Page 14 of 15
Posted: Tue Apr 19, 2011 9:15 pm
by ElEctric_EyE
OK, cool. I see the declaration in the cpu module:
reg  [7:0] AXYS[3:0]; 	// A, X, Y and S register file
I would've responded earlier...
I got sidetracked setting up my old C-64 system and decided to start a new thread for the software side of 6502SoC.
Back to working on the 6502SoC Flash interface tomorrow...
Posted: Wed Apr 20, 2011 1:49 pm
by ElEctric_EyE
OK, I think I got the Flash interface working @6MHz, finally! Using a top level bidirectional data bus is a very important building block. The display is clearing Black and reading $FF from the Flash and displaying White as expected...
Now plans are to use RDY.
ISE is saying Max Frequency of the project is @54.8MHz. I would like to run the CPU @48MHz now, put wait states to interface to the Display @38MHz, and more wait states to interface to the Flash @6MHz.
Posted: Wed Apr 20, 2011 2:43 pm
by Arlet
You could run the CPU at 48 MHz, and have a simple RDY signal that's '1' for one cycle, and '0' for 7 cycles. This should produce the same results as your 6 MHz test, and should be easy to set up.
Posted: Wed Apr 20, 2011 7:11 pm
by ElEctric_EyE
Shoot, I did mean 12MHz for the Flash. Sorry, my brain needs a rest!
But the RDY is an easy 1:4 ratio from the Flash 12MHz to the CPU 48MHz, unlike the 4:5 ratio of the Video 38MHZ to CPU 48MHz.
I have to get the Flash and the Display working together for me to test.
Posted: Thu Apr 21, 2011 6:47 pm
by ElEctric_EyE
OK I needed to get in the right frame of mind to think about this, aside from the excitement of firing up the 64 again. What better place than work to remove that excitement!...
This is what I understand so far:
From looking at Daryl's (8bit) and BDD's wait state circuits, I need to assert/deassert RDY during Phase 2 high.
RDY will be applied only during chip select actives.
The amount of time RDY is held active is the variable I need to find out for each device.
But to give me better resolution for the RDY active time, I think a good thing to do would be to use a DCM to double the phase 2 frequency to 97MHz (48.58x2)...
Posted: Thu Apr 21, 2011 7:01 pm
by Arlet
The 6502 core won't go as fast as 97MHz. I also don't have phase 1/phase 2 clocks in my core, just a single clock input.
The RDY signal needs to be asserted/deasserted on rising edges of this clock, just like any other input/output signal to the core.
Also, don't forget there's an extra cycle delay when the core reads from memory. It presents the address on the AB bus, and on the next cycle, it expects the data on DI.
Posted: Thu Apr 21, 2011 7:14 pm
by ElEctric_EyE
Arlet wrote:
The 6502 core won't go as fast as 97MHz. I also don't have phase 1/phase 2 clocks in my core, just a single clock input...
The cpu would still run @48.58MHz... The 97MHz would run a 2 to 4 bit counter to feed RDY, and would count 0 to X(whatever is needed for each device) on the rising edge (both frequency's would have the same rising edge since 1 is just 2X the other). It would give finer resolution to avoid delaying the CPU any more than absolutely necessary.
Arlet wrote:
...The RDY signal needs to be asserted/deasserted on rising edges of this clock, just like any other input/output signal to the core.
Rising edges, yes. I need to think edges, not levels, especially since FF's are involved.
Arlet wrote:
...Also, don't forget there's an extra cycle delay when the core reads from memory. It presents the address on the AB bus, and on the next cycle, it expects the data on DI.
I have a FF for the Flash RE signal delaying it one cycle. The Flash WE is just logic, no FF.
Actually, the same is true for my 2 Flash bank address registers(A10-A17) and (A18-A20, 5 bits unused). I think I also have the Flash CS delayed one cycle too. I will have to check about the CS when I get home tonight, I have the newest project files on another computer at home. Forgot to update this computer...
__________________________________________________________________________________________________________________________
No, the CS is not delayed. I know this would've screwed up the WE, but at one point I was testing this scenario.
Posted: Fri Apr 22, 2011 5:12 am
by Arlet
There's no point in letting the RDY go faster than the CPU clock. You can only delay the CPU by whole clock cycles. Also, I would let the RDY delay counter count down, that way you only need to test for 0.
As far as the delay cycle, it's best to put flip-flops on the AB output, the DO, the WE, and the CS (CS needs to be derived from original AB). That way, all signals have nice clean edges at the same time, without any glitches, as they leave the FPGA. There are special flip-flops built into the pads for this purpose, and the tool is smart enough to use those.
Posted: Fri Apr 22, 2011 12:38 pm
by ElEctric_EyE
Ok, understood about the RDY cycle. I'm making a new module for it and will be able to test it in the next few days.
Arlet wrote:
...As far as the delay cycle, it's best to put flip-flops on the AB output, the DO, the WE, and the CS...
I seem to have done an inverse, and delayed the RE only, and it seems to work.
But you are saying to delay ABout, DO, and WE and not RE?
Posted: Fri Apr 22, 2011 1:17 pm
by Arlet
I think it's best to delay all outputs, including RE. The idea is that everything will then be synchronous, but just 1 cycle delayed. The extra flip flops will create nice clean edges and the tools can guarantee you meet the timing requirements.
With a bunch of combinatorial signals, you never know which signal will come first. You don't want WE to be asserted when AB is still unstable.
ETA: Also, when you delay everything equally, you won't have a problem with alternating read/write cycles. For instance, when you only delay RE, and you do a read cycle, followed by a write, the original WE and the delayed RE will be asserted at the same time. Therefore you'll need to delay WE as well, and if you delay WE, you'll need to delay AB and DO, otherwise you write the wrong data in the wrong address.
Posted: Sat Apr 23, 2011 12:01 am
by ElEctric_EyE
Ok, that does make sense, alot of sense!
I will have a chance to put this concept to work by the end of Sunday. Also, will try the RDY circuit, and report back.
Posted: Sun Apr 24, 2011 10:47 pm
by ElEctric_EyE
The RDY concept is perplexing me, unable to post progress, because I don't full understand the concept. Gonna put it on the back burner for the moment and continue progressing on the software hack side...
But I did put all WE and RE signals through FF's successfully. Also the 6502 DOs, the ones that go offchip. The DOs for the internal bidirectional ports don't need to be delayed. Also, the ABInt does not need to be delayed. ISE gave a mention that they were already qualified by O2.
Posted: Wed Apr 27, 2011 2:41 pm
by ElEctric_EyE
Forgetting RDY (sorry Arlet, but I really do appreciate your efforts to add that), doing an automatic speed switch based on address decoding didn't work. I decided to go back to what I know has worked in my PWA project, and that is a programmable speed bit. Implementing the same concept in the FPGA works in ISim and the hardware I tested this morning.
Now it's time to work on an I2C core that controls the DS1085 frequency synthesizer. The datasheet assures the fact that it also does not have glitches on the output when the frequency is changed.
Posted: Wed Apr 27, 2011 11:24 pm
by ElEctric_EyE
In honor of 10K+ views and especially for those who have helped me progress to this point, I post schematics, including Richard Herveille's I2C core.
Still working on drivers for it, but everything else is functioning with his core present , including the 2 external 4.7K pull-up resistors for SCL and SDA.
The FPGA has an internal pull-up function too, but I think I read they're only good for around 12K.
His documentation is abit tricky, so I am forced to interpret his VHDL, as far as his register assignments and that even is a little tricky.
His registers seem to change based on whether his I2C Master Core is reading or writing to a device, I'm not sure why... But I do intend to use his core for write only operation. So I think I have it straight.
This is the 6502SoC Top_Level Schematic so far (I'll try to fix the blockiness of the smaller fonts):
Here are the modules from above:
Clock Control Module
TimingControl Module
Addr_Decode Module
DataOutRegisters
DataInMUXx
IO
Posted: Fri Apr 29, 2011 11:22 pm
by ElEctric_EyE
Gonna hold off on working with the I2C Core at the moment, but I'll still leave it in. Need to get the PS2 Core up and running with a keyboard scan routine.
