ttlworks wrote:
In NMOS, input protection breaks down to having a resistor on diffusion layer
between the pad and a NMOS FET which switches to GND in case of a negative signal voltage,
before said signal enters the first inverter.
ttlworks wrote:
The designers seemed to have used the "copy&paste" approach for building the logic gates,
means that identifying the logic gates is quite easy.
The layout of a gate sometimes is mirrored, rotated by 180°, or both.
//...But never by 90°.
ttlworks wrote:
A 2:1 multiplexer actually is a quite powerful device:
[...] you creatively wire up the data inputs and the select input of a 2:1 multiplexer,
said multiplexer can replace any type of a two input logic gate.
ttlworks wrote:
Merry Christmas,
and a Happy New Year.
