Some interesting MOS/CSG chip layout comparisons
fhw72
Re: Some interesting MOS/CSG chip layout comparisons
Post by fhw72 »
The latest overlay I did:
https://is.gd/7HRkOq
Fat Agnus/CSG8375R0 Metal vs. Poly
fhw72
Post by fhw72 »
While the vast majority of TED chips for the plus/4, C16 series was
Revision 2 of the 8360 chip there's also a revision 3 out in the wild:
https://is.gd/wnXAU7
fhw72
Post by fhw72 »
In case you want to see a side-by-side comparison of the
8360R2 vs. 8360R3:
https://is.gd/eybQeV
I can't see any changes jumping out at me, other than the addition of the mask copyright. Presumably the behavioural difference is known? Or is it a difference in quality, in some way?
fhw72
Post by fhw72 »
So far I think the ESD protection at the pads was changed and a the back-bias generator was changed very(!) slightly.
Apart from that I didn't see anything else - but I didn't take a look at full resolution yet.
My guess is that it was just a change for a different manufacturing process. Note: the R2 was introduced 1984
and the R3 apparently 1986 and MOS migrated from NMOS to HMOS-I and HMOS-II inbetween IIRC.
MOS/CSG did the same with the 6581 which had almost identical layouts from R2 to R3 and R4. Only changes for
the manufacturing process (e.g. die shrink).
fhw72
Post by fhw72 »
Here's a comparison of the
CSG8501R4 vs. MOS6509R7 die:
https://is.gd/9VbUjo
fhw72
Post by fhw72 »
The 2nd most important chip:
https://is.gd/bITbIm
6581R4AR metal + poly layer
fhw72
Post by fhw72 »
Here's some comparison of the PAL vs NTSC version
of the VIC-II:
https://is.gd/PYsfv9
fhw72
Post by fhw72 »
Finally the PAL VIC-II:
https://is.gd/ZvoqC3
fhw72
Post by fhw72 »
Just for the sake of it I started vectorizing the 6509R7:
