6502 36pin CPU module
Re: 6502 36pin CPU module
Dajgoro wrote:
Dajgoro wrote:
Can anyone recommend a schottky diode model that is easily obtainable and affordable in large quantities?
I prefer trough hole for now.
Edit: I need the drives for tristating the bus too, so I can have another device access the bus.
Please see attached for a suggestion.
The attachment 74s1053_schottky_array_16.pdf is no longer available
Nice, but looking on ebay they tend to be a bit expensive.
Is there an electronics distributor in your area that might be able to get it for you at a more reasonable cost?
An alternative would be to use Thevenin termination, which is just a bunch of resistors. The 74ABT245 transceivers you are using can source 32ma and sink 64ma, which gives you some leeway in choosing appropriate resistor values. For a start, I would try 220 ohms from the '245 outputs up to Vcc and 330 ohms from the '245 outputs to ground. That combination would produce a characteristic impedance of around 100 ohms on each signal.
You could use discrete resistors (1/4 watt carbon film recommended) or a resistor array. I use the latter on my SCSI host adapter for bus termination.
4100r_array_bourns.pdf
Resistor Array
(218.85 KiB) Downloaded 71 times
resistor_array_bourns_4300Rseries.pdf
Resistor SIPs
(210.63 KiB) Downloaded 76 times
resistor_array_bourns_4600Rseries.pdf
Resistor SIPs
(235.14 KiB) Downloaded 65 times
transmission_line_terminations.pdf
Some transmission line termination theory.
(314.95 KiB) Downloaded 70 times
Dajgoro
Post by Dajgoro »
That would be ok if I only had 74ABT245 as siganl sources, other modules might have different characteristics.
I tried sending an email to unicornelectronics to see if they had them, but their mailbox is full. :(
In that case, Schottky diodes (discrete or array) would probably be your best bet.
