The latest overlay I did:
https://is.gd/7HRkOq
Fat Agnus/CSG8375R0 Metal vs. Poly
Some interesting MOS/CSG chip layout comparisons
Re: Some interesting MOS/CSG chip layout comparisons
While the vast majority of TED chips for the plus/4, C16 series was
Revision 2 of the 8360 chip there's also a revision 3 out in the wild:
https://is.gd/wnXAU7
I can't see any changes jumping out at me, other than the addition of the mask copyright. Presumably the behavioural difference is known? Or is it a difference in quality, in some way?
So far I think the ESD protection at the pads was changed and a the back-bias generator was changed very(!) slightly.
Apart from that I didn't see anything else - but I didn't take a look at full resolution yet.
My guess is that it was just a change for a different manufacturing process. Note: the R2 was introduced 1984
and the R3 apparently 1986 and MOS migrated from NMOS to HMOS-I and HMOS-II inbetween IIRC.
MOS/CSG did the same with the 6581 which had almost identical layouts from R2 to R3 and R4. Only changes for
the manufacturing process (e.g. die shrink).
Just for the sake of it I started vectorizing the 6509R7:
