've played around with it. Owing to the way certain packages are pinned out and the relationships between the components in your design, parts positioning tends to develop a natural flow. I really don't know how to explain it, anymore that a musician can clearly explain how to get music from an instrument.
In that respect, I'm reminded of an incident that supposedly occurred while J.S. Bach was instructing one of his organ students. The student was having trouble with one of Bach's pieces and finally Bach, who was reputed to have less than ideal patience, sat down at the organ and started playing. "See," he exclaimed to his student," all you have to do is press the right keys at the right time and the organ will make music." Hopefully your board design will flow as easily as Bach's music did from his mind and hands
- GARTHWILSON
- Forum Moderator
I was gone all day and it has been hard to catch up on everything tonight. It has been pretty crazy, and I have not been able to read the Altera ap. note referenced above yet, but I'll try to write some things here, then come back later with more, depending on the questions & comments. Dr. Howard Johnson is an industry guru on high-speed digital design, and I've kept many, many of his articles in the trade magazines over the years, and you can find most of them on the web. Our stuff is very slow compared to what he is usually addressing, but our parts are bigger too, and pricewise, we may not be able to afford going to the lengths on our boards that he deals with. I see BDD posted while I was interrupted in my writing, but I'll keep going here anyway.
Consider the rise time of fast parts too. It's a major issue.
No. You must have a gound plane. Vcc plane is a further improvement. Without the Vcc plane, you can bypass Vcc pins to ground super close to the pin, but that's definitely second-best, not the preferable way. BTW, having a ground plane eliminates the ground bounce up to the ground connection of the IC, but there's still inductance between where the pin is soldered and up the pin and through the bondwire to the die, and that will cause a little groundbounce with fast switching times; but you can't do anything about that part.
No. Copper pours are helpful for high-impedance circuits where one trace can couple into another by capacitive means. The AC-signal part of high-speed digital is low-impedance, and the major thing is the inductive coupling and inductance, and for longish traces, transmission-line effects. To keep a line from coupling into other traces, the trace needs to run along a ground plane. The return current in the ground plane does not take the shortest route, but instead goes directly under the trace, taking the shape of the trace, because the mutual inductance makes that the path of least impedance. If the plane is interrupted, it's no good for that. It has to be continuous; so pours don't qualify.
Forget about the pours. There is a way to use them to supplement real planes; but if they're not done correctly, they can actually make things worse, according to experts in the field like Rick Hartley, Eric Bogatin, and Suzie Web whose lectures you can see on Altium's YouTube channel.
Make the board (or at least the high-speed part of it) small, and put parts close together so as to minimize the trace lengths.
Use chip capacitors for power-supply bypass as their inductance is a lot less than leaded capacitors'.
I don't limit my traces to 0, 45, and 90°. I do it however gets me the best density, shortest traces, best manufacturability, etc.. I've never had any trouble with .015" vias on .062"-thick board, or even .008" vias on .032"-thick board. The narrow (eg, .006") that BDD was talking about are not delicate like some might think. I've laid out dozens of extremely dense boards for our products, up to 500 parts and 12 layers normally .006" trace & space and .015" vias, with pads .020" bigger than the holes (so for example a .015" via has a .035" pad).
related posts:
viewtopic.php?p=789#p789
viewtopic.php?p=945#p945
viewtopic.php?p=13264#p13264
If you want to email me your layout (or post it for everyone to see on the forum) to look at before you get it made, or even before you're done, I'll look. jpegs would probably be easiest for me, but I can take gerbers too and look at them with the gerber viewer so I can zoom way in, view a different combination of layers, etc.. I've done a lot of layout, including switching power supplies which are particularly nasty because of the astronomical di/dt's, and gotten outstanding performance.
related posts:
