Random-number generation
Re: Random-number generation
In your code, when you do 'rndbyte = (rndbyte + carry)' you should generate an additional carry when rndbyte=255 and carry=1
Alex1 wrote:
Found '008AA873' at index 0 !
Found '008AA873' at index 11EC9D07 !
Found '008AA873' at index 36982356 !
Found '008AA873' at index B20751BF !
11ec9d02 : 8a a0 25 94 ba 34 ef - 55
11ec9d03 : cf 6f 95 29 81 b6 a5 - 24
11ec9d04 : 14 84 19 43 67 1e c4 - a3
11ec9d05 : 59 dd f6 39 65 84 48 - 2d
11ec9d06 : 9e 7b 72 ac 49 ce 16 - 5f
11ec9d07 : e3 5e d1 7d b5 83 9a - 2f
11ec9d08 : 28 87 58 d6 01 85 1f - 1e
11ec9d09 : 6d f4 4c 23 3e c3 e2 - dc
11ec9d0a : b2 a6 f3 16 33 f7 d9 - ea
11ec9d0b : f7 9d 91 a8 a4 9b 75 - d1
Here's when I see the bytes 00 8A A8 73 in sequence:
As you can see, even though the sequence 00 8A A8 73 shows up repeatedly, the internal state differs. That's because you're only watching 4 consecutive bytes, but there are 7 bytes of state.
(index) : internal state - output 4-byte sequence
0000000004 : 14 b3 66 74 dc ce af - 73 008aa873
001b4c11af : 2b 0c f5 cc 69 0f 1a - 73 008aa873
031110bb51 : d5 19 99 54 ff aa 8c - 73 008aa873
036d723c01 : 45 71 51 42 13 8c 60 - 73 008aa873
038707f8e7 : 43 72 c4 30 59 ea 2a - 73 008aa873
#include <stdint.h>
#include <stdio.h>
#define ADD( a, b ) \
do { \
x = a + (b); \
a = x; \
} while (0)
#define ADC( a, b ) \
do { \
x = a + (b) + (x >> 8) % 2; \
a = x; \
} while (0)
uint16_t x;
void main()
uint8_t s0,s1,s2,s3,s4,s5,s6,res;
uint32_t z,q;
s0=0;s1=0;s2=0;s3=0;s4=0;s5=0;s6=0;
q=0xffffffff;
for (z=0;z<q;z++)
ADD( s0, 0x45 );
ADC( s1, s0 );
ADC( s2, s1 );
ADC( s3, s2 );
ADC( s4, s3 ^ s6 );
ADC( s5, s4 );
ADC( s6, s5 );
res= s6 ^ s4;
// putchar( s6 ^ s4 );
printf("%0.2X",res);
//printf("%0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X\n", s0,s1,s2,s3,s4,s5,s6,res);
That looks good, as far as I can see, but when I run it, I don't see 008AA873 at index 11EC9D07
Can an onverflow cause this?
something with uint16_t and uint8_t ? Data loss during conversion?
I think you need to cast up to uint16_t before adding, inside the macros. Otherwise it does the add truncated to 8 bits, even though the result is stored in a 16 bit variable.
Edit: here for sure in ADD - doesn't matter which operand you cast:
And maybe similarly in ADC though in that one the fact that "x" is involved might mean it's already evaluated at 16 bits - I don't recall whether these things associate left or right though so maybe casting the a or b term would be needed.
x = (uint16_t)a + (b);
According to C standard, addition of smaller integer types should be promoted to 'int' before doing the addition, so there's no need to do a cast first.
Alex1 wrote:
Okay so you find the same repetitive outputs, but why don't you find them at the same indexes as on my side?
Arlet wrote:
How should i cast your code to try if the problem is solved with it ?
gfoot wrote:
Ah OK, apologies, I had thought it just promoted to the wider width of the two.
I added this to your code:
When I run it, I get this:
can you try that too?
ADC( s3, s2 );
ADC( s4, s3 ^ s6 );
ADC( s5, s4 );
ADC( s6, s5 );
res= s6 ^ s4;
if( z > 0x11EC9D00 )
printf("%08x : %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X = %0.2X\n", z, s0,s1,s2,s3,s4,s5,s6,res);
if( z > 0x11EC9D10 )
break;
11ec9d01 : 8A A0 25 94 BA 34 EF = 55
11ec9d02 : CF 6F 95 29 81 B6 A5 = 24
11ec9d03 : 14 84 19 43 67 1E C4 = A3
11ec9d04 : 59 DD F6 39 65 84 48 = 2D
11ec9d05 : 9E 7B 72 AC 49 CE 16 = 5F
11ec9d06 : E3 5E D1 7D B5 83 9A = 2F
11ec9d07 : 28 87 58 D6 01 85 1F = 1E
11ec9d08 : 6D F4 4C 23 3E C3 E2 = DC
11ec9d09 : B2 A6 F3 16 33 F7 D9 = EA
11ec9d0a : F7 9D 91 A8 A4 9B 75 = D1
11ec9d0b : 3C DA 6B 14 06 A2 17 = 11
11ec9d0c : 81 5B C7 DB D2 74 8C = 5E
11ec9d0d : C6 21 E9 C4 1B 90 1C = 07
11ec9d0e : 0B 2D 16 DB E2 72 8F = 6D
11ec9d0f : 50 7D 93 6E C4 37 C7 = 03
11ec9d10 : 95 12 A6 14 98 D0 97 = 0F
11ec9d11 : DA EC 92 A7 C8 98 30 = F8
