It is currently Fri Nov 22, 2024 2:14 pm
Post new topic Reply to topic  [ 245 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 17  Next
PostPosted: Thu Mar 23, 2023 5:38 pm
In your code, when you do 'rndbyte = (rndbyte + carry)' you should generate an additional carry when rndbyte=255 and carry=1
PostPosted: Thu Mar 23, 2023 5:44 pm
Alex1 wrote:
Found '008AA873' at index 0 !
Found '008AA873' at index 11EC9D07 !
Found '008AA873' at index 36982356 !
Found '008AA873' at index B20751BF !
I don't see that. Here is my output (byte #, internal state, output byte)
11ec9d02 : 8a a0 25 94 ba 34 ef - 55
11ec9d03 : cf 6f 95 29 81 b6 a5 - 24
11ec9d04 : 14 84 19 43 67 1e c4 - a3
11ec9d05 : 59 dd f6 39 65 84 48 - 2d
11ec9d06 : 9e 7b 72 ac 49 ce 16 - 5f
11ec9d07 : e3 5e d1 7d b5 83 9a - 2f
11ec9d08 : 28 87 58 d6 01 85 1f - 1e
11ec9d09 : 6d f4 4c 23 3e c3 e2 - dc
11ec9d0a : b2 a6 f3 16 33 f7 d9 - ea
11ec9d0b : f7 9d 91 a8 a4 9b 75 - d1
PostPosted: Thu Mar 23, 2023 5:51 pm
ah yes, thanks !
Here's when I see the bytes 00 8A A8 73 in sequence:
(index)    : internal state       - output 4-byte sequence
0000000004 : 14 b3 66 74 dc ce af - 73 008aa873
001b4c11af : 2b 0c f5 cc 69 0f 1a - 73 008aa873
031110bb51 : d5 19 99 54 ff aa 8c - 73 008aa873
036d723c01 : 45 71 51 42 13 8c 60 - 73 008aa873
038707f8e7 : 43 72 c4 30 59 ea 2a - 73 008aa873
As you can see, even though the sequence 00 8A A8 73 shows up repeatedly, the internal state differs. That's because you're only watching 4 consecutive bytes, but there are 7 bytes of state.
PostPosted: Thu Mar 23, 2023 5:52 pm
Here is the code i use, something wrong with unint_t ? Could you paste your C code ready to compile ?
#include <stdint.h>
#include <stdio.h>
#define ADD( a, b )                 \
    do {                            \
        x = a + (b);                \
        a = x;                      \
    } while (0)
#define ADC( a, b )                 \
    do {                            \
        x = a + (b) + (x >> 8) % 2; \
        a = x;                      \
    } while (0)
    uint16_t x;
void main()
    uint8_t s0,s1,s2,s3,s4,s5,s6,res;
    uint32_t z,q;
    s0=0;s1=0;s2=0;s3=0;s4=0;s5=0;s6=0;
    q=0xffffffff;
    for (z=0;z<q;z++)
        ADD( s0, 0x45 );
        ADC( s1, s0 );
        ADC( s2, s1 );
        ADC( s3, s2 );
        ADC( s4, s3 ^ s6 );
        ADC( s5, s4 );
        ADC( s6, s5 );
        res= s6 ^ s4;
       // putchar( s6 ^ s4 );
        printf("%0.2X",res);
        //printf("%0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X\n", s0,s1,s2,s3,s4,s5,s6,res);
PostPosted: Thu Mar 23, 2023 6:01 pm
That looks good, as far as I can see, but when I run it, I don't see 008AA873 at index 11EC9D07
PostPosted: Thu Mar 23, 2023 6:04 pm
Okay so you find the same repetitive outputs, but why don't you find them at the same indexes as on my side?
Can an onverflow cause this?
something with uint16_t and uint8_t ? Data loss during conversion?
PostPosted: Thu Mar 23, 2023 6:11 pm
I think you need to cast up to uint16_t before adding, inside the macros. Otherwise it does the add truncated to 8 bits, even though the result is stored in a 16 bit variable.
Edit: here for sure in ADD - doesn't matter which operand you cast:
x = (uint16_t)a + (b);
And maybe similarly in ADC though in that one the fact that "x" is involved might mean it's already evaluated at 16 bits - I don't recall whether these things associate left or right though so maybe casting the a or b term would be needed.
PostPosted: Thu Mar 23, 2023 6:12 pm
could you give me an example ?
PostPosted: Thu Mar 23, 2023 6:26 pm
According to C standard, addition of smaller integer types should be promoted to 'int' before doing the addition, so there's no need to do a cast first.
PostPosted: Thu Mar 23, 2023 6:30 pm
I copied your program, and then let it run to the point where you found the first repetition, and printed out the values. At that point, I did not see the pattern in the output.
PostPosted: Thu Mar 23, 2023 6:32 pm
Ah OK, apologies, I had thought it just promoted to the wider width of the two.
PostPosted: Thu Mar 23, 2023 6:33 pm
Then it's a compilation problem. I'm on linux ARM.
How should i cast your code to try if the problem is solved with it ?
PostPosted: Thu Mar 23, 2023 6:39 pm
It does that too, but only if one of the types is larger than 'int'. So if you do int + long, it will first promote the 'int' to 'long' and then do long+long addition.
PostPosted: Thu Mar 23, 2023 6:42 pm
I added this to your code:
        ADC( s3, s2 );
        ADC( s4, s3 ^ s6 );
        ADC( s5, s4 );
        ADC( s6, s5 );
        res= s6 ^ s4;
        if( z > 0x11EC9D00 )
            printf("%08x : %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X = %0.2X\n", z, s0,s1,s2,s3,s4,s5,s6,res);
            if( z > 0x11EC9D10 )
                break;
When I run it, I get this:
11ec9d01 : 8A A0 25 94 BA 34 EF = 55
11ec9d02 : CF 6F 95 29 81 B6 A5 = 24
11ec9d03 : 14 84 19 43 67 1E C4 = A3
11ec9d04 : 59 DD F6 39 65 84 48 = 2D
11ec9d05 : 9E 7B 72 AC 49 CE 16 = 5F
11ec9d06 : E3 5E D1 7D B5 83 9A = 2F
11ec9d07 : 28 87 58 D6 01 85 1F = 1E
11ec9d08 : 6D F4 4C 23 3E C3 E2 = DC
11ec9d09 : B2 A6 F3 16 33 F7 D9 = EA
11ec9d0a : F7 9D 91 A8 A4 9B 75 = D1
11ec9d0b : 3C DA 6B 14 06 A2 17 = 11
11ec9d0c : 81 5B C7 DB D2 74 8C = 5E
11ec9d0d : C6 21 E9 C4 1B 90 1C = 07
11ec9d0e : 0B 2D 16 DB E2 72 8F = 6D
11ec9d0f : 50 7D 93 6E C4 37 C7 = 03
11ec9d10 : 95 12 A6 14 98 D0 97 = 0F
11ec9d11 : DA EC 92 A7 C8 98 30 = F8
can you try that too?
