Dajgoro wrote:
Dajgoro wrote:
Can anyone recommend a schottky diode model that is easily obtainable and affordable in large quantities?
I prefer trough hole for now.
Edit: I need the drives for tristating the bus too, so I can have another device access the bus.
An alternative would be to use Thevenin termination, which is just a bunch of resistors. The 74ABT245 transceivers you are using can source 32ma and sink 64ma, which gives you some leeway in choosing appropriate resistor values. For a start, I would try 220 ohms from the '245 outputs up to Vcc and 330 ohms from the '245 outputs to ground. That combination would produce a characteristic impedance of around 100 ohms on each signal.
You could use discrete resistors (1/4 watt carbon film recommended) or a resistor array. I use the latter on my SCSI host adapter for bus termination.
